Gauges - Post Pics!
Page: Previous  1, 2, 3 ... 20, 21, 22
dhaavers
dhaavers is offline
PostPosted: Thu Sep 05, 2024 5:35 pm    Post subject: Re: Gauges - Post Pics! Reply with quote
qbini wrote:
LOVE this! ^^^
Cool
- Dave
"The WonderVan"
ZsZ
ZsZ is offline
PostPosted: Sun Mar 09, 2025 7:54 am    Post subject: Re: Gauges - Post Pics! Reply with quote
Added coolant temp, oil temp and oil pressure gauges.
The gauge holder was part of the kit (you can buy them separately) But had to design and make a cover for the side.
Modelled in 3D, unfolded the surface to have a cut sheet and cut and glued the cover.
Will share the 3D model just have to clean it up.
Still need to wire them up, but already installed the sensors.
Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008
uberaudi
uberaudi is offline
PostPosted: Sun Mar 09, 2025 8:53 am    Post subject: Re: Gauges - Post Pics! Reply with quote
Well done! Looks close to a factory piece now..much like a Syncro console.
'84 Adventurewagen 1Z TDI, '08 Audi Avant Quattro 6spd BHW TDI
ZsZ
ZsZ is offline
PostPosted: Sun Mar 09, 2025 11:01 am    Post subject: Re: Gauges - Post Pics! Reply with quote
Thanks!
Here is the 3D model:
https://www.thingiverse.com/thing:6973989
Zoltan
drj434343
drj434343 is offline
PostPosted: Sun Mar 09, 2025 3:00 pm    Post subject: Re: Gauges - Post Pics! Reply with quote
Here's my contribution:
Typical Speed Hut gauge replacement, but with a center screen that gives lean angle, outside temp and humidity, low coolant, and check engine. The rest of the idiot lights from the center section transfer over to the gauges (coolant temp, voltage, oil pressure, low fuel, turn signal, and high beam indicators.
uberaudi
uberaudi is offline
PostPosted: Sun Mar 09, 2025 8:40 pm    Post subject: Re: Gauges - Post Pics! Reply with quote
That is rad! Did you create that center piece? Love the tilt angles...that would be so nice to level a camp spot!
drj434343
PostPosted: Sun Mar 09, 2025 9:03 pm    Post subject: Re: Gauges - Post Pics! Reply with quote
I gutted the center lights and added an Arduino/screen combo that has a sensor board with tilt and a thermometer probe. It is definitely used for campsite leveling.
Page 22 of 22
