my3bugs Samba Member
Joined: June 18, 2003 Posts: 964 Location: Moreno Valley
Posted: Tue Apr 15, 2025 12:33 pm Post subject: Re: Squeaky gauges! Any solutions? |
| you have to carefully open up the chrome bezel most of the way around till it comes off . i have used a small screwdriver to get started , then one of those tools to open paint cans " kinda hook shaped " is what i used to open em for cleaning .... |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11613 Location: Oregon
Posted: Tue Apr 15, 2025 1:04 pm Post subject: Re: Squeaky gauges! Any solutions? |
When you remove the glass as described above.
Be very careful with the needle. One look at it the wrong way, and it will break. Ask me how I know.  _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Mrorangecrush77 Samba Member
Posted: Tue Apr 15, 2025 1:27 pm Post subject: Re: Squeaky gauges! Any solutions? |
| 67rustavenger wrote: |
Be very careful with the needle. One look at it the wrong way, and it will break. Ask me how I know.  |
I learned that on my fuel gauge. Very delicate touch.
Currently working on it now, what does everyone recommend to lubccate everything? |
Posted: Tue Apr 15, 2025 1:30 pm Post subject: Re: Squeaky gauges! Any solutions? |
What is a safe cleaner as well?
Last cleaner I used on my fuel gauge messed with the background coloring. Trying to avoid that |
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 2203 Location: Wichita, KS
Posted: Wed Apr 16, 2025 11:51 am Post subject: Re: Squeaky gauges! Any solutions? |
Survey says…..it works!
I very liberally applied grease everywhere grease should be, the old stuff was comparable to tar, no wonder it was having issues.
Secondly, a Square bit to drive screws works GREAT to test the speedo hole. It fit perfect and made it a bit easier to see if the gauge was making noice.
I used some lithium grease and sprayed it internally and I think I should be good to go for a while, a quick test drive and it worked fine!
