Steering Coupling Disc 211415417 (coupler)
Page: Previous  1, 2, 3 ... 32, 33, 34, 35  Next
Wildthings
Wildthings is offline
PostPosted: Tue Feb 18, 2025 9:39 pm    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
What is important is that each pair of adjacent holes on any couple has high ohms, opposite holes do not matter. No clue what the lower limit is ohms wise, but it may well be lower than any of the readings you are getting. In some failed couplers you can see a copper wire that ran from bushing to bushing, so the resistance would likely have been on the order of 0.05 ohms.
germansupplyscott
germansupplyscott is offline
PostPosted: Tue Feb 18, 2025 10:48 pm    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
All holes on Vewib, adjacent and diagonal, were the same, about 650 Ohm.
SL
kreemoweet
kreemoweet is offline
PostPosted: Wed Feb 19, 2025 6:20 am    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
A simple ohm test on a coupler sitting on a desk may not be entirely relevant. There are many who have reported horn honking (due to excessive coupler conductivity) only when turning, or otherwise placing stress on the coupler. In my own resistance measurements, I've found that putting pressure on the metal sleeves with the ohm-meter probes will substantially reduce the resistance (on some couplers). This squares with the theory that the unwanted coupler conductivity is caused by excessive graphite content in the coupler rubber, as graphite is somewhat conductive, and the conductivity is pressure-sensitive. Some old sewing machine speed controls were simply a stack of graphite disks in the motor electrical circuit, and putting mechanical pressure on the disks made the motor run faster, due to decreased resistance.
IOW, an actual in-use test may be necessary to evaluate the suitability of any given coupler design for use in early bay busses.
'67 bug: seized by the authorities
raygreenwood
raygreenwood is offline
PostPosted: Wed Feb 19, 2025 7:22 am    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
Just a note, unless you are finding graphite shedding out of the rubber, it's not likely the addition of graphite making the rubber conductive. It's more likely an excessive addition (possibly on purpose) of carbon black, which is already used in most black rubber and is highly conductive.
Adding pressure at the metal tubes or pressure decreases surface resistance in almost any circuit of any type (unless the contact points are actually a hard material and are highly polished).....because it compresses down the surface texture/profile of both contacts.
In the case of rubbers/elastomers that have "some" volume of conductive material dispersed in them....compressing the material "compacts" it....bringing the conductive ingredients closer together. That's the whole function you see happening.
The graphite disc phenomenon you saw in sewing machine rheostats and the same effect seen when putting pressure on motor brushes is the same. It's not any special pressure sensitivity/conductivity issue....it's just that graphite and carbon have rough, porous surfaces.
It's hard to know whether these couplers have been manufactured to be conductive on purpose.....or by accident.
Also, unless someone has done a density test at a minimum, I don't see that anyone has yet figured out what baseline rubber these have been made of.
They could be viton but I doubt it. Too expensive, most steering gear applications are in a low temperature and low oil, fuel chemical area.
They are usually Buna-N.
They are sometimes Neoprene but Neoprene is typically too soft for this product.
They could be SBR.
All of these, if they are SUPPOSED to be NON-CONDUCTIVE.....will have 5% or less carbon black and/or a mixture of treated, fumed-silica. Both are used as a tensile strength increasing additive, with carbon also acting as a pigment at the same time.
But.....if for some reason the addition of carbon black is either purposely or accidentally higher than 5% in most of these rubber types, the electrical conductivity rises very quickly.
The carbon market is cheap right now. Because carbon has a lot of good effect on abrasion resistance, and it's a far cheaper filler right now that fumed silica (fumed silica is only electrically conductive if it's been PEO modified which is also more expensive).....I "think" we are seeing the over use of carbon as a cheaper filler.
The last however.....if you see rubber that obviously has a graphite sheen on the outside, it's probable that the mold was dusted with graphite before injection of rubber to make an abrasion resistant rubber. We see o-rings like this....like the one that goes on the end of the crank next to the flywheel.
