early Samba Member
Joined: January 19, 2012 Posts: 291 Location: Glen Carbon, IL
Posted: Mon May 12, 2025 1:03 pm Post subject: 1835 Bus build Rattle. |
I have a rattle coming from the front crank snout. it is audible and continues until it warms up a bit.
it seems like it is camshaft backlash and goes away as the gear warms up, sounds weird i know.
wondering if anyone has had a similar situation.
this is my 1835 Bus engine i built last year.
Camshaft is a Webcam 86 dash 5 with CB lightweight lifters, CB aluminum pushrods and AA slipper foot rocker arms that come out to about 1.34 .
i thought the sound was valve train and took the rockers off and re-shimmed them to a loose zero and adjustment is .006.
the Cam gear is -2 Magnesium VW gear drilled and spot faced for new cam use that i got from Berg. and when i first set it up the backlash felt good as gold.
when i took this engine apart the first time it had a -2 Gear in it so that is why i used the -2 but after reading about the codes under the distributor my block is stamped WD which equates to a -4 cam gear ( according to the chart i have seen on here) so that would put me off .02mm on gear size, so that makes sense.
now this engine did not make this noise until about a month ago and it has less than 1000 miles on it since last years build.
here's a couple youtube videos of it running and one of the borescope i sent down to look at the crank gear, gear shows a little bit of scratching on it.
if you local gurus could have a look and a listen and give me your opinions i would be thankful. my next step would be to pull the oil pump and inspect the gear itself.
thanks in advance guys
https://youtu.be/lDsvS_6MtHQ
https://youtu.be/DwQzIJkgUBk
borescope
https://youtu.be/OFU2pfKU46Y
edit added this cam stamp post:
https://www.thesamba.com/vw/gallery/pix/2532111.png
Dave Becker Samba Member
Joined: October 16, 2003 Posts: 160 Location: Australia
Posted: Mon May 12, 2025 1:28 pm Post subject: Re: 1835 Bus build Rattle. |
I had a similar thing happed to an engine I built, pulled it down and found the cam thrust was way off and rattling, AA dual thrust cam bearings Engle 100 cam, thrust clearance was set correctly when the engine was built.
I have noticed AA cam bearing "settle in" so now clearance them after assembling the case with the cam and bearings in place and giving both ends of the cam a couple of taps with a copper drift, no problems since. _________________ FAHRVERGNUGEN;
Description of a pleasurable sensation,
Experienced when a car and it's driver are in mutual harmony, A unique driving experience, Pleasure, Satisfaction,
A feeling experienced by Volkswagen Drivers. |
early Samba Member
Posted: Mon May 12, 2025 1:33 pm Post subject: Re: 1835 Bus build Rattle. |
| Dave Becker wrote: |
I have noticed AA cam bearing "settle in" so now clearance them after assembling the case with the cam and bearings in place and giving both ends of the cam a couple of taps with a copper drift, no problems since. |
thanks for the reply .
i used Mahle Single Thrust (didn't think my engine was HotRod enough for dual, oh well)
set it up with .002 clearance
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42997 Location: at the beach in Northern Wokistan
Posted: Mon May 12, 2025 2:51 pm Post subject: Re: 1835 Bus build Rattle. |
the issue with the cam thrust is that sometimes it changes if the bearings are a bit spread. Have you checked the end play on the crankshaft? _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"
1971 deluxe (sold)
1977 deluxe |
early Samba Member
Posted: Mon May 12, 2025 3:06 pm Post subject: Re: 1835 Bus build Rattle. |
| SGKent wrote: |
| the issue with the cam thrust is that sometimes it changes if the bearings are a bit spread. Have you checked the end play on the crankshaft? |
End play was .004 at time of build. It's a little bit difficult to check it at this point since it is still together but there is no noticeable end play that can feel.
_________________ early-
Barnfind westy project
my 73 sports bug project build
http://www.thesamba.com/vw/forum/viewtopic.php?t=497088
Current Projects :
73 Sport Bug - L13M gone now
67 Westfalia
57 oval window ragtop - sold june 2021
61 sedan
68 Corvette Roadster - Small Block, 4 Speed
86 GMC Sierra Classic- 4x4, Shortbed
94 Harley Flstn |
veedubcrazy Samba Member
Joined: February 14, 2005 Posts: 2193 Location: La Porte, Tx.
Posted: Mon May 12, 2025 3:14 pm Post subject: Re: 1835 Bus build Rattle. |
Cam sliding back and forth in its bearings? Could be gear wore down the thrust... Check that oil to see if it looks like graphite... _________________ 1967 Deluxe Sedan
1971 Squareback - "The Silver Surfer" |
Brian_e  Samba Member
Joined: July 28, 2009 Posts: 4317 Location: Rapid City, South Dakota
Posted: Mon May 12, 2025 3:23 pm Post subject: Re: 1835 Bus build Rattle. |
I had one start doing this, and mine ended up being the cam gear.
Without stripping it, I pulled the oil pump cover off, and pulled the top gear out. Then I stuck a big screwdriver in the hole, and turned the cam back and forth to see if there was excessive backlash in the cam gears. I think i also rolled the engine over to TDC when I did it. Maybe I took the rockers off to relieve spring pressure? That was a really long time ago.
Brian _________________ So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts |
early Samba Member
Posted: Mon May 12, 2025 3:38 pm Post subject: Re: 1835 Bus build Rattle. |
| Brian_e wrote: |
Brian |
That was my next thought. Take pressure off the cam and pull pump cover off , top gear and screwdriver checking gear movement.
Veedubcrazy - oil is clean, I took filter apart and checked it really well .
