jorgelu17 Samba Member
Posted: Wed Jan 22, 2025 9:23 am Post subject: Pertronix Flame Thrower Electronic Distributor & Coil |
Hi. I purchased the Pertronix Flame Thrower Electronic Distributor and Ignition Coil for my 71 VW convertible Super Beetle. My question is, is it worth to install and does it make a big difference in starting it up and performance. Is there any cons that may go with this? Also, do I need to purchase the pertronix spark plug wires to or will the stock ones work? Thank you Samba peeps!! I look forward and appreciate the feedback! |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11276 Location: Huntington Beach, CA
Posted: Wed Jan 22, 2025 9:45 am Post subject: Re: Pertronix Flame Thrower Electronic Distributor & Coil |
The ignition module will die, unexpectedly and most likely when you are the furthest point away from help. I always carried a preset points distributor in my tool box, so it was no big deal. The coils are great, better than the new Bosch ones. Wires are good too.
My module lasted about 7 years. When it died, I had just filled up the tank coming back from a Bug show in Irwindale, 35 miles away. Had a hard time starting it back up. When it did start it was all over the place. No power with pedal push. So, I pushed it over to a parking spot across from the pump and swapped out the distributor. BAM! Car came back to life and I drove home! No more Pertronix for me! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79844 Location: Sneaking up behind you
Posted: Wed Jan 22, 2025 10:06 am Post subject: Re: Pertronix Flame Thrower Electronic Distributor & Coil |
It will make the car faster than a Ferrari
Seriously, i'm not a fan. When they die, they just drop dead, unlike points that give you warning signs. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4521 Location: viroqua wi.
Posted: Wed Jan 22, 2025 10:30 am Post subject: Re: Pertronix Flame Thrower Electronic Distributor & Coil |
I have used the modules for years, never had an issue. Carry points a feeler gauge and the right size screwdriver. Or do what VW_Jimbo does. Timed with clamp installed. Don't forget the 13mm |
Glenn  Mr. 010
Posted: Wed Jan 22, 2025 11:04 am Post subject: Re: Pertronix Flame Thrower Electronic Distributor & Coil |
bsairhead wrote: |
Carry points a feeler gauge and the right size screwdriver. |
51 years of driving my Beetle and never carried a spare set of points or a distributor... and i've been cross country 3 times with it.
Just do regular maintenance and you'll never have a problem.
You still need to change the oil and adjust valve lash every 3000 miles, so service the points at the same time. _________________ Glenn
Member #1009
#BlueSquare
Posted: Wed Jan 22, 2025 11:16 am Post subject: Re: Pertronix Flame Thrower Electronic Distributor & Coil |
Glenn wrote: |
bsairhead wrote: |
You still need to change the oil and adjust valve lash every 3000 miles, so service the points at the same time. |
Yes Glenn but your a points guy. |
Glenn  Mr. 010
Posted: Wed Jan 22, 2025 11:31 am Post subject: Re: Pertronix Flame Thrower Electronic Distributor & Coil |
bsairhead wrote: |
Glenn wrote: |
bsairhead wrote: |
I am also an oil change guy and a valve lash guy.
Replacing points is easy.
You still need a timing light with a Pertronix.
Putting one in will not make your care maintenance free, you either need to learn how to do it or pay someone else. _________________ Glenn
Member #1009
#BlueSquare
Posted: Wed Jan 22, 2025 11:44 am Post subject: Re: Pertronix Flame Thrower Electronic Distributor & Coil |
Yes you need to do or have maintenance done. A couple years ago I went to a VW show about 120 miles from home in my Bay Window. Found a good deal on a vintage cast iron distributor and decided to run it home. A friend of mine watching asks what I was doing sitting on my camp stool with the deck lid open. My response, ''playing". |
Posted: Wed Jan 22, 2025 1:13 pm Post subject: Re: Pertronix Flame Thrower Electronic Distributor & Coil |
From the sounds of it, it does not seem to be a good upgrade then! That's what I"m getting out of this. Thanks for the responses so far fellas! |
Zundfolge1432  Samba Member
Posted: Wed Jan 22, 2025 1:14 pm Post subject: Re: Pertronix Flame Thrower Electronic Distributor & Coil |
jorgelu17 wrote: |
Oh yes it’s here https://www.thesamba.com/vw/forum/viewtopic.php?t=281144 |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 4176 Location: Georgia
Posted: Wed Jan 22, 2025 2:31 pm Post subject: Re: Pertronix Flame Thrower Electronic Distributor & Coil |
People keep saying these things are unreliable but I’ve been running them for 30 years and never a problem. Full disclosure, I’ve never used their distributor. I just installed the module in my stock distributor or a German 009.
Even if they’re not to be trusted, why wouldn’t one just have another module to carry around? Easy swap, even on the side of the road.
Pertronix I will use the stock coil and plug wires.
Pertronix II uses a different coil and different plug wires.
Never used a Pertronix III. I think those use a different coil and wires as well.
