SGKent  Samba Member
Joined: October 30, 2007 Posts: 42072 Location: at the beach
Posted: Thu May 08, 2025 2:33 pm Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! |
Naturally aspirated 1600 Fiat 124 engine, 140 HP. We could get 130 with a Weber progressive or 140 HP with dual carbs. I would think that the VW engine should be able to hit at least 125HP. The Fiat did not have the disadvantage of pushrods and it was cross flow. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7785 Location: Videbaek Denmark
Posted: Thu May 08, 2025 2:53 pm Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! |
125 hp from a NA 1600, and peak at no more than 6000 is a walk in the park. From around 140 it begins to get, if not complicated, then you need to know what youre doing in order to get a nice usable engine out of it. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
oprn Samba Member
Joined: November 13, 2016 Posts: 14565 Location: Western Canada
Posted: Thu May 08, 2025 4:58 pm Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! |
Alstrup wrote: |
125 hp from a NA 1600, and peak at no more than 6000 is a walk in the park. From around 140 it begins to get, if not complicated, then you need to know what youre doing in order to get a nice usable engine out of it. |
Ah yes! But what you fellows are talking about is a lot of expensive specialized parts and machining to get those kind of numbers not a stock 1600. Also lets compare the torque numbers and where in the RPM range they occur.
Peak HP at peak RPM does not a drivable, practical engine make! Torque is what counts on the street. _________________ Our cars get old, we get old but driving an old VW never gets old! |
Root_Werks Samba Member
Joined: December 31, 2007 Posts: 1039 Location: San Juan Islands
Posted: Fri May 09, 2025 10:25 am Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! |
oprn wrote: |
Alstrup wrote: |
Peak HP at peak RPM does not a drivable, practical engine make! Torque is what counts on the street. |
I agree, torque = acceleration and hp = top speed (sort of). For driving around, a lazy stump pulling torque monster engine is nice.
Either way, fun video series! EP5 really shows how much difference a fresh top end can make. _________________ When I set my timing, why do I flush, then take a pee? |
Posted: Fri May 09, 2025 11:33 am Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! |
Draw throughs are a relatively easy way of getting quite a bit of a power increase. but in many areas it is not legal, at all. Next, while draw throughs are easy power they suck on cold start, idle and fuel economy. you pay a hefty price for the cheap power. But if the vehicle is a saturday night special, that part matters less for most.
Blow throughs are somewhat more complicated, but much more versatile and DD friendly once dialed in.
A 125 hp 1600 is relatively cheap and easy to build. Just stop "living" in 1995. That said, the difference between that and a 140 hp 140 is relatively small, so most would want the 1914. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
oprn Samba Member
Posted: Fri May 09, 2025 1:04 pm Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! |
I daily drove (our only family car with 2 children) a draw through for 4 years summer and down to -40 in the winter so it is entirely possible and practical. In fact it ran better the colder it got! This was 30 years ago and should be even easier with today's technology.
The only downside to draw through in my experience is the difficulty in incorporating an intercooler. All else is simpler. If I were to do a turbo today it would still be draw through or... go deluxe and blow through a single throttle body with EFI. All your usual blow through the carb problems would be gone! _________________ Our cars get old, we get old but driving an old VW never gets old! |
BFB Samba Member
Posted: Fri May 09, 2025 7:54 pm Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! |
I gotta agree with Oprn on this one, although majority of my engines live in buggys and aren’t DD’s years round, the draw throughs ive built are not much more cold natured than any N/A’s ive owned or built if at all.
My draw through 2276 with the split shaft DCOE , being the draw through i have the most time spent with, runs & drives like a production passenger vehicle did in the 80’s , not going to say its as easy as a modern EFI car though and it definitely is cold natured, but once its been run and warmed it it’ll fire right up.
Last I mathed the mileage it was about 25mpg, not bad in my book considering how i drive it.
Ive built about equal amounts of draw through and blow through set ups and theres really only 2 determining factors when choosing which one to build for someone, 1. How much they want to spend and 2. Whether they will be driving in colder temperatures or not.
