Flipping rear trailing arms
balljoint
balljoint is offline
PostPosted: Sat May 10, 2025 6:06 am    Post subject: Flipping rear trailing arms Reply with quote
Anyone has any proof of this being done to reduce negative camber on a bus?
It's an ongoing journey, never forget where you came from....
65 rhd Beetle
72 rhd kombi
SGKent Premium Member
SGKent is offline
PostPosted: Sat May 10, 2025 9:10 am    Post subject: Re: Flipping rear trailing arms Reply with quote
what steps have you taken to reduce negative camber on your bus and what are the measurements now?
George Carlin:
Skills@EuroCarsPlus:
1971 deluxe (sold)
1977 deluxe
balljoint
PostPosted: Sun May 11, 2025 7:50 am    Post subject: Re: Flipping rear trailing arms Reply with quote
I have 3.5 horse shoe plates and one outer spline down. Looking to get a degree wherever I could
65 rhd Beetle
72 rhd kombi
SGKent is offline
PostPosted: Sun May 11, 2025 2:27 pm    Post subject: Re: Flipping rear trailing arms Reply with quote
you might have better luck searching thru this thread, and asking here.
Lowering a Bay
George Carlin:
1971 deluxe (sold)
1977 deluxe
balljoint
PostPosted: Tue May 13, 2025 5:53 am    Post subject: Re: Flipping rear trailing arms Reply with quote
So I put new bushings in the arms bolted them in place on the same same side, one flipped obviously, and they measured out the same with an angle finder so I guess it's not a "thing" when it comes to busses. Don't believe everything on th interwebs d'oh!
65 rhd Beetle
72 rhd kombi
Clatter
Clatter is offline
PostPosted: Tue May 13, 2025 8:40 am    Post subject: Re: Flipping rear trailing arms Reply with quote
Nice work.
Good to have someone try IRL.
Sounds like it's time for a torsion raise?
Saw one once where they converted to swing and just raised the trans...
The KCW forums used to have a few really dumped buses with extensive how-tos on severe lowering.
C-notches, etc.
That site is gone now but snapshots are on the wayback machine.
Look around about maybe 2011 or so..?
Bus Motor Build
It does not exist!
