AJT Samba Member
Posted: Sun May 11, 2025 1:29 pm Post subject: Brake return spring - refitting the lever HELP |
Hi
I’ve removed a broken spring on a 77 Dual and had to drift out the axle stub it’s locked onto.
How do I reinstall it? Obvs I need to align the serrated slots but how do I then push the lever back onto the shaft? Tks.
SGKent  Samba Member
Joined: October 30, 2007 Posts: 43009 Location: at the beach in Northern Wokistan
Posted: Sun May 11, 2025 2:10 pm Post subject: Re: Brake return spring - refitting the lever HELP |
This is a right hand drive bay for left hand traffic. Maybe someone who has worked on, or owned one will chime in. Most of our buses here in the US and Canada are left hand drive. There are some buses in Australia too that are right hand drive.
Might check with any clubs in the orange colored areas. Wish I knew more but have never been in one or worked on it.
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"
1971 deluxe (sold)
1977 deluxe |
AJT Samba Member
Posted: Mon May 12, 2025 11:15 am Post subject: Re: Brake return spring - refitting the lever HELP |
Thanks.
This was a pain to reinstall. You need to marry up the serrated shaft with the serrated lever, all while looking thru a 2” inspection hole.
For reference, I marked the serrated sections on the end of the shaft and the outside of the lever so I could align them while looking thru the hole. After much shouting i managed to hammer the lever on using a 28mm impact socket and a short ½” extension bar. At the other end of the shaft I wedged a piece of wood to stop the shaft moving.
Refitted the bolt - do not forget to do this before fitting the spring. The spring itself is quite easy to fit - I used a seal puller initially then finished the install with a screwdriver. |