Aside from that they can both be tuned to drive about the same _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
SGKent  Samba Member
Posted: Sat May 10, 2025 12:55 pm Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! |
the numbers I gave were with a naturally aspirated (carb) engine, and not one with a turbo and boost. With the option of boost, it is simply a matter of how strong can you make things before the boost blows things apart or the engine glows red from lack of cooling and melts. The amount, of fuel and oxygen that combine, creates the heat that expands the air mass and moves the piston. It is that simple. Keeping it together is the challenge. You literally have to keep breaking things, and coming up with new engineering solutions to the causes of those things breaking, to know what the answer is to the question "How Much Power Can a 1600 Dual Port Make? We’re Finding Out!". _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
oprn Samba Member
Posted: Sat May 10, 2025 3:09 pm Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! |
It's been done with boost many times over. Clonebug is the master of this quest on this forum. Go look at his build thread for the answers. These fellows are on the same path now, headed in the same direction and if they go far enough will come up with pretty much the same results.
Mario at The Dub Shop did a very similar one not too long ago but are now headed down the special trick parts road.
I was following this one due to the fact that they were initially testing bolt on bits for a 1600 N/A engine (which has also been done before but not in recent times as far as I know) but they got bored of that long before I was hoping and went down this well travelled path instead.
It's still holding my interest mostly due to the grassroots down to earth fun they are sharing but the quest they are now on has certainly been done before. _________________ Our cars get old, we get old but driving an old VW never gets old! |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4130 Location: NW Washington
Posted: Sat May 10, 2025 5:54 pm Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! |
My best dyno run was 226 crank hp and around 255 lb. ft of torque but the engine didn't like it and it broke the ring lands on a couple pistons and also moved a small end rod bushing. All of that was below 5000 rpm. We were going to refresh the engine anyways so it was a test project....
Pushing an engine that hard will show it's weak spots especially on a dyno with multiple pulls.
Ignition advance and intake temps become a real issue especially on back to back dyno pulls as they found out.
Once you go over 15 lbs boost you need to be very careful.
I've said it many times that 130* F. is the critical point and the same posters call bullshit on it.
I'll bet they cracked their ring lands if it started puffing steam and they did it at 18 lbs boost......guess what temp the intake air was at that boost level????
Doing the math if draw thru can remove 100* F. intake temp from venturi effect..... at 100* F. inlet temp the IAT's at 18 lbs. boost would be 242* F. minus the 100 degrees of venturi effect....which puts it at 142 degrees........and that is a guess.
In an enclosed room it could have been more or less but at 20 plus degrees timing it was a ticking time bomb. Add a couple back to back pulls where the piston temp was high due to the load and.....boom.
I rest my case.......
There are quite a few 1600 challenge engines in Sweden and the surrounding area that have far exceeded anything I can imagine at over 400 hp.
They do use a big cam and rev to 8000 rpm but use stock heads, cranks and rods and get amazing results. They also use E-85 and massive intake plenums with very efficient intercooler setups.
Looking at the dyno graphs they have almost nothing below 4500 rpm but it is a steep ramp after that. It takes aggressive driving skill and antilag boost control to stay in the power band for consistent 1/4 mile times....something my daily driver isn't set up for. _________________
richardcraineum wrote: |
I'm so ignorant of efi I don't even know the difference between batch, sequential blah blah blah .. |
cbeck wrote: |
His user name in a previous life was dick head. |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2788 Location: HdG, MD & NJ
Posted: Sun May 11, 2025 9:58 am Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! |
I just never heard of draw through being illegal in some cases. It’s always been popular at the track to this day. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
BFB Samba Member
Posted: Sun May 11, 2025 11:26 am Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! |
clonebug wrote: |
Im curious how you came up with IAT being 242*F ? _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
MTT3107 Samba Member
Posted: Tue May 13, 2025 3:09 pm Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! |
I found this whole series a bit silly...
