sb001 Samba Member
Joined: May 19, 2011 Posts: 10458 Location: NW Arkansas
Posted: Wed May 14, 2025 1:17 pm Post subject: What is this loud "thump/ pop?" |
So after my bug has sat for a few hours, and I go to drive it, I put in any gear (reverse, Drive 1 etc) and hit the gas, it doesn't move initially (like the e-brake is still on) and then if I press the gas more, there is a sudden "POP" that sounds like it comes from the right rear side of the car and it releases, and it feels like that side of the car actually rises up as the car begins to move and then comes back down, like it's rolling over something only on that side. Only does it that one initial time and then it's fine.
But, after driving a bit and everything warmed up, if I park it for a bit (like going to the store) and then get in to drive it again, it does not do it.
Only after the car has been parked for a few hours or more, and then it does it again every single time.
My first thought was rear brake shoes rusted to drums, but they can't re-rust themselves to the drums in that short a period of time. Something to do with the rear torsion bar perhaps??
Any suggestions appreciated _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
nogoodwithusernames Samba Member
Joined: November 10, 2014 Posts: 654 Location: CA, USA
BMFBMF Samba Member
Joined: November 13, 2020 Posts: 465 Location: Swtzerland
Posted: Wed May 14, 2025 1:34 pm Post subject: Re: What is this loud "thump/ pop?" |
I'm guessing oval drums, as you ride. They warm up quite quickly and might not cause trouble but as soon as they cool down they could start catching again. _________________ -----Slava Ukraini-----
1971 Stock South African Beetle 1300 : My mom's european "Thin Chick" spec. Completely stock with torsion bar front, swingaxle rear, smooth hubs, single MC, 40 mm shoes, 31PICT3 carb and 5 bolt drums all round, currently Running a 1976 SF:AS engine with the original SF:AD engine overhauled in a box, waiting to go back in one day. |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4488 Location: viroqua wi.
Posted: Wed May 14, 2025 3:26 pm Post subject: Re: What is this loud "thump/ pop?" |
Could also be a rusty gland nut bearing. |
vamram  Samba Member
Posted: Wed May 14, 2025 4:38 pm Post subject: Re: What is this loud "thump/ pop?" |
Corrosion in the right rear cylinder that "rebinds" after a few hours...? _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 4149 Location: Georgia
Posted: Fri May 16, 2025 5:55 am Post subject: Re: What is this loud "thump/ pop?" |
Definitely a puzzle. If you park it in the garage I would park it. Jack it up, take off the wheel wait for it to cool down and see if you can turn the wheel by hand. See if you can hear where the popping comes from. You may have to pull the drum to see what’s going on. _________________ Volkswagen!
(Compression 8.7:1) |
a8ked Samba Member
Joined: April 06, 2024 Posts: 49 Location: Seattle area
Posted: Fri May 16, 2025 12:05 pm Post subject: Re: What is this loud "thump/ pop?" |
It might be a sticking EBrake lever inside the drum. A small dab of brake grease on the EBrake lever pivot pin might solve the problem. I've seen some very rusty ones that would hang up when the brake cable was released. |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 3342 Location: Memphis
Posted: Sat May 17, 2025 1:16 pm Post subject: Re: What is this loud "thump/ pop?" |
You’re describing a stuck brake.
Suspect the wheel cylinder and/or flex hose.
Additionally, if the drums and shoes are heavily worn, the cylinder pistons may be overtravelling and getting cocked in the bore. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25948 Location: Olympia Wash Rinse & Repeat
Posted: Sun May 18, 2025 10:41 am Post subject: Re: What is this loud "thump/ pop?" |
scrivyscriv wrote: |
Additionally, if the drums and shoes are heavily worn, the cylinder pistons may be overtravelling and getting cocked in the bore. |
Ditto, but possibly just a brake shoe rusted to the drum. Have had that happen over nite and sometimes one needs to shift back and forth between 1st and reverse to pop the shoe/s loose.
Have only once (with a daily driver that sat for over a week) in over fourty years that needed to additionally to pull a lug bolt to use a hammer and thin punch against the spine of the shoe to get it loosened. _________________ In Stereo, Where Available! |
sb001 Samba Member
Posted: Thu May 22, 2025 9:20 am Post subject: Re: What is this loud "thump/ pop?" |
Thanks for the suggestions
Eric & Barb this was my original thought I just thought there is no way it can re-rust to the drum in that short period of time, but maybe so.
Scrivvy I do also agree it is most likely brake related, and I thought about the wheel cylinder. At first chance I will try to get the drum off to have a look. _________________ I'm the humblest guy on this board.
1600 SP engine
volksworld Samba Member
Joined: November 26, 2011 Posts: 2580 Location: formerly NY currently NC
Posted: Thu May 22, 2025 10:13 am Post subject: Re: What is this loud "thump/ pop?" |
there may be brake fluid that has leaked onto the shoe making it stick to the drum when parked |
