RufusRockwell Samba Member
Posted: Mon Apr 14, 2025 9:39 am Post subject: Fuel pump sounds like a blender! |
Decided to replace the old white cube filter with the Go Westy fuel filter kit and thought I might as well replace the old (perfectly quiet and functioning) fuel pump with a new Bosch. When I get the van back from the shop the new fuel pump sounds like an old radio trying to find a station. The shop tells me these new pumps are just inherently noisy. I'm thinking that no Vanagon owner with an ounce of respect would put up with this kind of noise!
So, thinking I have a defective pump, I order a "last of the real German made Bosch" pumps and figure I'll swap it out knowing that this pump will for sure be quiet. To my disappointment this one is even louder! Now it sounds like a blender in the back seat. How can this be?
Either I got 2 defective pumps...?
They are supposed to sound like this...? (can't imagine it's a normal sound)
Or, It's something to do with the new filter set up, hoses, etc?
Either way, it's a classic case of "If it aint broke, don't fix it".
Any ideas appreciated.
85 with Subaru 2.2. |
khughes Samba Member
Joined: July 13, 2013 Posts: 920 Location: Phoenix AZ
Posted: Mon Apr 14, 2025 10:32 am Post subject: Re: Fuel pump sounds like a blender! |
| RufusRockwell wrote: |
Not familiar with the Go Westy fuel filter kit, but sounds like your pump is cavitating due to suction side restriction. Take the pre-pump filter out and see if that quiets it down. _________________ '86 Westy FAS GenV Turbo (Marvin) |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12424 Location: Santa Cruz, CA
Posted: Mon Apr 14, 2025 12:53 pm Post subject: Re: Fuel pump sounds like a blender! |
Probably a dumb question but are you still using the rubber isolator mounts?
It has to be quiet and have to stick my head out of the window to even have a chance to hear the fuel pump on any of my vans, what you are experiencing isn't remotely normal. |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3462 Location: OR & CA (Oregon/California)
Posted: Mon Apr 14, 2025 1:21 pm Post subject: Re: Fuel pump sounds like a blender! |
| Fuel pump usually very quiet... if it's noisy.. as mentioned it's cavitating (running empty or very low fuel). Remove the IN hose to see if the is fuel coming out of the hose from the tank side... |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23533 Location: Oklahoma City
Posted: Mon Apr 14, 2025 2:48 pm Post subject: Re: Fuel pump sounds like a blender! |
Is this the fuel filter you bought?
https://gowesty.com/products/gowesty-vanagon-fuel-...6702500005
And....did you put this in-line....in the same place where the original little white cube filter was (meaning BETWEEN the fuel tank and the pump)?
If so.....that is the problem.
That fuel filter is a digifant 1 and 2 UPSTREAM high pressure, high volume fuel filter. It goes AFTER the fuel pump between the pump and the engine.
The information from Go Westy at that link even states that it goes AFTER the filter.
It is an excellent filter and is a nearly perfect upgrade for VW type 3 and 4 sedan engines with D-jet or L-jet and VW type 2 engines with L-jet....and any number of vehicles running digifant/digijet or digifant 2 or motronic.
The difference is that it is designed internally to be on the high pressure side. It does not present a restriction due to its large size and volume. It has probably 10X the surface area as the little cube filters.....but it's filtration media is still too restrictive to put on the inlet side of a two port pump.
Ray |
zululep Samba Member
Joined: August 13, 2016 Posts: 58 Location: Portland, ME
Posted: Mon Apr 14, 2025 5:36 pm Post subject: Re: Fuel pump sounds like a blender! |
Have you tried putting your old "perfectly quiet and functioning" fuel pump back in and see how it sounds? And, as mentioned above, check that the shop didn't remove the isolator mounts. _________________ 1984 Westfalia with Bostig Zetec |
zerotofifty Samba Member
Posted: Mon Apr 14, 2025 7:14 pm Post subject: Re: Fuel pump sounds like a blender! |
if the pump is hooked up backwards, it may make a lot more noise than if correct. backwards hooked up hose, or even reversed electric connections might be the issue. _________________ Sorry About That Chief.
Give Peace a Chance.
Words to live by. |
Posted: Mon Apr 14, 2025 7:17 pm Post subject: Re: Fuel pump sounds like a blender! |
The original pump would have needed an adapter to attached to the feed hose from the tank. No clue what pump you actually have, but if it pumps too much fuel it might cavitate badly. The original already pumped far more fuel than the engine needs and some people have added a resister in-line with the pump to slow the pump down to stop the cavitating.
