Casperfg Samba Member
Posted: Sun Feb 16, 2025 6:08 pm Post subject: Vintage speed instruments/gauges |
Hi there,
Greetings from Boerne Texas.
I've got a 57' beetle that will be receiving an okrasa transplant.
I'm interested in what gauges you folks find useful in your vintage speed rides? I'd like to use vintage or vintage inspired stuff and not cut the dash if possible? Thoughts, suggestions much appreciated.
Dean
Bub Samba Member
Joined: June 10, 2004 Posts: 1339 Location: Central Washington
Posted: Mon Feb 17, 2025 10:11 am Post subject: Re: Vintage speed instruments/gauges |
Proper gauges are pretty rare these days. IF you can find a 5k tacho that's the ticket,.
if not, a 6k tach is a decent add on, but don't run one that goes over 6k...ain't foolin nobody!. And they don't look right.
Add an oil temp +/- pressure gauge off the steering column, or under the dash. It's one of those things you want to do, but not 'over-do"
Go through the 'gauges' thread ....there's lots of good stuff in there.
https://www.thesamba.com/vw/forum/viewforum.php?f=26 _________________
| hitest wrote: |
| Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was... |
Posted: Mon Feb 17, 2025 3:52 pm Post subject: Re: Vintage speed instruments/gauges |
Thank you Bud, that is exactly the info I need!
Dean |
gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1890 Location: Clearwater Fl.
Posted: Wed Feb 19, 2025 11:24 am Post subject: Re: Vintage speed instruments/gauges |
| Looks like a simple straightforward feedback gauge, could the signal make it to the dash area? |
Posted: Wed Feb 19, 2025 4:06 pm Post subject: Re: Vintage speed instruments/gauges |
One single wire… _________________ www.blastserv.com
wanted:
Nothing! |
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1290 Location: australia
Posted: Fri Feb 28, 2025 5:11 am Post subject: Re: Vintage speed instruments/gauges |
I like the look of the VDO accessory striped gauges.
This is a 1956 catalogue as uploaded by IN2VWS
Note the VDO ring style gauge mounts used in the very top pic of gauges mounted under the dash.
Personally I have oil pressure, oil temperature, a tachometer and a fuel gauge set up ready for an early big window (bar the correct fuel and tach senders)
For a single gauge, Motometer made a single mount that mounts to the steering column, reproductions available.
Pic again from the gallery with a modern tach rebuilt to look like the period "striped" gauges.
As said by a previous poster, check the "gauges" sticky in the accessories forum for many many other period gauge options.
Be warned though, period gauges are a whole offshoot rabbit hole of thier own, they come in a huge variety with many variations, are so so pretty, very very more-ish and are small, so are easy to store but can get quite expensive very quickly. Have fun. |
jbannon Samba Member
Joined: September 19, 2020 Posts: 239 Location: New York
Posted: Sat Mar 15, 2025 6:52 am Post subject: Re: Vintage speed instruments/gauges |
Something to consider if you don’t want to drill holes in the dash and desire a clean and elegant look/solution, is Fast Fab’s gauge panel for 52mm gauges. It’s very well made, and can be easily painted to match your car. I installed one in my 58 ragtop vintage speed build and it looks amazing in my opinion. If done correctly, it looks almost like a factory or period correct accessory.
https://www.fastfabonline.com/Gauge-Panel-two-Gauge--Ghia-56-65-Beetle-50-57_p_130.html _________________ 59 Beetle - Diamond Grey
58 Beetle ragtop - Glacier Blue
58 Beetle ragtop - Black
56 Beetle - Stratos Silver
62 Beetle - Turkis
67 Beetle - Savannah Beige |
Posted: Tue Apr 15, 2025 2:55 am Post subject: Re: Vintage speed instruments/gauges |
I was wondering if anyone had wiring diagrams for the VDO oil temp and oil pressure gauges? Here are photos of the gauges:
62 Beetle - Turkis
petrol punk Samba Member
Joined: August 21, 2007 Posts: 1054 Location: Las Vegas, NV
Posted: Tue Apr 15, 2025 6:02 am Post subject: Re: Vintage speed instruments/gauges |
I have oil temp and pressure. Pressure is not that useful, I've never really needed it but I keep it there since I have 2 gauge holes. I'd rather swap it out for a tach. _________________ 36hp '56 European DeLuxe oval
'70 bug 1835cc |
Posted: Tue Apr 15, 2025 6:16 am Post subject: Re: Vintage speed instruments/gauges |
Thanks for the reply. I actually have a tach as well. I have these gauges and want to use them in my vintage speed build. Any wiring diagrams are welcome. _________________ 59 Beetle - Diamond Grey
62 Beetle - Turkis
EverettB  Administrator
Joined: April 11, 2000 Posts: 72013 Location: Phoenix 602
Posted: Tue Apr 15, 2025 4:09 pm Post subject: Re: Vintage speed instruments/gauges |
+ = Power
G = Wire to sender
- or little symbol that looks like a downward arrow with 3 bars = Ground
The ground looks to be the connection in the bottom center as you face the back of the gauge but the gauge may also ground via the mounting bracket, if I am mistaken about the markings on that post.
Ground symbol:
_________________ How to Post Photos
