Bringing a neglected 1974 Superbeetle with A/C back to life
Page: Previous  1, 2, 3, 4
M@DhAtT3R
M@DhAtT3R is offline
PostPosted: Sat Apr 12, 2025 7:20 pm    Post subject: Re: Bringing a neglected 1974 Superbeetle with A/C back to life Reply with quote
next stop, Bu-g-A-Paluza
The things i do may be Stupid, dumb, and you may not understand. I am the M@DHatT3R. this is your only warning. I maynot know jack Sh!T about anything i do but the power of Google compels me.
M@DhAtT3R
PostPosted: Sat Apr 12, 2025 7:28 pm    Post subject: Re: Bringing a neglected 1974 Superbeetle with A/C back to life Reply with quote
https://www.youtube.com/shorts/m9a4AsYvv1M
the end for now.
M@DhAtT3R
PostPosted: Mon Apr 14, 2025 2:31 pm    Post subject: Re: Bringing a neglected 1974 Superbeetle with A/C back to life Reply with quote
Bug-A-Paluza 2025 We Made it! My Fiance in her Bug-A-Paluza car themed outfit. All 5'3 90 lbs of her lol
Video of just getting it home
M@DhAtT3R
PostPosted: Mon Apr 14, 2025 4:55 pm    Post subject: Re: Bringing a neglected 1974 Superbeetle with A/C back to life Reply with quote
It is home now under our carport. It runs fine, but chokes out after a few minutes because the mechanical fuel pumps diaphram failed and not only pumps a little, but dumps fuel into the crankcase so the dipstick is completely full and smells of gas. we will bypass with an electric one and drain and refill the oil. i gave the guy doing restoration a new fuel pump to replace it while he had it, so not the best feeling on that one since he left the old one on. if you ever pull the oil fill cap and see foam and a rev sends a stream out 5 feet, you need a new fuel pump and an oil change.
Rome
Rome is offline
PostPosted: Tue Apr 15, 2025 3:04 pm    Post subject: Re: Bringing a neglected 1974 Superbeetle with A/C back to life Reply with quote
Great going with saving the Super, and on it surviving its first trip!
M@DhAtT3R
PostPosted: Fri May 02, 2025 5:26 am    Post subject: Re: Bringing a neglected 1974 Superbeetle with A/C back to life Reply with quote
Well, now the motor has developed a knock and has to come out. The fun never ends lol Rolling Eyes
M@DhAtT3R
PostPosted: Fri May 09, 2025 5:03 pm    Post subject: Re: Bringing a neglected 1974 Superbeetle with A/C back to life Reply with quote
so a "check ball" that looks like a bb and is part of the NEW carb on accelerator pump, got sucked into intake and was being slammed between piston and head, sounding like a knock. i sh$t you not. now getting new pistons, heads, pushrod tubes, etc. going 1641 now.
Rome
Rome is offline
PostPosted: Fri May 09, 2025 10:39 pm    Post subject: Re: Bringing a neglected 1974 Superbeetle with A/C back to life Reply with quote
Ouch! What a shame that your engine only had a few weeks of running time so far. Did the brass bent discharge tube for the accelerator pump passage pop out of its pressed-in fitting so that the check ball was pumped out? If so, where is that brass tube?
2 years ago I also had a small item travel down into the combustion chamber; was larger than a BB and it banged up the #2 head's chamber "ceiling" as well as the top of the piston. Was on a German-made Solex carb which I rebuilt a few years before, together with a stock oil-bath air cleaner. I could not see anything out of place on the carb. The metal "pellet" had rounded ends probably due to the pounding, and was approx. 3/16" long. I only drove about 2 miles before I turned off the engine as I reached my home driveway. I've repaired the damage but not yet reassembled the engine (am very lazy). I really want to get to it this month, since I miss driving my '77 Beetle.
M@DhAtT3R
PostPosted: Tue May 13, 2025 4:14 am    Post subject: Re: Bringing a neglected 1974 Superbeetle with A/C back to life Reply with quote
Not sure, as i wasnt the one doing the work when it happened. It now has had a top end rebuild, Cylinders, pistons, heads, rings, and a sportier exhaust that sounds mean as hell on it, now 1641 cc. Picked it up yesterday and drove it home and then later to the gas station and back. I asked the guy doing the work, but he kept swearing up and down that that couldnt be it, and told me i still need a new carb. I said So i bought a new carb and put on it, paid you for a carb you put on it, and now say i still need to purchase a third?(didnt make sense to me) He backtracked and finally said he would buy one and put it on. feels good in 1st and second, although lags on bottom of third until the RPM's get up a bit.
M@DhAtT3R
PostPosted: Tue May 13, 2025 4:18 am    Post subject: Re: Bringing a neglected 1974 Superbeetle with A/C back to life Reply with quote
This is it now.
https://www.facebook.com/share/p/15F6N5QBKv/
M@DhAtT3R
PostPosted: Sat May 17, 2025 11:05 am    Post subject: Re: Bringing a neglected 1974 Superbeetle with A/C back to life Reply with quote
as she sits today. Just after a drive. Waiting on the next one....
Page 4 of 4