Recently, I installed a MagnsSpark II from CB Performance. Can’t say I noticed any perceivable difference in performance but I’m thinking about replacing the plug wires that came with the kit as they don’t have a very good click feel on the plug end. _________________ Volkswagen!
(Compression 8.7:1) |
Glenn  Mr. 010
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 2115 Location: Wichita, KS
Posted: Wed Jan 22, 2025 2:52 pm Post subject: Re: Pertronix Flame Thrower Electronic Distributor & Coil |
The main difference (as I see it) is that you can still generally find good quality, dependable points out there -- e.g. NOS Bosch points have proven very trustworthy for me over many years now. In fact, I find I've usually been able to file/sand, clean, and reuse them several times in a row.
Unfortunately (and I truly wish this was not the case), the same cannot be said for currently available Petronix units. Maybe they'll work a long time, maybe they won't -- no way to know for sure nowadays. And if & when they do fail, it's often with no warning whatsoever -- you're just suddenly left with a completely dead engine, maybe in the middle of the freeway, maybe in the middle of nowhere, who knows?
So to me, for good quality & dependable electronic ignition vs. similar good quality points? There's no contest -- the electronic ignition easily wins, hands-down!
But for questionable quality & dependability electronic ignition vs. good quality points? Then it's the other way around -- the points are generally the more practical and trustworthy option in that case. That's why I've been running them, anyway.
Just my $0.02 on the matter -- YMMV...
(note, that above write-up was copied from this earlier thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=796198&start=0) _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
wcfvw69 Samba Purist
Posted: Wed Jan 22, 2025 3:52 pm Post subject: Re: Pertronix Flame Thrower Electronic Distributor & Coil |
I have had so many customers try the points replacement modules, install them per instructions and had them fail, leaving them on the side of the road. Like mentioned, lots of folks have luck with them too. But it's kind of worrisome to have to carry a set of points and condenser just in case too. What if the engine dies in rush hour traffic on the freeway?
I just haven't been left stranded by points or condensers in 40 plus years of VW ownership. I know several people who still daily drive their bus or bug. They've all tried the modules and went back to points and condensers.
The other issue is the Pertronix modules don't play well with some of the fuel injected buses either. Lots of threads about misses at different RPMS. Several folks have emailed me over the years with this issue and asking if the distributor was at fault or needed to be restored. I found they had the module installed. I told them to remove the module and install a set of points and condenser. They did and their issues resolved.
I don't mind taking 5 minutes adjusting the points (if needed) every three thousand miles and reapplying new points wear block grease. As mentioned it's just part of the maintenance of these old cars. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Wed Jan 22, 2025 4:00 pm Post subject: Re: Pertronix Flame Thrower Electronic Distributor & Coil |
Not all of us have gone back to points. Not saying I don't have a back up just saying I never needed it. |
Glenn  Mr. 010
Posted: Wed Jan 22, 2025 4:12 pm Post subject: Re: Pertronix Flame Thrower Electronic Distributor & Coil |
bsairhead wrote: |
But you have it because you think you will need it. _________________ Glenn
Member #1009
#BlueSquare
cjsuner Samba Member
Joined: January 04, 2013 Posts: 513 Location: Bay area CA
Posted: Wed Jan 22, 2025 5:21 pm Post subject: Re: Pertronix Flame Thrower Electronic Distributor & Coil |
Been on my Pertonix I dizzy for 15 years, and I've never had a problem with it, and no, I don't carry a spare point dizzy around either.
I recently upgraded to an MSD ignition system, so I swapped my Pertonix dizzy over to my wifes car, and haven't had any issues over there either.
YRMV (your results may very) but i've always enjoyed easy start-ups with my cars, single, or dual carbs. _________________ 71 Super Convertible (Orange)
74 Standard Beetle (Light Blue) |
Posted: Wed Jan 22, 2025 5:39 pm Post subject: Re: Pertronix Flame Thrower Electronic Distributor & Coil |
Glenn wrote: |
bsairhead wrote: |
But you have it because you think you will need it. |
I also carry a jack and tools. |
Glenn  Mr. 010
Posted: Wed Jan 22, 2025 5:48 pm Post subject: Re: Pertronix Flame Thrower Electronic Distributor & Coil |
bsairhead wrote: |
Glenn wrote: |
bsairhead wrote: |
Do you carry a spare coil, fuel pump, carb, spark plugs, speedo and battery?
Hell, I don't carry a spare tire since I have different front and read and neither fit in the tire.well. _________________ Glenn
Member #1009
#BlueSquare
BenJAMin Samba Member
Joined: February 01, 2004 Posts: 528 Location: Michigan
Posted: Wed Jan 22, 2025 6:40 pm Post subject: Re: Pertronix Flame Thrower Electronic Distributor & Coil |
I've run a Pertronix Ignitor in my Bosch distributor since 2002. In more recent years I bought a chinese copy for $20 that I did try to keep just in case there was a problem. If/when I ever had a Pertronix problem I"ll either go 123 or Pat Downs Shockwave. I've had 2 123s in 2 different Citroens for over 20 years.
Fun Fact: I've never been stranded by Electronic Ignition, I have with Condensers. |
