Retitled - 'sneezing' misfire under load
Who.Me?
Who.Me? is offline
PostPosted: Thu May 01, 2025 12:43 pm    Post subject: Retitled - 'sneezing' misfire under load Reply with quote
What might cause this uneven scorching of the terminals on a new distributor cap?
This is the cylinder 2 terminal after a 15 minute test run...
The scorching looks unusual to me and particularly so compared to the other terminals that all look relatively clean like this...
It's a 1600 dual port engine with an original Bosch SVDA distributor. I've just changed the oil, points, distributor cap and rotor arm before taking it out for it's first run of the year (the drive train has been out while I repaired the transaxle).
The engine developed a slight missfire under acceleration as it came off choke that worsened as the engine warmed up. By the time I'd done a few miles and got it fully up to temperature the missfire became severe and an intermittent 'sneezing' backfire developed.
I will do a proper tune up over the weekend when the weather cools down (we've had freak heatwave here), but in the mean time I checked the parts I've changed.
Pulling the distributor cap, I noticed that the rotor arm seems to have 'clearanced' some of the plastic. I wiped the plastic dust off before I thought to take any pictures. More significantly, I noticed that unusual scorching on the cylinder 2 terminal. The other three terminals look OK.
I checked the distributor shaft in case there was any play that might cause the rotor arm to come closer to that terminal than the other. There is no lateral play (there is about 1mm up/down movement).
The cap and rotor arm I recieved from the supplier have slightly different part numbers to my old ones. (New cap = VK1061, Old cap was VK106BE. New rotor arm = EVL0851EF, old arm was EVL085BE).
The cap was seated correctly, as far as I can tell.
Any ideas why that terminal would show unusual scorching after just a few minutes? And could it relate to the worsening missfire?
Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786
my3bugs
my3bugs is offline
PostPosted: Thu May 01, 2025 1:34 pm    Post subject: Re: Strange scorching on new distributor cap terminals Reply with quote
pretty obvious the rotor did that ? but was it a cap made off center ? looks like its like one or the other . was the rotor installed all the way down and in the notch ? my guess is likely cheap aftermarket parts ? ill often pay more for Bosch .
SGKent Premium Member
SGKent is offline
PostPosted: Thu May 01, 2025 3:06 pm    Post subject: Re: Strange scorching on new distributor cap terminals Reply with quote
silicone grease (dielectric grease) put onto the tip of the rotor helps protect it. That is just a trail of arcing. I suspect that when the industry went from brass embedded caps to aluminum embedded ones that type arcing became more prevalent.
George Carlin:
Skills@EuroCarsPlus:
Who.Me?
Who.Me? is offline
PostPosted: Fri May 02, 2025 12:43 am    Post subject: Re: Strange scorching on new distributor cap terminals Reply with quote
Just seems weird that only one of the contacts is like that and there is such a clean swipe and that I had an increasing missfire.
The cap I took off had the usual marks on the contacts and the other three terminals new cap look to be forming normal marks.
The parts are all Beru. I didn't cheap out.
Andy
oprn
oprn is offline
PostPosted: Fri May 02, 2025 2:52 am    Post subject: Re: Strange scorching on new distributor cap terminals Reply with quote
Put the old ones back on and try it. If it runs fine... chuck the new ones out.
I live by the thought that just because you can buy some part new does not mean that you need to.
heimlich Premium Member
VWNOS.com
heimlich is online now
PostPosted: Fri May 02, 2025 11:52 am    Post subject: Re: Strange scorching on new distributor cap terminals Reply with quote
Some of those Beru parts are made with aluminum inserts. Yours might still be fine. Buy a Bosch one and see if it fixes the issue. If not you have a good spare.
Who.Me?
Who.Me? is offline
PostPosted: Sat May 03, 2025 8:11 am    Post subject: Re: Retitled - 'sneezing' misfire under load Reply with quote
Swapped the cap and rotor arm back to the old ones (but forgot to swap the points back) and did the rest of the tune up. It seemed better, but I'm still getting intermittent 'miss' under acceleration. Sometimes it's fine, then it suddenly becomes a huge issue stuttering and, if I push it, a 'sneezing' misfire, almost like it stalled momentarily and restarted.
Checked for vacuum leaks with carb cleaner (none).
Was going to swap out the condenser, just in case, but the one I've received is wrong (rectangular terminal block, instead of square).
Will pull the carb off tomorrow to check and clean it, but fuel here is good. I replaced the tank ten years ago with a band new WW one, so I don't suspect rust.
Have added some fuel dryer because it was easy since November, but I use E5 (and haven't had any issues with water in fuel before).
I did notice that there was some spark scatter (it drifted maybe 10mm either side) but I've noticed that before without this problem.
Any ideas?
