dsh1705  Samba Member
Joined: June 11, 2014 Posts: 131 Location: Seattle, WA
Posted: Mon Apr 28, 2025 1:25 pm Post subject: EVC Furnace Access Modification |
The shroud that surrounds the EVC furnace also supports the hot air ducts for the furnace. In order to remove this shroud you need to slide the stock rear seat out of the way for access. In my van, with its platform bed, removing the seat base is a non-trivial task. My solution was to cut the shroud at the location where the shroud changes size for the hot air ducts. Now I can remove the shroud without having to move the seat base, and without disturbing the hot air ducts.
_________________ David
1705.net
95 EVC
ACU,098 |
krusovice Samba Member
Joined: October 12, 2008 Posts: 288 Location: Duluth, MN
Posted: Mon Apr 28, 2025 2:10 pm Post subject: Re: EVC Furnace Access Modification |
Hi, joining you from the other thread.
do you find it rattles or squeaks where the panels meet? _________________ 1984 Vanagon 1.9/4 speed
2001 Eurovan Camper |
Posted: Mon Apr 28, 2025 2:12 pm Post subject: Re: EVC Furnace Access Modification |
Nope. But then, the entire van rattles and squeaks!  _________________ David
1705.net
95 EVC
ACU,098 |
Posted: Mon Apr 28, 2025 2:43 pm Post subject: Re: EVC Furnace Access Modification |
Quote: |
do you find it rattles or squeaks where the panels meet? |
Let me expand on this a little bit.
I cut this panel with an oscillating multi-tool.
I have found that the panels in the 95 are thicker than the panels I have seen in later vans. I have seen later vans with such thin plastic that the bed near the back of the van is sagging. Panels that are so thin that you are sure they will snap as soon as they are removed. So I am not sure if you did this in a van with thin plastic how it would turn out.
I did not find that I needed to add a gap between the panels, or to add any material to the cut edge - like edging - after creating a gap (both options I thought I might need to explore). It seems to work just as it did before.
My platform bed still uses the shroud for the support in the back - on both the furnace and battery sides. _________________ David
1705.net
95 EVC
ACU,098 |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2721 Location: Ocean Beach - San Diego
Posted: Tue Apr 29, 2025 8:19 am Post subject: Re: EVC Furnace Access Modification |
Also joining from the other thread.....
Thanks for the detail. If squeaks or rattles are an issue after this modification, it seems like some grey T-moulding might solve the issue(s). _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper.
People deserve the Government they voted for. |
RiversToTheSea Samba Member
Posted: Sat May 03, 2025 4:41 pm Post subject: Re: EVC Furnace Access Modification |
I'm upgrading the 12V electrics and replacing the furnace in my 1995 right now. Thanks for posting this, I think I will do this to mine. I couldn't believe how many screws had to be removed to gain access to the furnace/converter area. Not to mention having to disconnect all the hot-air ducts. |
