kourt Samba Member
Joined: August 13, 2013 Posts: 2417 Location: Austin, TX
Posted: Tue Apr 22, 2025 11:26 am Post subject: Re: DC to DC charger install - does this work? |
Yes, that's it.
Kourt |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2956 Location: North Carolina
Posted: Tue Apr 22, 2025 11:36 am Post subject: Re: DC to DC charger install - does this work? |
Another difference between early and late vans is that there is no stud on the earlier vans- it's just a splice-type junction. Look for this on the purple wires behind the mangatek.
The stud is a definite improvement and what I changed my van to.
Just putting this here for anybody who looks at this helpful thread in the future, but has an early model van. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
wavefarer Samba Member
Joined: August 17, 2024 Posts: 12 Location: Tucson, AZ
Posted: Tue Apr 22, 2025 12:07 pm Post subject: Re: DC to DC charger install - does this work? |
I'm heading back out the van to put the VOM to that stud and determine which wire is from battery/alternator. Has anybody tried removing the furnace without taking off the back panel with fuses and water sprayer? It looks like it might barely slip out and would save time as removing and reinstalling that back panel was a pain.
THank you to all again. _________________ 1999 VW Winnebago Campervan |
kourt Samba Member
Posted: Tue Apr 22, 2025 1:08 pm Post subject: Re: DC to DC charger install - does this work? |
Yes, on my 2001 EVC, the furnace will slip out of the steel box housing, as long as you have properly removed the propane line and wiring harness. It's not as hard as it sounds, but you need to properly test the propane line once you reconnect it.
Once you get the furnace out, you can remove the box as well. It's a lot of work, either way.
kourt
Posted: Tue Apr 22, 2025 1:29 pm Post subject: Re: DC to DC charger install - does this work? |
Thanks kourt. I am on it!
You mention properly test the propane. I have used soapy water solution on fitting to check for leaks. Is there a better method? _________________ 1999 VW Winnebago Campervan |
kourt Samba Member
Posted: Tue Apr 22, 2025 2:04 pm Post subject: Re: DC to DC charger install - does this work? |
Soapy water is fine for you, me, and thousands of plumbers.
Kourt |
dsh1705  Samba Member
Joined: June 11, 2014 Posts: 136 Location: Seattle, WA
Posted: Tue Apr 22, 2025 7:51 pm Post subject: ! |
| Quote: |
| You mention properly test the propane. I have used soapy water solution on fitting to check for leaks. Is there a better method? |
Yes! Soap test is pretty basic - this thing rocks. I have used it to track leaks down for neighbors gas plumbing, as well as my own. Allows you to test for leaks where a soup test would not be practical.
https://www.amazon.com/dp/B000HHTY7Q?th=1
There are other similar tools out there, as well. This is just the one I have used for the last 15 years.. _________________ David
1705.net
95 EVC
ACU,098 |
Posted: Tue Apr 22, 2025 7:57 pm Post subject: Re: DC to DC charger install - does this work? |
| Quote: |
| Has anybody tried removing the furnace without taking off the back panel with fuses and water sprayer? |
| Quote: |
Easily done. I have also made it a bit easier by cutting the plastic shroud that surrounds the heater. The cut is just before it heads behind the seat.
1705.net
95 EVC
ACU,098 |
Posted: Wed Apr 23, 2025 7:37 pm Post subject: Re: DC to DC charger install - does this work? |
dsh1705 Very clever upgrade for quickly getting to that area.
With everyone's help and encouragement, I was easily able to get the furnace out without removing the back. It went very smoothly.
I removed all the wires from the isolation post and moved all but the wire from alternator to the new bus bar. I then mounted the Victron DC Charger to the floor on driver side rear under where the isolator post was and commented the wire from alternator to DC charger input (+) and ran DC charger Output (+) to the bus bar that included the wire to a 40 Amp breaker and house battery.
Where I had planned to mount the DC charger in the passenger side battery compartment I left blank for next years project of Victron solar.
It all works as it should. I really appreciate this thread and others like it for helping me choose gear and think through the issues to complete this project.
Now to put the back seat back in and get her loaded up for a California beach vacation.
Here are a few pictures of my upgrade.
krusovice Samba Member
Joined: October 12, 2008 Posts: 327 Location: Duluth, MN
Posted: Thu Apr 24, 2025 6:12 am Post subject: Re: DC to DC charger install - does this work? |
Looks really nice. I'm going to have to really clean mine up. _________________ 2001 Eurovan Camper
Sold, but not forgotten:
1984 Vanagon 1.9/4 speed |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2800 Location: Ocean Beach - San Diego
Posted: Thu Apr 24, 2025 8:22 am Post subject: Re: DC to DC charger install - does this work? |
I am fascinated to read all of this discussion. When its comes to electricity my skills & knowledge are really limited.
I am tired of replacing Group 31 Deep Cycle batteries every 18-24 months. A lithium battery is on the horizon.
In another post on this topic (either here on on FB) another person put the Victron DC-DC charger in the engine compartment next to the starting battery.
He left the 3-way Ford relay where it was.
He used the existing wire from the relay to the DC-DC and then to the rear.
