1974BeetleSD Samba Member
Posted: Wed May 14, 2025 8:22 pm Post subject: no trans output shaft seal?!? |
So im back and i pulled the throwout bearing to change the leaky trans output shaft seal. Once i removed the throwout bearing and this metal tube, I see the following: is this an empty space where the seal is supposed to be??? I must be missing something, I can not believe the motor was installed without the output shaft seal. it is leaking, but a slow leak. (see old posts) what da hell??
Posted: Wed May 14, 2025 8:23 pm Post subject: Re: no trans output shaft seal?!? |
here is the seal i purchased.
Posted: Wed May 14, 2025 8:26 pm Post subject: Re: no trans output shaft seal?!? |
it probably wasnt leaking much because the trans was underfilled
can anyone confirm or deny if that seal is supposed to go there  |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33489 Location: Hot Arizona
Posted: Thu May 15, 2025 7:11 am Post subject: Re: no trans output shaft seal?!? |
| 1974BeetleSD wrote: |
I would tap in the seal, absolutely !!!
My 1971 Super is still on its factory transmission seal (it's been mine since 1976).
I have replaced the transmission seal on my 1970 (mine since 1972). The 1970 transmission uses the "early" style release bearing.
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Root_Werks Samba Member
Joined: December 31, 2007 Posts: 1080 Location: San Juan Islands
Posted: Thu May 15, 2025 1:55 pm Post subject: Re: no trans output shaft seal?!? |
Oh boy, yes, install a seal. That bellhousing looks pretty oily. Probably why. _________________ When I set my timing, why do I flush, then take a pee? |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4563 Location: viroqua wi.
Posted: Thu May 15, 2025 2:55 pm Post subject: Re: no trans output shaft seal?!? |
| White lithium grease is your friend. |
