Why are the running lights unfused?
talljordan
talljordan is offline
PostPosted: Mon May 12, 2025 9:24 pm    Post subject: Why are the running lights unfused? Reply with quote
As seen in the wiring diagram, the running lights are unfused, they connect to terminal 7 of the fuse box, but not on the fused side.
Why leave them unfused? Having a hot unfused wire behind the dash seems risky. And fuse 7 is also unused!
For the time being Ive moved it to the fused side of the terminal, but Im curious if there is a reason VW may have done this.
Edit: To be more clear, I know the lights themselves are fused via F1, but having the hot supply to the headlight switch be unfused feels unsafe?
1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end
sctbrd
sctbrd is offline
PostPosted: Mon May 12, 2025 9:59 pm    Post subject: Re: Why are the running lights unfused? Reply with quote
Headlights automatically turn off with the ignition switch, but parking lights stay on (see picture)- "parking lights" are for when you park the car but want to keep it visible.
Note at bottom "compulsory in some countries"- there were laws that parking lights had to be left on when parked in certain cases.
bsairhead
bsairhead is offline
PostPosted: Mon May 12, 2025 11:30 pm    Post subject: Re: Why are the running lights unfused? Reply with quote
A fuse can blow. The wire sizing was the equivalent to a fusible link.
baldessariclan
baldessariclan is offline
PostPosted: Tue May 13, 2025 5:23 am    Post subject: Re: Why are the running lights unfused? Reply with quote
If you look at the factory wiring diagrams for these cars, you’ll generally find a significant amount of unfused circuits and components, here and there. Why did VW do it that way? And is it “unsafe”?
Not 100% sure on all of VW’s motives / logic, but it seems to have worked just fine, and isn’t particularly unsafe either, or at least not by standards of the day these cars were built in. I don’t recall ever seeing or hearing about them catching on fire right and left due to the wiring behind the dash. If the connections are tight & secure, and area is properly covered, pretty much a non-issue (in my opinion, anyway).
What I do recall causing lots of electrical fires in all sorts cars when I was younger was teenagers (and some adults, too) installing custom wiring, stereos, lights, etc. Off top of my head, can remember at least a half dozen or more folks I know who had car fires caused by that sort of thing… Sad
Schepp
Schepp is offline
PostPosted: Tue May 13, 2025 7:29 am    Post subject: Re: Why are the running lights unfused? Reply with quote
If it really bothers you, you can create you own harness or buy a universal one that utilizes relays and go that route.
I replaced my harness with the JBugs full harness and added a separate standalone harness with relays for anything that isn't factory VW.
Like stated above, the wire gauges were proper for the factory accessories running on the factory circuits. Start adding things like an electric heater or a stereo etc.
With such a long run from the battery location, the factory wires can over heat real quick when over loaded.
ashman40
ashman40 is offline
PostPosted: Tue May 13, 2025 1:51 pm    Post subject: Re: Why are the running lights unfused? Reply with quote
Since we are talking about parking lights (front and rear) you should also be asking yourself WHY did VW place ALL but one parking light onto fuse #1 and just leave the left rear parking light all by itself on fuse #2???
If you do the calculations, a single 8A fuse is sufficient to power all four of the 5W corner parking lights and the license plate lamp. You could have powered them from a single 8A fuse. Why did VW chose to move the grey/black left rear parking light circuit onto its own 8A fuse? For redundancy (or resiliency?).
With all parking lamps on a single fuse, an overload would take out ALL your parking lights while driving down the road or parked. You would not know but from behind you would be invisible and someone could come up and rear end you, not seeing you were there.
But having one of your rear parking lights on its own fuse means you need to short two circuits to loose all parking lights. You will still be visible even if one of your parking light cicuits blew its fuse.
Unfortunately, by moving the headlight switch source #30 red wire to the protected (output) side of fuse #7 you have created the "single point of failure" VW removed by having 2 parking light fuses. When fuse #7 blows you will loose ALL parking lights.