Typically the only rubber where graphite is intentionally used as an additive for electrical conductivity is with silicone. Graphite powder has a lower conductivity than carbon powder but it also has lower absorbency so it affects the portability of casting silicone less than carbon.
I think we are seeing rubber made in 3rd world countries that is made to be generic across a wide range of products....and is being sloppily made with excessive addition of carbon as a filler.....because its cheaper....and it also just happens to be conductive.
Ray
SGKent Premium Member
SGKent is offline
PostPosted: Wed Feb 19, 2025 9:41 am    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
winner is Ray with an answer of carbon black. Compressed it is used for electric motor brushes, spot light cathodes and anodes, and many more conductive uses. Graphite is carbon black when it has been compressed to the point the molecular structure changes. Diamonds are the next step of compression. One never uses pencils around open electronics - the dust is conductive. Burning (oxidizing) carbon black, graphite or diamond yields CO2 and any impurities in it. Ironically, both carbon black and graphite are good conductors, diamond is not. Using graphite in an electric lock like on new cars can destroy the electric components inside.
I don't remember if my bus horn honks when the bus is off, or whether my 1971 did either. I can visualize the science where turning might decrease the resistance. 650 ohms at a running voltage of 14V would create about 1/3 watt drain. 650 ohms at a sitting voltage would create about a 1/4 watt parasitic drain if the horn is armed when the bus is off.
Ohm's Law is E=I/R so I=E/R which is 14V/650 Ohm's = .022 amps. Power (watts) is P=(V2)/R which calculates at about 1/3 watt when running at 14V.
George Carlin:
Skills@EuroCarsPlus:
1971 deluxe (sold)
1977 deluxe
raygreenwood
PostPosted: Wed Feb 19, 2025 9:47 am    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
germansupplyscott wrote:
I used a cheap meter for this, I have a nicer one that is auto-ranging but this one allowed selecting the range so the numbers make more sense without having to read the little letters after the number. On this meter “1“ is infinity.
VEWIB: ~650ohm (others will know better, but I think it's OK in a 12v circuit?)
VEWIB - Note scale on meter is now 200 Ohm
The rest of the “good“ ones are infinity Ohm.
Original
OEM Germany (SGF Brand - was available from VW until ~10 years ago)
Kafer Brand is bad, almost 0 Ohm
While the ohms tells you that there is some current flow, the fact that it reads anything means there is an connection.
What I would do is take a pair or wires and and old or new VW horn. Connect one wire straight to negative on 12v to the horn. Run the other horn wire to the rubber coupler. Connect the other wire to + on the battery. Touch the wirefrom the horn to teh coupler at thesame time you touch the + wire from the battery to the connector....diagonally from each other like Wildthings noted.
Push both connectors hard onto the rubber connector. If the horn beeps...its an issue.
Ray
borninabus
Samba R&D Dept.
borninabus is offline
PostPosted: Thu Feb 20, 2025 6:14 am    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
from page 31:
SGKent wrote:
telford dorr wrote:
Yeah, some couplers are made of something conductive! Had a guy with a split bus whose battery kept going dead after installing a new coupler. Seems his bus horn was hot all the time (e.g. not wired through the ignition switch), and the leakage current through the coupler rubber (around 0.1 amps) made short work of the battery charge, unless driven daily! Had to rewire the horn to stop it.
FYI...
something as simple as a rubber coupler. Who are the snake oil salesmen who peddle these crap parts? Late bays have a jumper between sides of the coupler so it doesn't seem to matter on them, but earlier bays that need isolation it does matter.
german supply, apparently.
88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport
germansupplyscott
PostPosted: Thu Feb 20, 2025 7:45 am    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
No, the only version of this part we've ever carried was the SGF brand coupler with the VW logo, which were very good. They became unavailable about 5 years ago.
SL
raygreenwood
PostPosted: Thu Feb 20, 2025 11:50 am    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
So....here we are. 33 pages in....many different versions tried, all but a few fail in one way or another.
