Brakes needing to be pumped after new master cylinder
Page: 1, 2, 3  Next
brewvan
brewvan is offline
PostPosted: Fri Apr 25, 2025 1:26 pm    Post subject: Brakes needing to be pumped after new master cylinder Reply with quote
Hey I have an 86 vanagon and I put a new MC in, changed 90% of the hydraulic brake lines, but GW stainless steel hoses on, and bleed the system multiple times and I have to pump it two or three times for it to firm up. Any ideas? Also side note but I noticed the little rubber seal for the cap has a crack in it. not sure if that has anything to do with this.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Apr 25, 2025 1:38 pm    Post subject: Re: Brakes needing to be pumped after new master cylinder Reply with quote
Did you bench bleed the master before installing?
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
brewvan
brewvan is offline
PostPosted: Fri Apr 25, 2025 1:46 pm    Post subject: Re: Brakes needing to be pumped after new master cylinder Reply with quote
I did bench bleed it
Altoona
Altoona is offline
PostPosted: Fri Apr 25, 2025 2:34 pm    Post subject: Re: Brakes needing to be pumped after new master cylinder Reply with quote
Did you replace the wheel cylinders with ones missing the internal springs?
brewvan
brewvan is offline
PostPosted: Fri Apr 25, 2025 2:40 pm    Post subject: Re: Brakes needing to be pumped after new master cylinder Reply with quote
If I pump it up it holds pressure great until I let my foot off.
Altoona
Altoona is offline
PostPosted: Fri Apr 25, 2025 2:51 pm    Post subject: Re: Brakes needing to be pumped after new master cylinder Reply with quote
Did you replace the wheel cylinders?
brewvan
brewvan is offline
PostPosted: Fri Apr 25, 2025 3:26 pm    Post subject: Re: Brakes needing to be pumped after new master cylinder Reply with quote
Wheel cylinders haven’t been touched
Ahwahnee
Ahwahnee is offline
PostPosted: Fri Apr 25, 2025 4:40 pm    Post subject: Re: Brakes needing to be pumped after new master cylinder Reply with quote
That is typical of an incomplete bleed - pumping compresses the air to a point where the brakes momentarily work.
I always pressure bleed (several ways, I have a simple approach using a bicycle inner tube).
syncrodoka
syncrodoka is offline
PostPosted: Fri Apr 25, 2025 4:42 pm    Post subject: Re: Brakes needing to be pumped after new master cylinder Reply with quote
Classic symptom of air in the system. You may need to try a different type of bleeding style. Pressure bleeding is very effective, cost conscious people even make their own.
brewvan
brewvan is offline
PostPosted: Fri Apr 25, 2025 5:48 pm    Post subject: Re: Brakes needing to be pumped after new master cylinder Reply with quote
I’ll try pressure bleeding. Is it possible for that to happen if my drums are not adjusted equally?
syncrodoka
PostPosted: Fri Apr 25, 2025 6:42 pm    Post subject: Re: Brakes needing to be pumped after new master cylinder Reply with quote
Properly adjusted rear brakes will give a correct, higher brake pedal. I always adjust them first but your system needs to be bled.
Ahwahnee
Ahwahnee is offline
PostPosted: Fri Apr 25, 2025 8:38 pm    Post subject: Re: Brakes needing to be pumped after new master cylinder Reply with quote
The arrangement I use to apply modest air pressure to the system for thorough bleeding.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9386081&highlight=tube#9386081
?Waldo?
?Waldo? is offline
PostPosted: Sat Apr 26, 2025 7:48 am    Post subject: Re: Brakes needing to be pumped after new master cylinder Reply with quote
Rear brakes significantly out of adjustment will require pumping for a solid pedal, e.g. first pump moves the shoes close to the drums, next pump gives the solid feel.
Wildthings
Wildthings is online now
PostPosted: Sat Apr 26, 2025 11:22 am    Post subject: Re: Brakes needing to be pumped after new master cylinder Reply with quote
Did you do anything at all to the rear brakes? If so, what?
brewvan
brewvan is offline
PostPosted: Sun Apr 27, 2025 12:52 pm    Post subject: Re: Brakes needing to be pumped after new master cylinder Reply with quote
Ahhh gotcha. I haven't done anything to the rear brakes because ive been unable to get the drums off. it does seem that the passenger side rear isn't adjust the same as the other side. any advice on removing the drums?
Wildthings
PostPosted: Sun Apr 27, 2025 8:37 pm    Post subject: Re: Brakes needing to be pumped after new master cylinder Reply with quote
I always just remove the nut and hub. Easy enough if you have the tools to do so and with the hub out of the way you can replace the outer wheel seal and using a needle can pump a bit of new grease into the wheel bearings.
raygreenwood
raygreenwood is offline
PostPosted: Sun Apr 27, 2025 10:31 pm    Post subject: Re: Brakes needing to be pumped after new master cylinder Reply with quote
This is also a dead on symptom of something else.
Question: New master cylinder...meaning "NEW BUILD"...meaning manufactured recently...right? Or....
Is this an NOS cylinder? An old one?
This happens with many (I would say the vast majority) of NOS master cylinders over about 10 years old. The problem is that the EPDM seals harden up with age. That in itself is not a big deal. But, being confined in the bore on a shelf somewhere, they take on compression set. This means that they do not naturally extend outward.
They can hold great pressure but any relaxation of the pedal and they collapse and the pedal goes to the floor.
If not, if its a recent build master cylinder....yes...it may just need better bleeding.
Ray
brewvan
brewvan is offline
PostPosted: Tue May 06, 2025 12:43 am    Post subject: Re: Brakes needing to be pumped after new master cylinder Reply with quote
Here’s some info and an update. Removed the drums and cleaned the everything up. Installed new German built wheel cylinders. Re bench bleed the MC. Re bleed the whole system in the correct order multiple times. All the fittings are tight and leak free. No air is coming out even with a pressure bleeder. The MC I bought was from go westy and it’s the classic line brand. The brake pedal holds fine when the engine is off and I pump it up but when the engine is on the pedal slams to the floor. If I pump up the pedal while it’s running the brake pedal falls slowly to the floor. Any thoughts?
MarkWard
MarkWard is offline
PostPosted: Tue May 06, 2025 4:39 am    Post subject: Re: Brakes needing to be pumped after new master cylinder Reply with quote
Stock engine? Stock brake booster?
Igeo
Igeo is offline
PostPosted: Tue May 06, 2025 6:55 am    Post subject: Re: Brakes needing to be pumped after new master cylinder Reply with quote
I'm starting to think you got a bad master.
1987 Westfalia 2.1 WBX Manual
Page: 1, 2, 3  Next
