Run Flores Run Samba Member
Joined: April 09, 2025 Posts: 3 Location: Midland, Texas
Posted: Wed Apr 09, 2025 12:42 pm Post subject: Advice on my 1776cc Engine Build |
1776cc Engine Build
This motor will be for my ’67 Ghia with a stock tranny. It will be a weekend warrior not a daily driver. I would rather have it quicker than faster. I live in west Texas so I’m not sure how the climate and elevation factor in.
I want to re-use some parts if possible. Below is what I’ve come up with so far. I have not purchased anything yet.
Please let me know your thoughts. I’m not locked in on anything yet. Thanks.
Re-use 1600 dual relief AH case
(need to make sure case is still in spec)
Re-use 90.5 pistons and cylinders
(is this a good idea if I re-hone the cylinders and replace the rings)
Re-use SCAT C45 cam
(Is this too much cam?? Would the CB 2280 cheater cam be better)
Re-use 69mm stock crank
Re-use stock rods
Stock clutch
Lightened flywheel
Ultra-light lifters
1.25 rockers on solid shafts with swivel feet adjusters
Stock DP heads (35X32) with dual springs and mildly ported
CB Magna spark ignition system
Dual 40 IDF carbs (clones) (not sure on the jetting)
Not sure about the exhaust size
Not sure about the CR and deck height
Thanks,
Ray, |
Brian_e  Samba Member
Joined: July 28, 2009 Posts: 4280 Location: Rapid City, South Dakota
Posted: Wed Apr 09, 2025 1:16 pm Post subject: Re: Advice on my 1776cc Engine Build |
Couple more questions need to be answered before your combo can get narrowed down.
Do you want to keep the stock heater boxes?
Are you up for running 91 octane all the time?
Whats your elevation?
How high are you wanting to rev it when you are driving it hard??
Is this a weekend cruiser around town, or are you wanting to jump on the highway and run it for 2-3 hours in the summer?
Brian _________________ So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts |
johnnyvw164 Samba Member
Joined: July 27, 2020 Posts: 626 Location: South of Raleigh
Posted: Wed Apr 09, 2025 2:11 pm Post subject: Re: Advice on my 1776cc Engine Build |
power band for that cam is advertised as 3500 to 6500. Since your sticking with a stock crank, definitely go with something milder. I'm currently building something similar, and am using an Engle W90 since I'm limiting the RPMS to 4500 because of the stock crank. Kadrons, VS exhaust, AA500 heads with some port blending and smoothing along with a 3 angle valve grind.
Or...get a c/w crank so you can actually use the RPM capabilities without beating the crap out of the case.
Posted: Wed Apr 09, 2025 2:12 pm Post subject: Re: Advice on my 1776cc Engine Build |
Hey Brian, thanks for responding.
I'll be running J tubes with a 4-1 header but not sure what size exhaust.
I'm up for running 91 octane if I need to.
Elevation here is 2,782
Not sure how high I want to rev it. I'm old so I'm not an aggressive driver but I do want to "get on it" from time to time.
It will be mostly around town driving. From time to time I'll get it on the loop at 60mph. |
Posted: Wed Apr 09, 2025 2:36 pm Post subject: Re: Advice on my 1776cc Engine Build |
The c45 is a pretty big cam, especially for a 1776cc with stock heads.
If you are after more low end grunt for town driving, but still need to spin it to 5000+, I would say something in the 236-242 @ .050" range.
A cheap 1 3/8" hideout header and muffler from CB would be good. A ss143 from Vintage Speed would be better, and really quiet. But also lots more money.
Here is what I would build. I have done the same thing a couple times now, and they run great.
Stock crank and rods rebuilt
Re-use your P&C's if they are in good shape. Hone the barrels, and add new Grant cast rings.
cb2239 cam, and their cheap lifters
Stock push rods, cut down.
Stock adjusters, or CB elephant foot adjusters. (NO SWIVEL BALL STYLE!!!)
Solid style rocker shafts.
Light flywheel
aa500 heads, blended bowls, and a good, well placed 3-4 angle valve job
Single HD valve springs.
Amazon 40mm IDF's, with 30mm vents
CB offset manifold and linkage kit.
