1950split Samba Member
Posted: Fri Mar 31, 2023 7:08 am Post subject: Re: CSP stainless steel stock style muffler pics and impression |
Hi Rustavenger,
How does this CSP competition evo system compare vs a A1 sidewinder or a CSP Python ? Have you had one of those on your engine before to give a comparison ?
I have a CSP python. It is soooo loud that even with noise insulation in the car it gets annoying for longer drives.
I like the competition evo but don't want to give up performance.
My engine : 2276, 86b, 44x38 mid-D heads and IDAs
Any quality issues on the competition evo ?
Thanks,
Phil |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 10930 Location: Oregon
Posted: Fri Mar 31, 2023 7:35 am Post subject: Re: CSP stainless steel stock style muffler pics and impression |
1950split wrote: |
Hi Rustavenger,
Thanks,
Phil |
Phil,
The EVO installation is pretty straight forward. The only issue I had was with the 1/3 lower exhaust fasteners. The exhaust bend is rather tight right off the head. I used m8x10mm hex flare nuts to clear the tubes.
Otherwise, the exhaust was a bolt on deal, no fiddling with ill fitting exhaust flanges.
In the video I posted, The engine at t time was a 2180, Tims S2 heads, 86b.
All you are really hearing in the video, is the roar of the 45 Dellorto's at full throttle. The Jetta I was racing against was completely stock.
CSP designed the EVO exhaust based off the Wasp system. What quiets the exhaust down is the dual muffler system post collector.
When driving the car, it's quieter than the old EMPI cheapy hideaway header and muffler I had originally installed.
We have a 103db noise limit at PIR Saturday night drags. I have never been called out for being too loud.  _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!  |
Posted: Sat Apr 01, 2023 12:26 am Post subject: Re: CSP stainless steel stock style muffler pics and impression |
Hi,
Thanks for your feedback.
Do you have to remove the mufflers to adjust valve play?
I like the peeshooter look of it. |
Posted: Sat Apr 01, 2023 5:52 am Post subject: Re: CSP stainless steel stock style muffler pics and impression |
1950split wrote: |
Hi,
Short answer, No.
But it takes 5-10 minutes to remove the mufflers for better access.
Three allen collector flange fasteners, four rubber vibration hangers, and the mufflers are on the ground. _________________ I have learned over the years.
Buy Once, Cry Once!
toxicavenger70 Samba Member
Posted: Thu Apr 06, 2023 2:05 pm Post subject: Re: CSP stainless steel stock style muffler pics and impression |
Mug Bug wrote: |
To the original poster of this thread........ Now that you've had the CSP for a while, are you still happy with it? Getting ready to order one and thought I would see what you thought first! Thank you. |
I really like it. The only thing that I added is I had heater box flanges welded to the muffler.
Bug53 wrote: |
I want an exhaust that will come out the back of the car through the pea shooter cut-outs, connect to heater boxes, and offer some flow for a 1900 |
The CSP does all of this.
Glenn wrote: |
67rustavenger wrote: |
But the mugbug was asking about the OP's system. Not the CSP EVO Competition system. |
The OP was complaining about the welds... I can say that they are really nice on the system I worked on. |
On a system that required me to sell my kidneys I would hope it would be perfect. I did not exactly expect perfect welds on the one I bought. |
boxer74 Samba Member
Joined: July 03, 2011 Posts: 855 Location: Ontario, Canada
Posted: Fri Sep 13, 2024 7:35 am Post subject: Re: CSP stainless steel stock style muffler pics and impression |
toxicavenger70 wrote: |
Alstrup wrote: |
CSP or VS. The main difference is the manufacturer and the way they weld |
I got to see a VS muffler last week and I agree the welds are nicer on the VS.
I have been running the CSP muffler for a week. It is slightly more throaty than the stock Kadron. My butt dyno says I have a little more grunt with the addition of this muffler. The CIP1 hardware sucked, but I believe the muffler was worth the cost. |
Still running this exhaust and still happy with it?