Across all of this discussion, we have no real specifications other than:
1. Must not conduct electricity
2. Must not be too soft
3. Must not be too hard
4. Must fit correctly.
Because no one has ever found (to my knowledge) a blueprint/spec sheet/CAD print of the original coupler.....no one has really defined the real specs of this thing.
I keep saying this. The specification of rubber cannot be done with a curl test in someone's hand. Sure, being able to wrap around a hotdogs is OBVIOUSLY too soft Laughing ....but otherwise, I can find reinforced rubber/elastomers that can curl that much in the flat plane....but in the opposite "plane" ....they are hard as a rock.
The measurements for rubber need to include type of rubber, density of that rubber, durometer of that rubber, modulus of elasticity and tensile strength. Until all of that gets involved....and rubber that passes the unscientific "bend test" in someone's hand....may actually fail compression tests (squishes out too much), may fail modulus/tensile strength tests (too stretchy).
I can test for type or rubber, durometer and to a crude extent....stretch out or rebound.
So, let's change tact....and start somewhere else and define what this part should DO before we worry about what it should be made out of.
1. We say it should "give" some. How much? Do we mean just twist wise, torsionally when you turn the steering wheel?....or do we also allow vertical/axial flex like when you pull in and out on the steering wheel? How much for each?
It is my observation....that this coupler only needs to flex a little bit in the flat plane....torsionally...when you turn the steering wheel....mainly as a buffer to not overload the steering gearbox and slam the gears together.
2. It needs to be non conductive....that's a given.
3. It needs to absorb/arrest vibration. I see this as a a big function right?
Question: a few pages back I commented that I "thought" that part of the reason this is a soft coupler was so that it would rip/tear during an accident. Wildthings noted that this is probably not that important given the rest of what goes on to the front end in an accident.....and OK...I agree. I see his point.
So....given all of that....why could this coupler not be made of a stack up of reinforced but flexible plastic like nylon or UHMW in the middle with a layer of rubber on each side on the outside?
About 10 pages back I posted a sketch of just how this could be made and actually made pretty cheap and easy. About the only thing it would not accomplish is to be "breakaway" in an accident.
Ray
Wildthings
PostPosted: Thu Feb 20, 2025 3:10 pm    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
I suspect on a lot of couplers the engineering consists of buy a piece of conveyor belt for a reasonably cheap price, then shape it and sell it. Similar couplers were used on many rigs of the era and there were likely dozens of domestic manufacturers at one point, but slowly companies left the market and remaining production moved over seas, and more expensive product were replaced with cheaper ones. Hopefully someone will make a decent replacement coupling well into the future.
metahacker
metahacker is offline
PostPosted: Thu Feb 20, 2025 4:58 pm    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
is there any need to look further than the Lares?
raygreenwood
PostPosted: Thu Feb 20, 2025 7:43 pm    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
Quality and fit wise from what everyone says? Probably not.
As of last week as others have noted...availability wise? Maybe so.
Yes they are making a new batch. It will be about a month they say. How big is a batch? Is there enough demand to make sure they are always going to produce this?
Has anyone here in this thread driven one long enough to say it will last as long as factory? ....which depending on what you drive can be a couple of decades or more.
On one hand...not requiring things to last forever. On the other hand...in my own interest....the 211 415 417...does not fit my car. I have made one fit long ago but it did not last. I had to pry it into location and that shortened its life. My car uses a 411 417 415 B or C....and yes for mine that is the correct part #. The two yokes are very slightly narrower in spacing. I could use a bus coupler in a pinch..........or......I think I could just as easily make one.
Its worth discussing what we want this part to achieve. At some point a good working spec part is going to disappear again. Ray
borninabus
Samba R&D Dept.
PostPosted: Thu Feb 20, 2025 9:38 pm    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
my mistake for assuming you are selling them as opposed to recommending their use.
advCo
advCo is offline
PostPosted: Mon Apr 21, 2025 7:43 am    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
FYI the Lares 209 is back in stock on RockAuto.
