1500 stock engine dealing barrels
aircooled
aircooled is offline
PostPosted: Tue May 06, 2025 7:13 pm    Post subject: 1500 stock engine dealing barrels Reply with quote
I’m getting ready to reinstall my stock cyclinders. They have a thin metal shim on each cyclinder. Should I put down a thin bead of sealant between the shim and bottom of cyclinder and another beam under the spacer as it fits against the case?
Or should I just put a bead under the spacer as it fits to the case?
67 Sun Roof / Born Sept 66 / Second Owner
67 Convertible / Born Aug 66 / Second Owner
Member of 67 Posse
Omaha Volkswagen Club
Neb VVWCA Chapter Rep
Volkswagen Club of Nebraska
oprn
oprn is offline
PostPosted: Tue May 06, 2025 7:36 pm    Post subject: Re: 1500 stock engine dealing barrels Reply with quote
My question is... why would you be shimming cylinders on a stock 1500?
If the shims are legitimately needed, there is no harm in a thin coat of sealant on both sides in my view.
Dusty1
Dusty1 is offline
PostPosted: Wed May 07, 2025 2:15 pm    Post subject: Re: 1500 stock engine dealing barrels Reply with quote
Your cylinders should be re- ringed and nicely honed before re- installation.
Spend the $40 for a Berg "CC" kit. You can figure compression ratio if you know your combustion chamber volume and deck height. Enter the numbers into CB's handy calculator. Then you'll know why those shims are there and if they're necessary.
RWK
RWK is offline
PostPosted: Wed May 07, 2025 7:17 pm    Post subject: Re: 1500 stock engine dealing barrels Reply with quote
I usually deck old cases, have had to shim stock cylinders to get back to good (safe) deck, most cases need .01 off to get flat again, decking an old case is good insurance against leaking and getting a good seal at the head.
73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530
