2type2 Samba Member
Joined: June 02, 2002 Posts: 1229 Location: SW Colorado
Posted: Sat Jun 01, 2024 6:50 am Post subject: Re: NOTEK German Military Convoy Light |
Any progress to report? _________________ "A life of peace and happiness depends on your own gratefulness" |
volkaholic1 Samba Member
Posted: Sat Jun 01, 2024 10:35 am Post subject: Re: NOTEK German Military Convoy Light |
i've been working on it, but going slow, got the helmet cleaned up
bought some LED 6v ans 12v bulbs and holders
designing the base
bought the stuff to build the mount
need to think about seals to keep the water out _________________ Volkaholic |
2type2 Samba Member
Posted: Sun Jun 02, 2024 6:43 am Post subject: Re: NOTEK German Military Convoy Light |
Good to hear. Perhaps you could source some type of silicone sheet to cut gaskets from. Are you attempting a light up function, or trying for actual " black-out" functionality? Maybe someone with a lathe can help with the stem parts (in aluminum?). Keep us informed please as you go along. _________________ "A life of peace and happiness depends on your own gratefulness" |
Posted: Sun Jun 02, 2024 12:13 pm Post subject: Re: NOTEK German Military Convoy Light |
my plan is to offer both 12v and 6v, i think 3 LED lights will do it
i want to offer either clear white light, or be able to install colored film
for example
yellow - good for fog
blue - supposedly better on the eyes than white
red - to keep you night vision - i think this make the most sense under real war conditions _________________ Volkaholic |
2type2 Samba Member
Posted: Wed Aug 21, 2024 7:41 am Post subject: Re: NOTEK German Military Convoy Light |
Any new developments since last post? _________________ "A life of peace and happiness depends on your own gratefulness" |
Posted: Wed Aug 21, 2024 4:08 pm Post subject: Re: NOTEK German Military Convoy Light |
i am making slow progress, but i have had a set back, my scanner died, super mad about that paid $400 bucks to creality, i sent it back for repair/replacement = nothing, just gone, so i will get a different brand, i am done with those guys, what a rip off! _________________ Volkaholic |
Posted: Sun Oct 27, 2024 1:19 am Post subject: Re: NOTEK German Military Convoy Light |
finally getting close! got the prototype built, will send to my son for scanning so i can 3d print it
so far is 3 parts
easy part the panel the holds the glass (but i will use plexiglass)
my plan is to offer 2 color filter you can add yellow and red
yellow give you better visibility in fog
red give you better night vision (important when bad guys might be hiding around)
the actual top, from Latvia, i painted it primer gray, then white, then filled in all the rust spots with red body putty, left it this way so you can see all the work that went into it
the inside you can see the mount for the window
i was glad to have that 1:35 part i blew up to life size, to see all the imporant details on the base
for the outside, bottom, you can see the all bracing around the shaft, i spent time making the brass clamp, it is for looks only, not functional, but looks cool
on the inside, i put a mount for 3 LED lights, i will i offer both 6V and 12V
the wire will run throught the mount shaft, so nothing visible now i have seen 2 different bases, on this dissucssion, the bases are round but i have seen square bases, so not sure which to offer, your thoughts?
this is a big print job, so might take 2-3 days to complete 1 build. _________________ Volkaholic |
finster Samba Member
Joined: May 26, 2012 Posts: 10607 Location: not far from the madding crowd
Posted: Sun Oct 27, 2024 2:52 am Post subject: Re: NOTEK German Military Convoy Light |
looking good, a lot of work but hopefully worth it. turned out to be quite the project!  _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
Posted: Sun Oct 27, 2024 12:45 pm Post subject: Re: NOTEK German Military Convoy Light |
yep. and that is why it will be priced accordingly _________________ Volkaholic |
Posted: Fri Nov 01, 2024 3:59 pm Post subject: Re: NOTEK German Military Convoy Light |
making progress, made the mounting bracket, used 20 gauge steel plate and 3/4" conduit
has 3 mounting bolts, i used 3/4 conduit for the vertical, one question, i made the shaft 6" but i think it is too tall, what about you? would 4" be better?
advantage of this mount is that you can bend the legs as needed, depending on the vehicle and the exact mounting location.