This is my stock pump hooked to the later model filter. You can see that the pump has a much larger hose attached to it's inlet than your pump probably does. You can't see my adapter in the photo, but its just made from fittings bought from the local hardware store. |
Posted: Mon Apr 14, 2025 9:18 pm Post subject: Re: Fuel pump sounds like a blender! |
| Wildthings wrote: |
Wrong kind of hose clamp is shown. use injection rated clamps, the perforated clamps can loosen do to extrusion of the hose through the perforations in the clamp's band. This is most serious an issue with high pressures such as in injection systems verse the low pressure of carb systems. _________________ Sorry About That Chief.
Words to live by. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 24472 Location: NYC/Upstate/ROW
Posted: Tue Apr 15, 2025 2:02 am Post subject: Re: Fuel pump sounds like a blender! |
| zerotofifty wrote: |
| Wildthings wrote: |
Wrong kind of hose clamp is shown. use injection rated clamps, the perforated clamps can loosen do to extrusion of the hose through the perforations in the clamp's band. This is most serious an issue with high pressures such as in injection systems verse the low pressure of carb systems. |
Take heed of the above , sound advice indeed. _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
Posted: Tue Apr 15, 2025 8:15 am Post subject: Re: Fuel pump sounds like a blender! |
| Wildthings wrote: |
Wow, you would think it would have caused problems over the last 17 years since it was put on there. Actually that clamp got replaced shortly after the picture was taken, though there is still a cheese grater clamp on the suction hose at the tank which has never given any problems as there is no reason to tighten it all that tight. |
82westyrabbit Samba Member
Posted: Tue Apr 15, 2025 4:14 pm Post subject: Re: Fuel pump sounds like a blender! |
| Part of the GoWesty kit is that you get rid of the little square pre-filter. I find a lot of times the fuel tank is going bad and the sediment from inside of the tank without the pre-filter will ruin a new or an old fuel pump in short order. There is a screen that there is no way to clean inside of the fuel pump. Just so this is clear, there is no way to get to this screen without ruining the pump. If it were me, the first thing I would do is flush fuel through the pump backwards just in case you got sediment from a rusty tank caught in that screen. Then I would put a square filter back in before the fuel pump and see what happens. That might be all you have to do to quiet it down. Can you get your original pump back and reinstall it? John |
Posted: Tue Apr 15, 2025 5:17 pm Post subject: Re: Fuel pump sounds like a blender! |
| 82westyrabbit wrote: |
The answer is do not use the square filter for a "pre-filter". Most of these are 10-12 micron fuel filters.
Pre-filters like the sock filters put inside of many acvw fuel tanks are 25-50 microns and some as large as 100 microns. The pre-filter is just there fo keep sand out. They are better termed as "fuel strainers".
You can buy simple inline fuel strainers that have very low resistance to flow and typically are 25+ micron filters. They use them in diesels all the time. This way you catch the rocks before they ever reach any strainer in the pump (which many modern pumps do not have).
Strainer before the pump....pump to the large volume, high pressure digifant filter that Gowesty sells.
If you need part numbers for cheap disposable diesel type pre-filters, let me know. I think I have a list somewhere.
Ray |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2687 Location: Southeast Kentucky
Posted: Tue Apr 15, 2025 8:10 pm Post subject: Re: Fuel pump sounds like a blender! |
Subscribed for the joy...  _________________ '84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful. |
Posted: Wed Apr 16, 2025 1:58 pm Post subject: Re: Fuel pump sounds like a blender! |
| raygreenwood wrote: |
Pre-filters like the sock filters put inside of many acvw fuel tanks are 25-50 microns and some as large as 100 microns. The pre-filter is just there fo keep sand out. They are better termed as "fuel strainers". |
We call them "rocks and alligators" filters in my realm
But another option is to stick with finer pore size and increase the filter element surface area. Will still clog (I mean, it IS a filter) but as the OP has noticed there's a built in "warning system". Certainly the best for *maximum* pump protection. 40 micron is about the limit of visibility, so as you go further above that you start getting into material that may start abrading pump components. _________________ '86 Westy FAS GenV Turbo (Marvin) |
bobbyblack  Samba Member
Joined: May 21, 2015 Posts: 4710 Location: United States, Iowa
Posted: Wed Apr 16, 2025 2:09 pm Post subject: Re: Fuel pump sounds like a blender! |
I had posted some 'this bobbyblack guy is nuts' stuff and deleted it early enough that perhaps nobody looked...