In either case I'm not happy with it. The funny thing is after it runs for a few minutes it goes quiet and runs like it should.
Videos are cold start so you can hear it, noise is more prominent in 2nd video.
Borescope video is not the best but you can see where crank gear has some shiny spots where it's moving.
Thanks for your responses. _________________ early-
Current Projects :
67 Westfalia
61 sedan
94 Harley Flstn |
74 Thing Samba Member
Posted: Mon May 12, 2025 3:56 pm Post subject: Re: 1835 Bus build Rattle. |
I think you can see the cam gear teeth through the fuel pump block off area.
As Brian E indicated above, maybe pull the rockers then the oil pump cover and remove the upper oil pump gear and see if the cam gear backlash is excessive using a screw driver (may sure you do this to maybe 4-6 spots while rotating since it can be loose on one side and just right on the other). |
Posted: Tue May 13, 2025 8:17 am Post subject: Re: 1835 Bus build Rattle. |
| Brian_e wrote: |
Brian |
I've read this a couple times and it reminded me of HVW magazines doing an April Fools write-up how to remove a cam gear out the oil pump access hole.  _________________ 1967 Deluxe Sedan
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 3390 Location: Memphis
Posted: Tue May 13, 2025 7:17 pm Post subject: Re: 1835 Bus build Rattle. |
That first video sounds almost like the fan rattling. Did the noise change any with the fan belt off?
It could also be a loose crank pulley. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
early Samba Member
Posted: Tue May 13, 2025 7:34 pm Post subject: Re: 1835 Bus build Rattle. |
| scrivyscriv wrote: |
It could also be a loose crank pulley. |
listen to the second video, much better, and no the crank pulley is tight and yes i had hoped it was the fan belt or fan but it's not. checked that stuff right away.
second video about half way through and you can hear what i think is cam gear backlash. _________________ early-
Current Projects :
67 Westfalia
61 sedan
94 Harley Flstn |
Posted: Tue May 13, 2025 7:43 pm Post subject: Re: 1835 Bus build Rattle. |
| You can test for sure by removing the fan belt for a min at idle. |
modok Samba Member
Joined: October 30, 2009 Posts: 27757 Location: Colorado Springs
Posted: Tue May 13, 2025 8:18 pm Post subject: Re: 1835 Bus build Rattle. |
Don't want to jinx it, but maybe the gear is loose on the cam.
I always bathe those bolts in 640 green sleeve retainer like Berg, and IMO never use star lockwashers on magnesium, and probably not on aluminum either.
Maybe I'm paranoid.....or maybe I'm not. I don't know.
Also now and then you can get abnormal wear on the cam gear if the crank gear is distorted, and that can happen if the key is too tight in the gear.
Loose pulley or flywheel or fan or generator pulley also possible.
Or the cam ate the thrust bearing.....tho I doubt it with a WEB cam, but some of the other companies forget to mask off the thrust faces when they parkerize the cam and that sure doesn't help things.
I didn't watch the vid, just covering all the usual suspects. |
Posted: Tue May 13, 2025 9:52 pm Post subject: Re: 1835 Bus build Rattle. |
Remove the fan belt to eliminate a loose belt/alt pulley or fan.
Also do what Modok suggested and check the crankshaft pulley bolt and maybe pull the pulley off and inspect the snout area.
If those don't work then pull the oil pump cover. The teeth on the cam gear look ok in your borescope, but you should check it on 4 spots 90 degrees apart in case it is worn in one area and not consistently worn throughout. |
early Samba Member
Posted: Sun Aug 17, 2025 1:27 pm Post subject: Re: 1835 Bus build Rattle. |
latest update:
engine is pulled and on the workbench stand. Stripped down to the long block. checking a few things before i tear into it.
Here's a borescope video thru the generator stand hole, showing the Crank gear and the Cam gear as i rotate the crank with a ratchet. you can see the obvious play in crank / cam gear mesh as i begin to rotate.
it almost looks like the crank gear is loose at the keyway and floating a little bit.
I'll tear it down this week and get a better diagnosis of what this is. anyone care to guess what is loose? crank gear, cam gear, keyway, or combination of all.
here's the video:
https://youtu.be/GaH0bkdJ0QI
cheers... early _________________ early-
Current Projects :
67 Westfalia
61 sedan
94 Harley Flstn |
Posted: Sun Aug 17, 2025 3:19 pm Post subject: Re: 1835 Bus build Rattle. |
| early wrote: |
latest update:
here's the video:
cheers... early |
If its and aluminum cam gear, I am betting the teeth are worn down, and increasing the backlash. Or the cam bolts are loose.
-Modok
db69 Samba Member
Posted: Sun Aug 17, 2025 5:49 pm Post subject: Re: 1835 Bus build Rattle. |
| Looks like crank gear is slipping on the crank to me. |
early Samba Member
Posted: Sun Aug 17, 2025 6:22 pm Post subject: Re: 1835 Bus build Rattle. |
| db69 wrote: |
That's what it looks like to me but, it also looks like crankshaft is turning same speed.
Also, to Brian e, it's a vw magnesium gear . From berg.
Anyway, ill find out tomorrow as I tear into it. _________________ early-
Current Projects :
67 Westfalia
61 sedan
94 Harley Flstn |
RWK Samba Member
Posted: Mon Aug 18, 2025 6:04 am Post subject: Re: 1835 Bus build Rattle. |
Another trick for locking cam bolts is to peen the end of the bolt where it comes through the cam, this distorts the thread so it can't back out, and no washers to break and come apart! I have used rivets also like the factory, they eliminate all movement because they expand in the hole unlike a bolt which has clearance in the hole. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