Considering it for a 1776 with single 40 IDF, so it's nice that it has provisions for good manifold heating. I don't expect this engine to produce more than 90HP anyways, so it should work out well and retain the stock look. Currently have a 1-3/8 header and quiet pack but don't like the look and reduced ground clearance. _________________ 74 Super
84 Westy |
early Samba Member
Joined: January 19, 2012 Posts: 255 Location: Glen Carbon, IL
Posted: Fri Sep 13, 2024 9:45 am Post subject: Re: CSP stainless steel stock style muffler pics and impression |
I happen to like this exhaust system, manifold heat is good, it has a pleasant exhaust note thru my TDE tailpipes. I cut the intake manifold heat pipes, drilled the carbon out with a long 3/8 drill bit and re-welded them back on.works great. Fits great, tips exit correctly
Bruce Samba Member
Joined: May 16, 2003 Posts: 17560 Location: Left coast, Canada
Posted: Sun Sep 15, 2024 1:25 pm Post subject: Re: CSP stainless steel stock style muffler pics and impression |
You have the vacuum advance hose hooked up at the wrong location on the carb. It should be on the left side, forward of the spring. _________________
early Samba Member
Posted: Sun Sep 15, 2024 2:05 pm Post subject: Re: CSP stainless steel stock style muffler pics and impression |
Bruce wrote: |
You have the vacuum advance hose hooked up at the wrong location on the carb. It should be on the left side, forward of the spring. |
Yup, it's a brosol/solex H30/31 carb. These carbs do not have the
Proper vacuum signal at the normal side position.
The rear vacuum position has nearly the right amount of vacuum.
It's been covered here on the samba.
Edit. I plan to try a 1500 style distributor which requires less vacuum
Which this carb supplies, but this project is on the back burner for now
As I finish tuning the bus engine.
Good eye but it's not a 34pict3.
Cheers and thanks |
Posted: Mon Sep 16, 2024 4:58 am Post subject: Re: CSP stainless steel stock style muffler pics and impression |
early wrote: |
I happen to like this exhaust system, manifold heat is good, it has a pleasant exhaust note thru my TDE tailpipes. I cut the intake manifold heat pipes, drilled the carbon out with a long 3/8 drill bit and re-welded them back on.works great. Fits great, tips exit correctly |
Thanks for the feedback. It seems you had no issue clearing the #2 and #4 runners with heater hoses. That's good. _________________ 74 Super
84 Westy |
eljimberino Samba Member
Posted: Fri Mar 21, 2025 6:56 am Post subject: Re: CSP stainless steel stock style muffler pics and impression |
Hi -
Can anyone with a CSP exhaust of any model please tell me how far the closest tube gets to the pulley please?
I have a custom engine mount that is 3-4cm from the pulley...
Thank you |
Murt Samba Member
Joined: October 01, 2017 Posts: 529 Location: Kent, England
Posted: Fri Mar 21, 2025 9:10 am Post subject: Re: CSP stainless steel stock style muffler pics and impression |
I've just recently mocked up a CSP Bus exhaust.
Note, the pulley is not fully on
_________________ 1966 VW Beetle ‘Jules’
1967 Kombi Splitscreen ‘Barney’
2018 VW Caddy Maxi R Line
2017 Golf GTD saloon
2008 VW EOS 2.0 TFSi |
Posted: Fri Mar 21, 2025 9:23 pm Post subject: Re: CSP stainless steel stock style muffler pics and impression |
Okay - that's the competition...
Won't work for me.
I wonder about the wasp.
[/img] |
Posted: Sat Mar 22, 2025 1:22 am Post subject: Re: CSP stainless steel stock style muffler pics and impression |
eljimberino wrote: |
Won't work for me.
[/img] |
Please tell us, what the issue is that you are having with the pulley clearance to header is.
It appears that there is plenty of room to clear the header based on the image above.
By the way, That's some Mastercraft tin fitment you have done on your engine mockup.  _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Sat Mar 22, 2025 8:20 am Post subject: Re: CSP stainless steel stock style muffler pics and impression |
Hello sir
Thank you for your reply
The image I posted isn't my engine.
I have a 1916cc going in a 912 Porsche. The rear mount I have is 3-4cm from the pulley and connects to the bottom of the case via a crossmember that straddles between the chassis rails up top in the engine bay.
Now I need a exhaust upgrade and I don't even know if a stock muffler will fit! |
