CV drive flange caps worn, raised van, axles shorter
Page: Previous  1, 2
Sodo
Sodo is offline
PostPosted: Wed Sep 11, 2024 1:23 pm    Post subject: Re: CV drive flange caps worn, raised van, axles shorter Reply with quote
hardway wrote:
I have seen this more than once. So far the common factor has been Chinese axles. What is happening is that as the axle rotates the shaft jumps back and forth. You can hear the axle striking the drive flanges while driving. With the bus on a rack you can watch the axle moving in and out when rotating the wheel.
The root cause is not the length of the axle. It is something to do with the joints that causes the plunging of the shaft.
Length of the axle may set the alignment
between the inner star & outer race
in the alternating V groove pattern of the CV.
It's feasible that the axle can be flung in&out by the V-pattern if axle length places the inner star NOT aligned with the outer race.
This alignment will change on a lifted van similar to axle length.
You can't inpect star & outer alignment because of the boots and the grease.
I read sometimes about axles knocking only when turning.
When the van leans (like around a curve) the R&L suspensions compress & raise and the 'plunge position' changes.
Maybe to a position that "happens" to fling the axle in and out.
And if you have really springy boots.
'87 Tintop, EJ25, cooled filtered (original) gearbox
....KTMs, GasGas, SPOT mtb
All Vanagons should do this:
Add direct starter-to-chassis cable THEN delete ground strap at front transaxle mount.
The best time to do this mod was in 2010. The second best time is TODAY.
If your starter is slow, this is MORE important.
JEL91Westy
JEL91Westy is offline
PostPosted: Sun Apr 06, 2025 1:43 pm    Post subject: Re: CV drive flange caps worn, raised van, axles shorter Reply with quote
Reviving this as I have the exact same problem. Not sure of the manufacture of the axle, but I believe the last time it was replaced, maybe 5k ago, they installed an entire axle assembly. The inner CV doesn’t look worn that bad and I have not inspected the outer one yet, but suspected I was dealing with something else after seeing the damaged cap. I do know that this axle is noticeably thinner than the one on the other side if that means anything.
At first I only noticed the sound when turning left, but now it is anytime the joint is loaded with drive torque.
Vanis - wondering if you ever determined the cause?
91 Westy
85 911
vanis13
vanis13 is online now
PostPosted: Sun Apr 06, 2025 2:04 pm    Post subject: Re: CV drive flange caps worn, raised van, axles shorter Reply with quote
Haven't....next step for several reasons higher than this one, I'm going to subaru automatic transmission which will take different axles and won't have this c(r)ap..
JEL91Westy
PostPosted: Sun Apr 06, 2025 4:11 pm    Post subject: Re: CV drive flange caps worn, raised van, axles shorter Reply with quote
Vanis- Thanks for the response, but that isn’t an option. I need to try and figure it out. Other thoughts or suggestions?
May just buy a new axle with German CVs and hope that solves it.
91 Westy
85 911
vanis13
PostPosted: Mon Apr 07, 2025 4:12 am    Post subject: Re: CV drive flange caps worn, raised van, axles shorter Reply with quote
Let us know if that new axle resolves it or not, and I either case, let us know if the old axle has any id markings so we (try to) know what it might be and what brand/etc the new one is and if it solves it.
4Gears4Tires
4Gears4Tires is offline
PostPosted: Mon Apr 07, 2025 4:49 am    Post subject: Re: CV drive flange caps worn, raised van, axles shorter Reply with quote
If you're determined to run Chinese axles, they are certainly cheap enough to grind the ends down a bit. Has anyone followed Rancho's advice yet? Take off a sixteenth or an eighth?
MarkWard
MarkWard is offline
PostPosted: Mon Apr 07, 2025 6:27 am    Post subject: Re: CV drive flange caps worn, raised van, axles shorter Reply with quote
First step, get some good used OE axles. Know there are early ones that are longer than the later ones, so make sure they are correct for your van.