VW's method of using a single circuit parking light switch to control all parking lights but have two parking light circuits for redundancy is cheaper than to create a fully dual circuit parking light switch to feed two different parking light circuits. A dual circuit parking light switch could have the fuses placed in front of the switch... but the switch would be much more expensive! Not VW's way. Shocked
Also, switches are not designed to fail. You assume they will work for many years. Fuses though, are by design meant to fail and protect the wiring. VW planned for fuses to blow but worked to keep the driver safe with redundancy/resiliency but kept the single circuit parking light switch.
AshMan40
sb001
sb001 is offline
PostPosted: Wed May 14, 2025 1:05 pm    Post subject: Re: Why are the running lights unfused? Reply with quote
I know that's what my dad probably THOUGHT happened when I installed an aftermarket stereo system in the bug in spring of 1990 and then it caught fire in the summer. But it's not.
I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Bosch 113905205AE autostick distributor
DUNGBTL Premium Member
DUNGBTL is offline
PostPosted: Wed May 14, 2025 1:27 pm    Post subject: Re: Why are the running lights unfused? Reply with quote
This.
OldSchoolVW's Premium Member
OldSchoolVW's is offline
PostPosted: Wed May 14, 2025 3:34 pm    Post subject: Re: Why are the running lights unfused? Reply with quote
The 10 gauge feed from voltage regulator B+ to the fuse panel is unfused and passes through pretty inaccessible areas, so a short in that wire would likely create a time-consuming rewiring project. If concerned about protecting that wire, a 30A circuit breaker could be installed near the battery like this:
The wire going from the fuse panel to light switch (E1) 30 is only 16 gauge, so to protect that you could use a 10 or 15A inline fuse ... an easy add-on if it makes you feel more comfortable.
BTW ... using the nomenclature for these diagrams, "F1" references the oil pressure switch rather than shorthand for "fuse 1". So, initially, a little confusing for the reader.
Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
talljordan
PostPosted: Wed May 14, 2025 7:14 pm    Post subject: Re: Why are the running lights unfused? Reply with quote
I appreciate the response ashman, I figured you would have a good reasoning.
That said, because in 1972 VW moved the headlight power to switched power, if I lose fuse7, I still have headlights and brake lights. So not like I have no lights.
But overall this logic holds up to me.
ashman40
ashman40 is offline
PostPosted: Wed May 14, 2025 10:57 pm    Post subject: Re: Why are the running lights unfused? Reply with quote
Parked on the side of an unlit road with just your headlights ON... the rear of your Beetle is still invisible without "parking" lights or the license plate lamp.
Just know that given that you now have the #7 fuse carrying the load of both parking light circuits, if there is a short or overload that would normally blow either the #1 or #2 fuse individually, it will likely be fuse #7 that burns up FIRST as it will always see the combined load of both circuits. This assumes fuse #7 is a white 8A fuse.
And if you decide to leave fuse #7 in place ahead of the headlight switch, you could conceptually wire the headlight switch #58 output directly to all four of the parking light circuits; freeing up 2 fuses from the fuse box for some other purpose.
Having said that, it is no worse a situation than most modern cars that have only a single fuse for all parking lights.
I suppose putting the license plate lamp on a separate fuse would also help keep you visible, but VW chose to basically make the license plate lamp a 5th parking lamp; extended from the right rear parking light. This means you cannot easily put it on its own fuse without running a new wire almost the entire length of the car. Shocked
AshMan40
talljordan
PostPosted: Thu May 15, 2025 10:28 am    Post subject: Re: Why are the running lights unfused? Reply with quote
Yeah I may revert my change and just add some insulation around the hot terminal on the headlight switch to avoid short potential.
I'm a smidge torn, I always carry spare fuses, so if I lose lights I can always swap it in., and I would rather blow a fuse than start a fire. But fire risk also seems very low.
