ohiovw Samba Member
Posted: Fri Apr 25, 2025 9:09 am Post subject: 69 tin top Westfalia wood headliner template needed |
I’m doing my research and see that my bus originally had a wooden interior roof panel. It came without any roof interior so I’m trying to decide what to put up there. Would anyone have the dimensions of the wood panel with dimensions for appropriate cut outs etc? _________________ -Will
1969 bay window
build thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=802451&highlight= |
Kudagra Samba Member
Joined: March 22, 2007 Posts: 133 Location: Baldwin City KS. Just a wee bit South of KC
Posted: Tue May 20, 2025 3:55 pm Post subject: Re: 69 tin top Westfalia wood headliner template needed |
have a 70 but only the one above the driver is out right now. Im not an engineer so my measurements would be welder measurements not carpenter.
But I will say see if you have the little metal channels running down the sides of the bus above the windows. Thats what keep mine in. If you dont have that you probably dont have wood panels originally.
But they could probably easily be adapted to work.
I wont be making my new panels till my welding is done...and this was a Nebraska bus...so basically the lower 6" is bad...and Im dealing with the slider rocker at the moment.
I
_________________ Everything burns if you get it hot enough. |
brass gears Samba Member
Joined: October 21, 2013 Posts: 99 Location: Calgary,AB
Posted: Tue May 20, 2025 7:07 pm Post subject: Re: 69 tin top Westfalia wood headliner template needed |
I found this a while ago and book marked it
Although it’s for a pop top, it might be useful for some measurements and instruction for how these install.
Bus looks good. Enjoy, _________________ ‘70 transporter
‘ 64 beetle |
ohiovw Samba Member
W1K1 Samba Member
Joined: March 04, 2004 Posts: 5293 Location: Southern AB
Posted: Mon May 26, 2025 10:02 am Post subject: Re: 69 tin top Westfalia wood headliner template needed |
ohiovw wrote: |
Some of those H channel strips is what I need for my headliner. |
that's easy: https://www.mcmaster.com/products/aluminum-h-channels/ _________________ 1973 super 2110cc
1965 squareback 1500E-sold
1971 bay window westy- EJ2.5 subi swap |
