DSVW Samba Member
Posted: Tue May 06, 2025 8:54 am Post subject: Distributor Cap |
Hi, I have a 1966 Bug, all original.
It is still 6 volt.
I have brand new cap and distributors around. Can I use the same cap and distributor that I used for my 12-volt 1969 Ghia or 1974 Thing in my 1966 Bug.
Thanks. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80667 Location: Sneaking up behind you
Posted: Tue May 06, 2025 9:23 am Post subject: Re: Distributor Cap |
Cap doesn't care if it's 6v or 12v as long as it fits. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7452 Location: Clyde, TX
Posted: Tue May 06, 2025 9:47 am Post subject: Re: Distributor Cap |
As noted above, the cap doesn't care if you're running 6v or 12v, it just needs to fit the distributor in question and be compatible with the rotor.
Now, can you use the distributor(s) you used in your Ghia or Thing in your '66 Bug? Sure. Most any distributor can be used, but that doesn't mean it'll work well or work correctly. The distributor needs to be paired with a carburetor it's designed to work with. _________________ 1960 Ragtop w/Semaphores "Inga" |
DSVW Samba Member
Posted: Tue May 06, 2025 10:07 am Post subject: Re: Distributor Cap |
| Sorry, I meant rotor, not distributor. Can I use the same rotor as well as the cap.Thanks |
Glenn  Mr. 010
Posted: Tue May 06, 2025 10:16 am Post subject: Re: Distributor Cap |
Yes bit are good for 6v and 12v _________________ Glenn
Member #1009
#BlueSquare
DSVW Samba Member
Posted: Tue May 06, 2025 12:20 pm Post subject: Re: Distributor Cap |
| Thanks, I take it the points would be the same as well? |
Glenn  Mr. 010
Posted: Tue May 06, 2025 12:46 pm Post subject: Re: Distributor Cap |
Yes.
The only thinks voltage specific on the engine are the generator, coil and electric choke. _________________ Glenn
Member #1009
#BlueSquare
DSVW Samba Member
Posted: Tue May 06, 2025 12:52 pm Post subject: Re: Distributor Cap |
| Great, thanks. |
wimkever Samba Member
Joined: July 16, 2004 Posts: 439 Location: Holland (the Netherlands)
Posted: Tue May 06, 2025 1:06 pm Post subject: Re: Distributor Cap |
| Glenn wrote: |
Yes.
The only things voltage specific on the engine are the generator, coil and electric choke. |
And the voltage regulator. _________________ a beetle is like a cocker spaniel, always funny but sometimes not listening |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36440 Location: Conejo Valley, CA
Posted: Tue May 06, 2025 2:19 pm Post subject: Re: Distributor Cap |
... and the electromagnetic pilot jet (if you fitted one). _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
zerotofifty Samba Member
Posted: Tue May 06, 2025 3:09 pm Post subject: Re: Distributor Cap |
| Glenn wrote: |
Yes.
The only thinks voltage specific on the engine are the generator, coil and electric choke. |
And the run on valve, and regulator. _________________ Sorry About That Chief.
Give Peace a Chance.
Words to live by. |
Glenn  Mr. 010
Posted: Tue May 06, 2025 3:27 pm Post subject: Re: Distributor Cap |
| zerotofifty wrote: |
| Glenn wrote: |
Yes.
And the run on valve, and regulator. |
Look at the 2 posts above yours. They were already mentioned. _________________ Glenn
Member #1009
#BlueSquare
Joined: April 27, 2002 Posts: 6876 Location: Pentwater, Michigan
Posted: Tue May 06, 2025 8:04 pm Post subject: Re: Distributor Cap |
Just in case, if what you're asking is, the same cap and rotor on my 1966 car with different later distributors then the answer is, no. Between 1966 and the mid 1970's distributors went through several design changes requiring different caps and rotors. They are not interchangeable. _________________ Roads Scholar
Member# 2059 |
