Loki54 Samba Member
Joined: April 19, 2022 Posts: 64 Location: in a van down by the Ottawa River
Posted: Wed May 07, 2025 3:07 pm Post subject: Beetle Door Hinge Screw Plug |
For late production 1967 Beetles, i.e. March in my car's case, are the door hinge screw plugs white or black?
I'm seeing that only 68 and up have white plugs.
My March 67 production beetle has white plugs, but I'm missing lower plugs on both sides and want to make it correct.
67conv Samba Member
Joined: July 10, 2005 Posts: 465 Location: Simi Valley, California
Posted: Thu May 08, 2025 6:50 am Post subject: Re: Beetle Door Hinge Screw Plug |
The "white" hole caps are actually a clear plastic and usually fade to a light amber / slightly yellow shade after 50+ years. They are the correct choice for your '67. Black is incorrect for 67's, was used on earlier Beetles. _________________ 1967 VW Convertible, owned 35 years.
1957 DKW 3=6, owned 21 years.
PREVIOUS: 1972 "Baja Champion SE" Spec. Edition Beetle bought NEW @ Pierce VW in Denver; 1979 Super Beetle Convertible bought NEW @ Downtown LA VW; 1967 type 1 savanna beige; 1967 Porsche 2.0 911S; 1973 Porsche 2.4 911T; 1963 356 T6 B Cabriolet; 1964 356 SC sunroof coupe; 1972 Type-3 Squareback; 1968 + 1969 Type-3 Fastbacks; 1987 Vanagon GL Weekender |
Loki54 Samba Member
Posted: Thu May 08, 2025 7:30 am Post subject: Re: Beetle Door Hinge Screw Plug |
| 67conv wrote: |
| The "white" hole caps are actually a clear plastic and usually fade to a light amber / slightly yellow shade after 50+ years. They are the correct choice for your '67. Black is incorrect for 67's, was used on earlier Beetles. |
Great information, thank you!
Would you or anyone else know where to source these clear plastic hole caps in NOS condition? |
branston Samba Member
67conv Samba Member
Posted: Thu May 08, 2025 7:54 am Post subject: Re: Beetle Door Hinge Screw Plug |
Aftermarket clear plastic caps are readily available through vendors such as Wolfsburg West and West Coast Metric. However, since they'll be repops, the original "VW" and "Knipping" scripts wont be on them. Depends on if you're doing a bone stock restoration or not, if that will matter to you. Otherwise, you might want to check the Samba classifieds for the 'correct' OEM ones for sale. Be aware that not all of these caps are of the same size diameter. Depends on what hole application they're covering... So, know what you will need in advance. _________________ 1967 VW Convertible, owned 35 years.
thomas. Samba Member
Joined: July 31, 2010 Posts: 1383 Location: South West (Pa.)
Posted: Thu May 08, 2025 2:08 pm Post subject: Re: Beetle Door Hinge Screw Plug |
A number of years ago I bought some of these org. German items from this vendor in the Philippines. They have the VW markings on them. Same part number as yours too. I changed all of them at the time so they would all look the same. I bought these around 5 or 10 years ago and it doesn't look like the price has changed.
https://www.thesamba.com/vw/classifieds/detail.php?id=1790423 |
Loki54 Samba Member
Posted: Thu May 08, 2025 2:20 pm Post subject: Re: Beetle Door Hinge Screw Plug |
| thomas. wrote: |
Thanks I'll try to connect with this vendor and see if they are still available. |
