Squeaky gauges! Any solutions?
Page: Previous  1, 2
my3bugs
my3bugs is offline
PostPosted: Tue Apr 15, 2025 12:33 pm    Post subject: Re: Squeaky gauges! Any solutions? Reply with quote
you have to carefully open up the chrome bezel most of the way around till it comes off . i have used a small screwdriver to get started , then one of those tools to open paint cans " kinda hook shaped " is what i used to open em for cleaning ....
67rustavenger
67rustavenger is offline
PostPosted: Tue Apr 15, 2025 1:04 pm    Post subject: Re: Squeaky gauges! Any solutions? Reply with quote
When you remove the glass as described above.
Be very careful with the needle. One look at it the wrong way, and it will break. Ask me how I know. Shocked
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Mrorangecrush77
Mrorangecrush77 is offline
PostPosted: Tue Apr 15, 2025 1:27 pm    Post subject: Re: Squeaky gauges! Any solutions? Reply with quote
I learned that on my fuel gauge. Very delicate touch.
Currently working on it now, what does everyone recommend to lubccate everything?
Mrorangecrush77
PostPosted: Tue Apr 15, 2025 1:30 pm    Post subject: Re: Squeaky gauges! Any solutions? Reply with quote
What is a safe cleaner as well?
Last cleaner I used on my fuel gauge messed with the background coloring. Trying to avoid that
baldessariclan
baldessariclan is offline
PostPosted: Tue Apr 15, 2025 1:45 pm    Post subject: Re: Squeaky gauges! Any solutions? Reply with quote
Good job! Since you've got it out and apart, you would probably benefit from reading through the following speedometer rebuild threads -- lots of good information and pointers in these!:
https://www.thesamba.com/vw/forum/viewtopic.php?t=327535&
https://www.thesamba.com/vw/forum/viewtopic.php?t=...peedometer
Mrorangecrush77
PostPosted: Wed Apr 16, 2025 11:51 am    Post subject: Re: Squeaky gauges! Any solutions? Reply with quote
Survey says…..it works!
I very liberally applied grease everywhere grease should be, the old stuff was comparable to tar, no wonder it was having issues.
Secondly, a Square bit to drive screws works GREAT to test the speedo hole. It fit perfect and made it a bit easier to see if the gauge was making noice.
I used some lithium grease and sprayed it internally and I think I should be good to go for a while, a quick test drive and it worked fine!
Page: Previous  1, 2
Page 2 of 2