Aftermarket complete axles are for when you are broke down somewhere. With proper maintenance CVs should not leave you stranded. Of course changing ride height, power plant etc could introduce problems.
A CV shaft on a loaded suspension should move in and out an inch or so. They actually depend on CV boot position to hold them “centered”. Joints of unequal wear can also cause the shaft to ride off center. Grinding the end, might solve the cap issue, but you really want the CV joint centered on itself.
broncoisl
broncoisl is offline
PostPosted: Thu Apr 17, 2025 5:40 am    Post subject: Re: CV drive flange caps worn, raised van, axles shorter Reply with quote
I have a 1984 Vanagon Westfalia 4 speed that I’m restoring. The left axle is damaged and destroyed the flange cap. The right side is fine. As far as I know the axles are original.But I replaced the cv joints a few years ago.
The van has a Subaru engine with bell housing and bracket from RJES (UK). The engine bracket is bolted to original holes in the van and uses the Subaru rubber engine mounts.
As the trailing arms and springs are not in the car at the moment I measured from top center of the drive flanges on the gearbox to center of the bump stops. Left side 418 mm right side 430 mm Difference 12 mm.
What are your thoughts on this? Should the gearbox be centred in the van? Is it possible that the engine (pulley end) with gearbox is tilted to the left and causing this to happen?
The axles are same length so in my mind it’s logical that the gearbox should be dead center.
Does someone happen to know or have measurements from frame rails left and right to center of the crankshaft pulley bolt on the engine? On any engine with 4 speed gearbox. Possibly I can adjust the position of the engine on the mounts.
Or whats the best way to measure if the engine is straight in the car?
Damaged axle:
MarkWard
MarkWard is offline
PostPosted: Thu Apr 17, 2025 8:48 am    Post subject: Re: CV drive flange caps worn, raised van, axles shorter Reply with quote
Ouch, that isn't right. I'm not familiar with your install, but the vanagon 2wd chassis had two sets of transmission bolt locations. I think Early vans used the offset holes. So, yes you might have the transmission in the wrong holes. Same bracket pattern is used for both sets.
I would expect the measurements side to side to be pretty close to the same and it's obvious the one CV is lathing into the drive flange. Best to figure out where the problem or problems are.
broncoisl
PostPosted: Fri Apr 18, 2025 9:29 am    Post subject: Re: CV drive flange caps worn, raised van, axles shorter Reply with quote
Thanks I’m waiting for new trailing arms. When I have installed them I will try to measure and center everything up. So this will not happen again.
vanis13
PostPosted: Fri Apr 18, 2025 9:37 am    Post subject: Re: CV drive flange caps worn, raised van, axles shorter Reply with quote
FWIW - my problem side looked like the last pic above with the shaft rounded over ....measured and distances to center were within 1/16" of each other :-/
broncoisl
PostPosted: Fri Apr 18, 2025 11:31 am    Post subject: Re: CV drive flange caps worn, raised van, axles shorter Reply with quote
Thanks, did you ever figure out what caused this? I’m thinking if one of the cv joints somehow got stuck.
When I think of it I remember hearing a screaming noise from the rear when turning after installing the Subaru engine. I thought it was the brake drum rubbing on the backing plate but found nothing. The sound then stopped coming.
vanis13
PostPosted: Fri Apr 18, 2025 11:36 am    Post subject: Re: CV drive flange caps worn, raised van, axles shorter Reply with quote
What you quoted to Mark, I wrote.
Didn't ever figure it out. Eventually calmed down but still occured ....my next solution is a Subaru auto transaxle, well see how it does on that
broncoisl
PostPosted: Sat May 10, 2025 3:01 am    Post subject: Re: CV drive flange caps worn, raised van, axles shorter Reply with quote
Got my new “cheap” axles they look good.
Decided to clean up some surface rust and paint before I install them.
Had to clock one of the axle, otherwise everything looks good and the length is the same as the old axles.
Here are some pictures:
Page: Previous  1, 2
Page 2 of 2
