Rear Brake drum hitting shoe retaining spring
Wrdiver
Wrdiver is offline
PostPosted: Wed May 07, 2025 1:00 pm    Post subject: Rear Brake drum hitting shoe retaining spring Reply with quote
First off… 1963 Ghia. Car new to me, sat for 25 years, brakes were seized. I redid the brakes with new hardware and had drums turned as they are original and just needed cleaned up. It’s new shoes, springs, cylinders. OE drums that I has turned by a reputable machine shop.
Now after putting it all back together and torquing the castle nut to 253lb (then slightly backed off so cotter pin could go in) , the drum is hitting the retaining spring when I spin the drum. I noticed the new hardware pins are slightly longer than OE originals so I reused the old ones (pins and springs) and they still hit the spring. It’s hitting where the wheel stud hole bulges out inside the drum. Also hit original “oil slingers”. Once again OE drums (decent shape)….
I have taken the brakes apart like 5 times and get the same result…. I also tried with the shoes fully adjusted in and also set properly (slightly rubbing drum)….. I need advice….
wagen19
wagen19 is offline
PostPosted: Wed May 07, 2025 9:47 pm    Post subject: Re: Rear Brake drum hitting shoe retaining spring Reply with quote
Make sure, you have original short pins for 30 mm rear brake shoes and original springs.
Some aftermaket pins and springs are junk. (assuming, your old pins already can be aftermarket)
runamoc Premium Member
runamoc is offline
PostPosted: Thu May 08, 2025 8:11 am    Post subject: Re: Rear Brake drum hitting shoe retaining spring Reply with quote
I've had this happen before. What I did was use #8 washer, or was it #6 washer, whatever fits around the pin but smaller than the pin head. Put the washer on the pin before putting the pin through the backing plate. I fixed mine with one washer on each side but it may take stacking two washers to pull the locking cap back enough not to hit.
Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
Wrdiver
Wrdiver is offline
PostPosted: Fri May 09, 2025 3:13 pm    Post subject: Re: Rear Brake drum hitting shoe retaining spring Reply with quote
Thanks for the suggestion. A little washer on the pin head seems to do the trick!
Teeroy Premium Member
Teeroy is offline
PostPosted: Fri May 09, 2025 6:42 pm    Post subject: Re: Rear Brake drum hitting shoe retaining spring Reply with quote
After you have rubbing issue resolved, torque the drums properly. Once you hit torque if the holes for cotter pins don't line up,keep tightening to the next hole, if you back them off to line up like you did, they are no longer torqued.
Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