He did not replace the Magnatek, at least yet.
No new shunts.
No new wires from front to back.
No bus bars.
No new fuses.
He kept it really simple.
Any reason that would not work? I understand its might not be "as good", but would it be "good enough". _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper.
People deserve the Government they voted for. |
Posted: Thu Apr 24, 2025 9:12 am Post subject: Re: DC to DC charger install - does this work? |
I thought about that but didn't want to put the DC/DC charger under the hood.
Also, the Magnatec won't charge a lithium battery. If you leave it there you can't plug it in. (Well, I guess they kind of charge lithium, but not correctly or completely and why spend the money on a nice battery if you can't charge it completely.) _________________ 2001 Eurovan Camper
Posted: Thu Apr 24, 2025 9:45 am Post subject: Re: DC to DC charger install - does this work? |
I suppose you could put the DC/DC charger in the engine compartment and avoid some of the extra bits. If you are going to go LiFePo4 battery then you will need a battery state of charge monitor or you will not know how much juice you have left. Also, if you want to charge from your home then a LiFePo4 compatible AC/DC charge will be required to properly charge. I charged the lifepo4 battery with the magnatek for awhile but it never got fully charged and who knows if I messed up the battery. The bus bars and fuses just make things tidier and easier to follow, the battery switch is just for convenience and safety, and the shunt is part of battery monitor.
I will see how it all works this summer and after that I will make any adjustments and maybe upgrade to solar and a 200 Ah battery. I believe I should get at least 40 hours with Dometic fridge and lights running on 100 Ah battery - we'll see. That should be fine as with a 10 year old we usually don't camp in one place for more than 2 days. Hopefully, the driving from campsite to campsite with the DC/DC charger will keep our drinks cold. _________________ 1999 VW Winnebago Campervan |
Posted: Thu Apr 24, 2025 12:51 pm Post subject: Re: DC to DC charger install - does this work? |
| OB Bus wrote: |
No new shunts.
No bus bars.
No new fuses.
Any reason that would not work? I understand its might not be "as good", but would it be "good enough". |
If this is saying that the "charge" current is still eventually passing through the Magnatek on it's way to the battery, I'd strongly advise against that. it will "dirty" the voltage in ways the lithium will not like (I think, others correct me if I'm wrong). _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
xEVC Samba Member
Joined: March 23, 2017 Posts: 185 Location: California
Posted: Thu Apr 24, 2025 4:44 pm Post subject: Re: DC to DC charger install - does this work? |
| Quote: |
| That should be fine as with a 10 year old we usually don't camp in one place for more than 2 days. |
Nice to have a small chauffeur to drive you from site to site!
If you really want simplicity, consider not including a DC DC charger at all. I've been living that way for 5+ years.
Yes, some will say "Danger! You'll burn out your alternator, because the low resistance of LFP batteries will draw too many amps". Possibly true in other vehicles.
But I've tested this in the Eurovan, and it's simply not true: between the starting battery and the house battery are about 30 feet of wire, a bunch of connections, a big solenoid, and two 40AMP auto-reset breakers.
Add these all up and it's a non-trivial amount of resistance.
Thus, even when your LFP house battery is nearly dead, there simply is not enough current running through the system to do damage to your alternator.
In fact, the opposite is the problem: I find my LFP house battery only charges at about 20 amps. Adding a DC-DC charger might actually *increase* the amperage.
But whatever you do, get rid of the MagneTek - it's really a dinosaur.
p.s. : it's spelled MagneTek - many of us are getting it wrong in this thread. _________________ 2000 Eurovan Camper (Winnebago)
Upgraded with 16" wheels |
kourt Samba Member
Posted: Fri Apr 25, 2025 6:34 am Post subject: Re: DC to DC charger install - does this work? |
Just to add on to the amperage discussion: I configure my Victron DCDC chargers to never exceed 15amps in/out. Maybe not necessary in the plausible scenario that xEVC lists, but at least I have a gatekeeper that I know will limit amperage. I like that kind of control.
I second the removal of any MagneTek appliances.
kourt |
OB Bus Samba Member
Posted: Fri Apr 25, 2025 8:11 am Post subject: Re: DC to DC charger install - does this work? |
| kourt wrote: |
kourt |
So is there a step-by-step guide somewhere for eliminating the Magnetek? Not replacing it, but simply removing it? I know it unplugs, but what about the rest of the wires? I have never been inside that cabinet...yet.
I am not young. Thanks for your patience. _________________ Larry in OB
OB Bus Samba Member
Posted: Fri Apr 25, 2025 11:47 am Post subject: Re: DC to DC charger install - does this work? |
| mikemtnbike wrote: |
OB Bus- both the links above are very helpful. |
Yes I have studied both of them.
The instructions are to remove the "dirty" feed from the Mag. That I get. But there is still the red wire going from the Mag to the isolation stud. If I am not replacing the converter, does this wire get removed also? _________________ Larry in OB
Posted: Fri Apr 25, 2025 11:54 am Post subject: Re: DC to DC charger install - does this work? |
You can remove it, or safely cap it off for future use. _________________ David
1705.net
95 EVC
ACU,098 |