CB hideout muffler and 1 3/8" header
Sachs clutch and pressure plate, shimmed for max holding pressure.
.040" deck height
8.8-9.0:1 compression.
Get the heads right, and the deck height where it needs to be, and it will run cool, and have really good power for what it is. No need for a fancy crank, just get it all dynamically balanced, and it will last a really long time.
BFB will say its boring, and cookie cutter, but that's because it works good, its cheap to build, and it will make really good power if its put together right. No need to make it more difficult than it needs to be.
-Modok
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7971 Location: Videbaek Denmark
Posted: Wed Apr 09, 2025 2:41 pm Post subject: Re: Advice on my 1776cc Engine Build |
He´s talking weekend warrior. If the heads are good and the CR is decent, I see no issues on that. The older C45 cams - can - be good, and help deliver great overall power. The newer ones are sadly crap.
Stock heat exchangers and a 1 3/8" header/ hideaway will be waaay too restrictive. Even a 1 3/8 with a good collector/muffler set up will limit it at 115-120 hp. A decent 1½" system will support the exhaust flow needed. As always for medium engines I like the Super Comp both for power support and tunability. - and you will need all the help you can get in the ghia, because you have to limit the intakew length. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4249 Location: San Diego
Posted: Wed Apr 09, 2025 3:24 pm Post subject: Re: Advice on my 1776cc Engine Build |
I can second Brian’s recommendations on a similar 1776, CB2239 cam. 9 to 1 CR, .040” deck This is in a bus so I do have gear advantage with RGB’s
Today I floored it on a steep off ramp doing about 58mph. Passed a F150 doing about 72 close to the top of the hill. The guy yelled at me at the stop light. What the HELL do you have in that thing!  |
DesertSasquatchXploration Samba Member
Posted: Wed Apr 09, 2025 7:27 pm Post subject: Re: Advice on my 1776cc Engine Build |
The other day @ CarCraft the engine builder was very adamant about never going smaller then a .060 deck. I didn't ask or provoke any response about deck height. Just asked about the heads they offer.
He suggested 40x35.5 heads on My short block a 90.5 69 crank with a 100 cam.
Do a 60deck cut heads to 8.8-9.0 CR. Seems a bit weird. Possibly he was thinking I could expand to a dual IDF setup when I get tired of a single?
I'm going with Brian's suggestions nice valve job, tight deck and stock valves. Plenty of manifold Air speed for around town your not at the track jumping from 5-7K |
Posted: Thu Apr 10, 2025 5:35 am Post subject: Re: Advice on my 1776cc Engine Build |
| DesertSasquatchXploration wrote: |
Do not throw stones when you live in a glass building. But, that guy clearly hasnt got a clue about what he´s doing.
As I more or less wrote above, the C45 is actually a very good cam if it is precicely ground. In the right combo it pulls at least as much lower rpm torque as a W120, but still better upper end power. Back in the days it was one of my favourite cams for nippy engines. We used them all the way down to 1600´s. Granted, a 1600 was a little soft in the bottom , but woke up nicely during the rpms. A decently built 1776 with nice stock valved heads etc. can be a joy. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Thu Apr 10, 2025 9:48 am Post subject: Re: Advice on my 1776cc Engine Build |
He suggested 40x35.5 heads on My short block a 90.5 69 crank with a 100 cam. Do a 60deck cut heads to 8.8-9.0 CR. |
This sounds like a terrible engine.
Unported big valve heads, big deck, and a small cam? He would have to flycut the heads a bunch, and then add shims to get back up to the .060" deck height.
-Modok
Posted: Sat Apr 12, 2025 9:12 am Post subject: Re: Advice on my 1776cc Engine Build |
Thanks to all who responded.
No one mentioned the cheater cam. Is it not a good option for my combo? |
ChangeIt Samba Member
Posted: Sat Apr 12, 2025 10:27 am Post subject: Re: Advice on my 1776cc Engine Build |
The 2280 is a good cam. I ran it with rebuilt Kads and a 1 3/8" header and hideaway muffler and liked it in my 1679cc Super Beetle but you can get more out of your engine with the other suggested cam(s) and the recommended higher compression ratio and proper deck height.