IMHO, natural progression should have been :
Headers
Dual carbs
Ratio rockers
And so on..
Instead, they went with that goofy setup, blowing air from the heater vents into the carb.
Then, installing a oxygen sensor ?
I think that there are very few folks who would actually do that.
And instead of testing a good combo of headers, dual carbs, etc., they went straight to a turbo setup...
Again, how many folks do actually do that ? |
BFB Samba Member
Posted: Tue May 13, 2025 5:35 pm Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! |
why waste money on " good headers , dual carbs, etc.." on a stock 1600 that does virtually nothing compared to boosting it? one of the first things I did to the first buggy I had was boost it.
I think if you have that mentality that you have to buy this and that part then you've swallowed the corporate sales kool-aide.
I do wish they'd have done other stuff before jumping to the turbo but really, there wasnt much more left to do.
if my performance options on any stock engine was either headers, carb(s), intake, etc. OR boost the stock engine, id always choose to boost the stock engine.
but yeh your right, probably not many do that. gotta get all the chrome, billet, and A/N fittings first
also, still waiting to see how clone bug came up with their 18lbs of boost being 242* F. ???? _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
EVfun  Samba Member
Posted: Tue May 13, 2025 10:10 pm Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! |
BFB wrote: |
also, still waiting to see how clone bug came up with their 18lbs of boost being 242* F. ???? |
The formula for the heating of air from compression:
T2 = T1 * (P2/P1)^((y-1)/y)
T2 is the final temperature, in Kelvin
T1 is the initial temperature, in Kelvin
P2 is the final pressure
P1 is the initial pressure
y is the Adiabatic Index (for the air we breathe that is about 1.4)
I start by reducing the right part of equation.
((1.4-1)/1.4) = 0.2857
Atmospheric pressure is about 15psi, and he want to boost it another 18psi, so the pressure change is:
P2/P1 = 33/15 = 2.2
degrees Kelvin equals degrees Celsius + 273.
25C = 298K
T2 = 298 * 2.2^0.2857
T2 = 373.3K = 100.3C
So, that means just the compression is expected to heat the air to 212.5 degrees Fahrenheit, plus I expect it will pick up some exhaust heat from passing through the turbocharger.
Thank you for making me dust off the old math formula and plugging some number into it for practice. _________________
Wildthings wrote: |
BFB Samba Member
Posted: Wed May 14, 2025 7:47 am Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! |
EVfun wrote: |
BFB wrote: |
P2/P1 = 33/15 = 2.2
25C = 298K
Thank you for making me dust off the old math formula and plugging some number into it for practice. |
ok ok... thanks for posting that.
I'll be the first to admit my math skills are a little weak, and even though I had to do a little googling to grasp this , I think I got it.
but here's a problem I have with this, and correct me if I'm wrong. this formula if for calculating the heat of air from compression, then according to it the air in my shops compressor @ 180 psi would be 347* C or 656* F.
ive never put a thermometer in one of my compressors tanks but I can be pretty certain that they are no where near 650F , matter fact not even 200F because I can touch the tank ( holding said compressed air ) at any time and its no warmer than ambient air temp.
and if we take this a little further , what about the compressed air tanks that hold 1000+ psi?? if this formula ya'll use is applicable then that thing should be reaching nuclear melt down temps...
so rationally this makes no sense.
if you think of it in terms of an engine's cylinder pressure and that air charge being compressed 20:1 and it reaching those temps , sure that makes sense. I mean that's how diesels work and pre-ignition happens.
but theres no way in hell you ( generally speaking, not you specifically) can say that @ 18lbs of boost the IAT's will be 242*F AND have factored in addition temps from exhaust heat transfer, but leave out heat dissipation through the piping and also disregard the turbo's efficiency, and what exhaust temps actually are, which vary in themselves. theres way to many variables in the equation and to disregard some while factoring in others is just biasing the numbers to suit 'your' agenda and exaggerating to try and prove your point.