BUT, I have to go at it again, and here is the basics of the original post I did;
Clamp off the fuel tank outlet.
take fuel pump out. With some fuel hose for both sides, and a small container of gas, and some way of applying power to the pump, see what happens with the pump while it is not hooked up to the bus EFI. There is also the option of reversing the polarity, the pump will spin the other way. I've done this both on purpose, and by accident. A couple seconds of running the pump backwards did not harm my pump. It did expel some debris.
I do understand that you would normally take your rig to a shop for them to do the work, but they may decline. I can't take my Vanagons to any shops within 2 hours drive anymore, so I get to do my own work.
-bobby _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Wed Apr 16, 2025 3:07 pm Post subject: Re: Fuel pump sounds like a blender! |
| khughes wrote: |
But another option is to stick with finer pore size and increase the filter element surface area. Will still clog (I mean, it IS a filter) but as the OP has noticed there's a built in "warning system". Certainly the best for *maximum* pump protection. 40 micron is about the limit of visibility, so as you go further above that you start getting into material that may start abrading pump components. |
No....really.
A couple of points:
1. you cannot use the Go westy digifant filter before the pump. That big metal filter is designed to be on the pressure side. That is why it is so big so the restriction is low.
2. You do not want "pre-filter" mesh and finer than about 150 to 200 wires/threads per inch. It's just for debris large enough to do damage to the pump.
3. The original cube filter is already a restriction on the pump inlet....but L-jet and digifant got away with it from the factory....ONLY.....because there was no upstream restriction from any other filters.
So you need just a pre-strainer on the inlet side....not an actual filter. The factory work filters that came in many acvw tanks would be fine. A diesel pre-strainer would be fine....but nothing that filters below/smaller than about 25 micron which is right at 0.001". In fact, the vast majority of pre-strainers that do not go through a filter before they hit the pump are about 50 microns.
Those that are designed to go from tank, through a sock or bag type pre-filter/pre-strainer before going into a a fine filter are more like 75-100 microns.
The upstream fuel filter that is 10-12 microns will take care of the rest.
Ray |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10316 Location: Mt Lemmon, AZ
Obviously there's no love for the square plastic pre-filter but I'll note in passing that it's what's been used on my van for 40+ years without an issue.
Maybe I've been lucky or careful in choice of gas stations (though often I have to go with whatever is on offer as I travel). I am still running the original pump and tank.
I do always carry a spare filter and did once have to replace it along the side of the road after a fill-up at Love's in Longmont CO.
Possibly it helps that the van is also my daily driver so it never sits for long. |
Posted: Wed Apr 16, 2025 5:29 pm Post subject: Re: Fuel pump sounds like a blender! |
Thanks for the replies.
To answer some of the questions...
The white cube filter has been removed and the new canister filter (yes, the big grey one from Go Westy) is after the pump.
I can't put my original pump back in because I neglected to ask the shop for it back, and by the time I did, they had tossed it. (lesson learned!)
The kit also came with a hose bit that goes from the skinny one coming out of the tank to a larger one that fits the pump inlet.
Since both new pumps are making noise, it makes sense that it would be cavitation due to too much fuel going through...although I don't quite understand why this would be if this is a common pump/filter configuration.
I like the resistor idea for the pump wire. What would be the best one to get?
At this point my plan is to take it back to my local shop and have them help figure it out. |
Posted: Wed Apr 16, 2025 6:09 pm Post subject: Re: Fuel pump sounds like a blender! |
Below are photos of the internal fuel screen assembly inside the fuel tank. This was from an Air-cool era Vanagon.
Below, you can see where it is located at the center bottom of the tank. The white round box to the right is where the returning fuel is dumped. It snaps onto the white connector there on the other side near the pickup pipe (the unit is flipped). I suppose the returning fuel goes through that round box to reduce air bubbles during a low fuel level. The black pickup tube snaps onto a connector under the edge of the strainer on the other side (it is out of view). Look at the last photo below of the stripped down plate. In that photo, you can see the location of the connector for the pickup tube. Hope this makes sense.
Below, is the fuel pickup assembly lying on the work bench. Notice the screen mess goes all the way around and is also on the top.
As stated above, the pic below shows the bottom plate, which is flipped, with the strainer removed. Near the center where the strainer snaps on, you can see the connection point for the fuel pickup tube, the black pipe. The snap connector further to the outside perimeter is where the round box snaps on for the returning fuel. And, that plate is tack welded to the concave bottom and sealed around the perimeter with some sort of sealant. Thus, all gasoline goes thru the mess screen as well as water to the very bottom of the tank ...
I hope this is helpful with the discussion. _________________ '84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