"He pulled the mirrors off his Cadillac ‘cause he doesn’t like it looking like he looks back"
'70 Westfalia Restoration
A bunch of vintage motorcycles
'73 Moto Guzzi Eldorado Restoration
rob.e
rob.e is offline
PostPosted: Tue Apr 22, 2025 7:30 am    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
I fitted the Lares coupler back in 2022.
I removed it at the weekend - no issues but i just wanted to check it out - no visible issues with wear, still looks like new.
it does feel a bit more flexible than i think it was when it was new. i don't have a new one here to compare unfortunately.
i've fitted an old one from my "stash" temporarily and i've orderd one of the bus-ok couplers to compare.
i'll do a short comparison video when the bus-ok one arrivives.
I've done prob 7-8k miles on the lares coupler btw.
@the_bus_journey
View user's profile Send private message Instagram Classifieds Feedback
Jason0115
Jason0115 is offline
PostPosted: Mon Apr 28, 2025 4:45 am    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
kreemoweet wrote:
As far as I can see, there's really nothing other than the stiffness of the rubber coupler and the spring under the steering wheel
preventing up-and-down (axial) movement of the steering column, aside from interference of attached parts.
So yesterday I replaced my original coupler with the LARES 209 coupler that everyone recommends from rockauto. I replaced the hardware with 10.9 grade flange nuts bolts and wave washers. All hardware is tight.
My question: Is it normal for the LARES couplers to flex when you turn the wheel and/or pull the wheel up and down? I am having two issues:
Item #1: When I turn the wheel either direction stationary, the coupler flexes and you can feel the flex through the wheel. When you let go, the wheel shoots back in place and the wheels return close to their original position.
Item #2: When you pull up or push down on the steering wheel, the coupler flexes up and down, moving the wheel/steering rod about a half inch in either direction.
Here is a video of both scenarios:
If the embed video does not work see below:
https://youtu.be/dGgK-2hR9eY
I haven't been able to figure out what actually keeps the steering shaft from moving up and down or side to side. Has anyone faced a similar issue or know of a solution?
1975 bus.
Wildthings
PostPosted: Mon Apr 28, 2025 5:23 am    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
The rebound is just from your tires and suspension loading and unloading, and not from the coupling, while the up and down motion seems excessive and potentially worrisome.
Jason0115
PostPosted: Mon Apr 28, 2025 5:41 am    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
So the rebound is normal? I just don't remember it being that dramatic with the old coupler. I also do not remember there being any up/down motion prior. When I turn the wheel either direction, I can see the coupler bend. Now I suppose that is from the vertical play in the steering rod...
What I think is happening: when I turn the wheel, that pulls the steering rod up or down, pulling the top two bolts on the steering coupler with it (as seen in the fourth clip of the video) causing it to bend when it shouldn't.
There really is nothing else besides the coupler that prevents the steering rod from moving up and down?
raygreenwood
PostPosted: Mon Apr 28, 2025 7:08 am    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
I agree with what Wildthings said. I watched your video a couple of times....very nice filming by the way.....I did not see the coupling disc "load up" radially, enough to cause that much steering wheel snap back. That is just about the type/amount of loading you get from the whole stack of suspension components, coupler disc, tires etc combined.
As for the in/out movement of the steering wheel.....that can't be correct because the gap it creates would actually cause issues with the self canceling mechanism and other components in the steering wheel. I will have to look at the parts diagram but.....totally speculating here....on some other models of acvw there is a snap ring or circuit that limits the in/out movement.
Ray
Wildthings
PostPosted: Mon Apr 28, 2025 7:50 am    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
How about a shot that shows the cords in the coupler well. Maybe Lares is using some other belting than what they had been using?
I have a fairly new coupling on the bus and a new spare, both of which carry the VW logo and seem to be A-1, but if I were looking for a replacement I might get the hole measurement that VW uses and hit a wrecking yard with a bunch of oldies but goodies and see if I could find a coupler with the same hole spacing that I could potentially salvage the rubber disc from.
Page 33 of 35
