Bug VS bus Torsion housing to swingaxle centerlines
trilogymac
trilogymac is offline
PostPosted: Wed Apr 09, 2025 8:22 am    Post subject: Bug VS bus Torsion housing to swingaxle centerlines Reply with quote
Im building a set of adapters to install RGB,s in my bug. Are the torsion housing to axle centerlines the same?
Thanks!!
Bill
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Sun Apr 13, 2025 8:00 pm    Post subject: Re: Bug VS bus Torsion housing to swingaxle centerlines Reply with quote
Yes they are the same distance apart. If you just making a J type of block to attach reduction box to spring plate, you will actually need to cut off end of spring plate where it would slip around Bug axle tube.
Find the original Baja Prepping VW Sedans & Dune Buggies by Bob Waar. My copy was printed in 1970.
The book has pictures of what you want to do.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
BFB
BFB is offline
PostPosted: Mon Apr 14, 2025 5:50 am    Post subject: Re: Bug VS bus Torsion housing to swingaxle centerlines Reply with quote
or just go ahead and build a 4 link for it so you can eliminate the anti- squat now vs. later
Most experts aren't.
trilogymac
PostPosted: Tue Apr 15, 2025 4:40 am    Post subject: Re: Bug VS bus Torsion housing to swingaxle centerlines Reply with quote
Thank ya'll very much!
Best,
Bill
Dale M.
Dale M. is offline
PostPosted: Tue Apr 15, 2025 7:17 am    Post subject: Re: Bug VS bus Torsion housing to swingaxle centerlines Reply with quote
Don't forget to flip the ring gear in transaxle....
trilogymac
PostPosted: Tue Apr 15, 2025 8:25 am    Post subject: Re: Bug VS bus Torsion housing to swingaxle centerlines Reply with quote
I have a rebuild 1964 B&D transmission (MI) that has never been installed. I'm going to take the tranny and the RGB parts to them and have them inspect and assemble everything. I think I need a different nose cone to fit the 64 in my 57 as well.
Thanks for all the help.
Thanks,
Bill