I went with the 2280 and 8.25 C.R. knowing that I was eventually going to try a 34PICT3 blow thru turbo. If I was going NA I would shoot for around 9:1 and a bigger cam and better heads as the experts have said. |
Posted: Sat Apr 12, 2025 11:06 am Post subject: Re: Advice on my 1776cc Engine Build |
| Run Flores Run wrote: |
The Cheater cam is 2 full groups down. Not comparable at all. The cheater is a good cam, but for a totally different segment. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Sat Apr 12, 2025 12:45 pm Post subject: Re: Advice on my 1776cc Engine Build |
| Brian_e wrote: |
Brian |
The 40X35.5 heads are 215$ each seems cheap like Empi crap cheap. Stock valve heads are 209$ Plus machine work. Well my bday is next month so after I take the wife to Disneyland for her bday next week.... I'm going to go see Steve Tims for my gift. If I have to wait months fine, I want some bitchen stock valve heads looks like he's the guy Local to me. |
croSSeduP Samba Member
Joined: June 13, 2004 Posts: 1169 Location: Western Washington State
Posted: Sat Apr 12, 2025 1:31 pm Post subject: Re: Advice on my 1776cc Engine Build |
DO NOT use a stock crank in any engine that will see more than 4500 rpm! You will get nasty harmonics and will pound out the case at the center main in short order, especially with using a line bored, used case. My recommendation, besides what you already have:
Counterweighted 69 mm crank, 8-dowelled, lightened flywheel, forged gland nut. There are places (at least there used to be) that would take your crank, check it out, and counterweight it for you.
Engle FK-43
Chromoly or HD aluminum push rods
1.4:1 rockers (CB or the like).
1 1/2" merged header
Performance Workshop Stage 1 heads, CB Super Mag Round Ports (or the like)
Keep CR below 8.5:1 _________________ Please check my '67 sedan project progress!
http://www.thesamba.com/vw/forum/viewtopic.php?t=502253&highlight=
Posted: Sat Apr 12, 2025 2:31 pm Post subject: Re: Advice on my 1776cc Engine Build |
| croSSeduP wrote: |
DO NOT use a stock cam in any engine that will see more than 4500 rpm! You will get nasty harmonics and will pound out the case at the center main in short order, especially with using a line bored, used case.
No offense, but, what a bunch of horsemanure to let out. Those harmonics you refer to has nothing to do with the cam, but are purely crank, rod and piston balance related. That´s two different issues.
As for your rexcommended static compression for the FK43... Well each to his own. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
txoval Samba Member
Joined: January 23, 2004 Posts: 3901 Location: The Woodlands, TX
Posted: Sat Apr 12, 2025 8:47 pm Post subject: Re: Advice on my 1776cc Engine Build |
FK43 is about .540” lift depending on what your rockers end up measuring and 250 at .050.
Probably needs to be between 9-9.5:1 |
Posted: Sun Apr 13, 2025 8:52 pm Post subject: Re: Advice on my 1776cc Engine Build |
| txoval wrote: |
Right. I knew this. Why would that be bad for a 1776 with the limitations mentioned? It seems to me that that cam would have low end snap, and upper end too. I had a 1776 with stock valve ported heads, 1 3/8" header to stock heater boxes, 42 DCNF's and an Engle V-26 cam. It has 252 @ .050", .480" lift at valve w/ 1.4 rockers. That engine was in a true daily driver. It ran like a stock 1600 until you gave it some gas, then it ran like a Jack Russell terrier on speed. Made about 95 hp, but VERY throttle responsive. Power all the way to about 6200 rpm. With less duration and more lift that FK-43 might even be snappier and give better upper end power.
IMHO if you're running pump gas 9:1 CR would be pushing it. I ran that on a 2161 with a Web-Cam 86b. _________________ Please check my '67 sedan project progress!
http://www.thesamba.com/vw/forum/viewtopic.php?t=502253&highlight= |
Posted: Fri May 16, 2025 8:47 am Post subject: Re: Advice on my 1776cc Engine Build |
Hey Brian_e, you mentioned shimming the presuure plate for maximum clamping pressure. I'm in the process of building a similar motor and wondering how you do that and if there are any negative affects? I would like to at least consider it.
Thanks! |
