OK to drive this far after tranny leak?
mr matt
mr matt is offline
PostPosted: Wed Apr 30, 2025 2:35 pm    Post subject: OK to drive this far after tranny leak? Reply with quote
My 55 oval sits in a very small garage, which a while ago, when I opened the door I noticed a lot of tranny fluid on the cardboard underneath the car. (Cardboard is always a VW must)
I do not know how much fluid is left.
No room in the small garage to know what is going on.
My main garage is about 50 ft away, but prior to that, need to go reversre and forward ~ 3x to make a turn to face the driveway.
Is it ok to very gently drive it( lowest speed/rpm effort made) that distance vs pushing it? After pushing it out of the small garage, there is a large area of 3/4 inch gravel making it tough to push off of. My back is not the greatest.
I will over inflate the tires to make rolling better...
Is "driving it" save to do?
Thanks
1955 3-fold semaphore Oval beetle
1971 Convertible beetle
1977 Westfalia, FI, Berlin interior
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Wed Apr 30, 2025 4:48 pm    Post subject: Re: OK to drive this far after tranny leak? Reply with quote
Thanks
I will give you some info from what I have experienced. You will need to decide if it works for you.
I worked professionally as a mechanic, in a ACVW shop, for several years. During just that time, I had first hand interactions with several different ACVWs running and driving with little (I mean a few ounces) to nothing in the transmissions. A few were daily drivers.
I personally towed (with a tow bar) a few Bugs with no transmission oil. One of those made it with no issues afterwards. One of them lost its shit on the way home, costing me a few hundred bucks in towing and a bunch of frustration!
I have had a mix of experiences both ways with more than 30 AcVWs. I cannot give you a definitive answer.
Good luck which ever way you go! I am rooting for you!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
Bub
Bub is offline
PostPosted: Wed Apr 30, 2025 4:53 pm    Post subject: Re: OK to drive this far after tranny leak? Reply with quote
Nobody can really say what will happen or what the situation is-
But I can tell you I am certain that if you drive it 50 feet, or even a mile with a totally empty gearbox and it fails, it was going to anyway. If that short of a distance ends in disaster then there was no avoiding it, the damage was already done.
hitest wrote:
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was...
mr matt
mr matt is offline
PostPosted: Thu May 01, 2025 7:40 am    Post subject: Re: OK to drive this far after tranny leak? Reply with quote
Found a tow bar, will use that... thanks for the input, appreciate it
VW_Jimbo is offline
PostPosted: Thu May 01, 2025 8:43 am    Post subject: Re: OK to drive this far after tranny leak? Reply with quote
You are welcome. And that is a much better idea.
Jimbo
petrol punk
petrol punk is offline
PostPosted: Thu May 01, 2025 10:20 am    Post subject: Re: OK to drive this far after tranny leak? Reply with quote
Transaxle oil level is not as important as you think. I could drive to the store and back with no oil in the trans and not sweat it. And a large puddle on the cardboard sometimes only translates to a small amount of oil volume. You're fine to move the car around.
36hp '56 European DeLuxe oval
'70 bug 1835cc
pondoras box
pondoras box is offline
PostPosted: Thu May 08, 2025 8:31 am    Post subject: Re: OK to drive this far after tranny leak? Reply with quote
The transaxle still spins when being towed with a towbar. I just had to move a jeep with the differential cover removed and went probably 150 feet. Drove fine no issues or damage. There was enough residual oil the it was well protected for that. Just cleaned it with brake clean reassembled topped of and it was perfect.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop (Arschloch)
1973 standard bug (Dirty Gertie)
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion
my3bugs
my3bugs is offline
PostPosted: Thu May 08, 2025 8:52 am    Post subject: Re: OK to drive this far after tranny leak? Reply with quote
it could just be a cracked axle boot not an actual trans leak . you need to jack it up n take a look to see where its coming from ..........ill bet the boot just cracked ???
RUNKLE
RUNKLE is offline
PostPosted: Thu May 08, 2025 9:39 am    Post subject: Re: OK to drive this far after tranny leak? Reply with quote
mr matt wrote:
… My main garage is about 50 ft away, but prior to that, need to go reversre and forward ~ 3x to make a turn to face the driveway.
Is it ok to very gently drive it( lowest speed/rpm effort made) that distance vs pushing it?… Is "driving it" save to do?
Thanks
Those boxes are fairly hardy, and there’s enough gear oil left in it - so it’s completely safe to move your car under its own power to your main garage 50ft away.
Type 1
Type 3
1968 Squareback
mr matt
mr matt is offline
PostPosted: Fri May 09, 2025 1:36 pm    Post subject: Re: OK to drive this far after tranny leak? Reply with quote
Thanks again all!
Probably will give it a try this weekend I hope.., and I am hoping it is something simple as a cracked boot Pray otherwise quite a bit of time and money...
mr matt
mr matt is offline
PostPosted: Sun May 11, 2025 8:55 am    Post subject: Re: OK to drive this far after tranny leak? Reply with quote
OK,
Got it in the garage under its own power... gentle and slow as ever.
No bad sounds from the tranny when it was moving..
just came out from crawling under it to find a boot has cracked Very Happy well,
happy about that vs the 70 year old tranny having some mishap Shocked .
What bothers me is I put that boot on maybe 18 years ago, and it failed, whereas the one that came with the car is still intact Wink
I am starting to look at what would be good quality rubber boot.. like from WCM, but first glance WCM sell seamless boots.. guess to put that one on need to disconnect the axle from the tranny. Rather not.
The seamed boots apparently do not leak at the seam at all.. and if I remember right, was not that bad to replace...although I have to look up again how to do it.
Then there is the question as to what oil goes into these boxes.
I changed it out before, but remember reading there was a better oil alternative that what I used.
Found it on WCM, but does not have their usual mention of "guaranteed for life, best quality rubber from WCM: kind of exposition
https://www.westcoastmetric.com/i-22963989-axle-bo...2OMUETzEoq