Andy
BoneStorm-zZ
BoneStorm-zZ is offline
PostPosted: Sat May 03, 2025 6:24 pm    Post subject: Re: Retitled - 'sneezing' misfire under load Reply with quote
I had the same sneeze. Few things you could check. One is a vaccum leak. Where the intakes sit, boots if you have them, base of the Carb, and the throttle bushings. Where the accelerator arm attaches.
Spray your carb cleaner religiously. Hold it for a few seconds. Go through a can or two. Both sides of intakes, around the entire base of the Carb, both bushings.
Do you have ALL your gaskets in place? Are all the nuts tightened down?
Then make sure you get good fuel from your pump. Get to idle, pull the lever back and look for a GOOD squirt into the throat. Make sure the little brass nozzle leaves gas directly into the throat. Down the middle! The tiniest pull should give you some gas.
If it doesn't? Adjust the fuel pump. There's a small cam lobe with a screw in it. Right side closest to the alt/gen. The same little lobe has a + or -. Go "-" for more gas. If you max out and still nothing, freshen up the pump. Or buy a new carb, idk.
Also, don't slam the accelerator pedal. Go through the gears a little slower and ease into each gear. Something about appropriate rpms for the gear you're in. Hope this helps!
-Nate
vamram Premium Member
vamram is offline
PostPosted: Sun May 04, 2025 9:00 am    Post subject: Re: Retitled - 'sneezing' misfire under load Reply with quote
Have you tested your coil? I've had similar symptoms w/bad coils, and w/a dirty carb where the bowl was drying out under load due to junk in the needle valve, idle and main jets.
'75 Super Le Grande...we hardly knew ye. Sold 2025 for peanuts.
Click to view image
Save the Supers!!
Who.Me?
Who.Me? is offline
PostPosted: Sun May 04, 2025 1:10 pm    Post subject: Re: Retitled - 'sneezing' misfire under load Reply with quote
I went through the carb this afternoon. It was spotless. I checked the accelerator pump volume again. It's delivering 15ml per squirt, and starts squirting the as soon as the throttle arm starts to move, so that's OK.
The only issue I found with the carb was that the o-ring on the volume screw was chewed up. Not sure if that happened during dissassembly, or whether it was already chewed up. I've replaced it with a new one left over from a rebuild kit that I had.
I also pulled the filter out of the pump. Again; it was spotless.
I haven't tested the coil yet. I will test it. The problem only seems to manifest under acceleration when the engine is warm or warming. I'm a bit concerned that, if the coil is at fault, it might be temperature-related, so I might struggle to diagnose whether it's good or not.
I've also ordered the correct condensor (Beru's website gave the wrong info). I keep spare new leads and plugs knocking around that I'll try.
Andy
SGKent is offline
PostPosted: Sun May 04, 2025 3:56 pm    Post subject: Re: Retitled - 'sneezing' misfire under load Reply with quote
my vote is bad condenser or cracked dual port boot
George Carlin:
vamram is offline
PostPosted: Sun May 04, 2025 5:31 pm    Post subject: Re: Retitled - 'sneezing' misfire under load Reply with quote
Good point. WhoMe, have you checked for vacuum leaks at the boots?
Click to view image
Save the Supers!!
Who.Me?
Who.Me? is offline
PostPosted: Mon May 05, 2025 4:02 am    Post subject: Re: Retitled - 'sneezing' misfire under load Reply with quote
Yes. That was the first thing I did before running through the timing and carb tune up on Saturday. I've had vacuum leaks in the past and the revs were oscillating at idle before I ran the tune up procedure, so I thought I might have dislodged a connection somewhere while the engine was out.
I sprayed all the possible inleakage points between the throttle arm pivot and the head flanges with aerosol carb cleaner but no change to the idle.
As I ran the tune up the idle settled down. Not sure if the points gap could have caused the oscillating idle, but that issue cleared up after adjusted the dwell (new points when I refitted the engine). Dwell is currently 51 degrees according to my meter. The book says 50 +/- 2 degrees for new points.
Andy
johnnyvw164
johnnyvw164 is offline
PostPosted: Mon May 05, 2025 5:49 am    Post subject: Re: Retitled - 'sneezing' misfire under load Reply with quote
Try an old trick: at night when you can run the engine in the dark, spray some water on the ignition wires and look for arcing to any metal. The symptoms sound like the insulation is breaking down and allowing voltage leakage.
Who.Me?
Who.Me? is offline
PostPosted: Fri May 09, 2025 6:15 am    Post subject: Re: Retitled - 'sneezing' misfire under load Reply with quote
Condenser. d'oh!
Strange. I wouldn't have thought it could cause symptoms like that. I always thought they either worked, or didn't.
The timing scatter has also cleared up. I'm wondering how old that condenser was, because I can't remember the timing ever being as steady as it is now.
I was starting to doubt the accuracy of my venerable timing light, but there's not much that can go wrong with those which would cause them to trigger at the wrong time.
Andy