Posted: Sat Nov 02, 2024 3:16 am Post subject: Re: NOTEK German Military Convoy Light |
the mounting is way too tall, even at 4". the notek sat just above the base plate so the tube only needs to be short enough for the clamp with a little clearance. here are the parts (repro)
https://www.oldtimerteile-s.de/militaria-zubehor/6...ks750.html
Posted: Sat Nov 02, 2024 9:29 am Post subject: Re: NOTEK German Military Convoy Light |
interesting, ok 4" too tall, let me try 3", now some baseplates are round, like you show, but some are like mine, evidently they had more than 1 design, i tried to make the round base plate, like what you show, but just could not get it right, so i went with the other design, both work, both take 3 bolts, so not that much different really. _________________ Volkaholic |
Posted: Tue Nov 26, 2024 2:05 pm Post subject: Re: NOTEK German Military Convoy Light |
made a little progress, this is the 3D printed lens cover, i cut out a little plexiglass window, then got 2 films, 1 for yellow light and 1 for red, slowly coming together
VWNYCMike Samba Member
Posted: Thu Dec 05, 2024 4:49 pm Post subject: Re: NOTEK German Military Convoy Light |
After much deliberation and honestly not having either the skills or the technical resources to make my own, I purchased an original NOTEK that was in dire need of work. This particular one was intact but needed some work after years of exposure to the elements. After disassembly, sandblasting (extremely low pressure with fine grit), painting I was left with a very nice period correct piece.
Viewed several war era photos here on The Samba and settled on a final mounting position more or less along the center axis of the front wheel.
Cut my own natural cork gasket and added some aftermarket stainless steel metric bolts.
Next up is 12v conversion and wiring.
Posted: Thu Dec 05, 2024 5:23 pm Post subject: Re: NOTEK German Military Convoy Light |
wow, nice job, i hope my 3D printed version comes out as nice,,,, _________________ Volkaholic |
2type2 Samba Member
Posted: Sun Apr 06, 2025 7:04 am Post subject: Re: NOTEK German Military Convoy Light |
Still working on this repro effort? _________________ "A life of peace and happiness depends on your own gratefulness" |
Posted: Sun Apr 06, 2025 8:34 am Post subject: Re: NOTEK German Military Convoy Light |
yes, has been going way to slow, hard to find someone that has a scanner and will get me an /stl file, i contact the folks that says they do 3d scanning, then they ask me for my cad file, i tell them i need actual physical parts scanned, and either they cant do it, will not do it, or they want $2000 to "try" to do it.
i thought amazon sells tons of scanners, how come no 1 has 1? i bought 2 and could not get either to even fire up, yet alone work, it sucks, i need to find someone that can do this. should not be this hard. _________________ Volkaholic |
2type2 Samba Member
Posted: Sun Apr 06, 2025 9:03 am Post subject: Re: NOTEK German Military Convoy Light |
With the vast amount of educated and innovative people on the Samba, hopefully someone will help. It always amazes me how people chime in with engineering and fabrication expertise from so many industries. Have you put out a call?
Actually it surprises me that nobody overseas has already done it, given that there's considerable interest in WW2 vehicles and reenactments. Forge on! _________________ "A life of peace and happiness depends on your own gratefulness" |
Posted: Sun Apr 06, 2025 10:41 am Post subject: Re: NOTEK German Military Convoy Light |
i guess i will ask, thanks _________________ Volkaholic |
Posted: Sun Apr 06, 2025 10:55 am Post subject: Re: NOTEK German Military Convoy Light |
so i did just post on this same forum index, we will see what folks say _________________ Volkaholic |