im not saying that turbo IAT's dont get hot, sure they do. but they're not on the verge of nuclear melt down hot. and like ive said before you can't go around telling people that their shits going to melt down if its run past your determined temperature which is only 30*F higher than some people's ambient air temp. I think that's dumb & arrogant. and that's why some people decided to quote me in their signature because they're all but hurt about someone disputing their 'expert' opinion.
so yeh, im going challenge that whenever I see it because that 'theory' is based off of one vehicle and tests performed in one climate region while disregarding all others, and that's no way to substantiate a theory. _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
EVfun  Samba Member
Posted: Wed May 14, 2025 11:37 am Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! |
BFB wrote: |
EVfun wrote: |
BFB wrote: |
P2/P1 = 33/15 = 2.2
25C = 298K
so yeh, im going challenge that whenever I see it because that 'theory' is based off of one vehicle and tests performed in one climate region while disregarding all others, and that's no way to substantiate a theory. |
Generally speaking air compressors make efforts to cool the compressed air before it enters the tank. The compressor has finned cylinders and heads and often the air line to the tank is finned and/or excessively long to help cool the compressed air on the way to the tank. Then it mixes that still warm air into a much larger tank of air that has had some time to cool down. I know I don't want to grab the steel line from the compressor to the tank on my air compressor when its running!
As far as the specific suggestion that the air would be 242F, yeah, I find the specificity suspect. The intake air temperature would have an impact on the final temperature, as would heat loss in the plumbing and heat gain from the hot exhaust gas running through the other side of the turbo. My guess is the 242F number came from an estimate of gaining about 212 degrees from compression, gaining about 30 degrees of stray exhaust heat passing through the turbo, and moving the air through the system fast enough that plumbing losses would be minimal. That number (and your questioning it) is what prompted me to dig out the formula and see for myself if that amount of heating seemed reasonable. It pencils out to me as a reasonable estimate. Of course, an intercooler and/or water injection (evaporative cooling) could be used to cut down the intake air temperature. _________________
Wildthings wrote: |
Dan_Lockwood Samba Member
Joined: October 03, 2023 Posts: 433 Location: Clare MI
Posted: Wed May 14, 2025 11:39 am Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! |
I touched the feed line from the two-stage high pressure cylinder that feeds the tank by accident and got a really bad burn from it. Once the air hits the expanse of the tank, I believe it cools quite fast to an average temp of hotter than ambient. |
Posted: Wed May 14, 2025 12:00 pm Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! |
Quote: |
gotta get all the chrome, billet, and A/N fittings first |
Of course, all that stuff brings at least 20 hp....
But seriously, for most folks, a turbo is too much.
You also have to consider $$$
I looked around, and the cheapest turbo kit I could find, is over $2k...
And that's just the kit, surely once you get to installing it, more costs will pop up..
But to each his own ! |
Alexander_Monday Samba Member
Joined: November 09, 2007 Posts: 365 Location: Springfield Missouri
Posted: Wed May 14, 2025 3:22 pm Post subject: Re: How Much Power Can a 1600 Dual Port Make? We’re Finding Out! |
Just for comparison, here is the discharge temp curve of my 1.5L twin screw supercharger at 2 bar with 68F inlet temp.
Turbo should be quite a bit more efficient at the lower end, about the same in the middle and a little more efficient at the upper end.
So at 2.25 bar the math probably isn't too far off.
Degrees F on left, Drive RPM on bottom.
At the end of the day though, after water to air intercooler only 3F to 10F rise logged so an intercooler absorbs a lot of heat.
_________________ Danth’s or Parker’s Law:
“If you have to insist that you've won an internet argument, you've probably lost badly.”
Alexander_Monday->What were the rings gapped at?
bedlamite->Almost enough.
andk5591 wrote: |
The original german engineers have attained sainthood and it is impossible to improve perfection.
Anything that anyone does to deviate from the original designs will be made to wrench on 20 year old Yugos with Harbor Freight tools in hell. |
