thom Samba Member
Joined: October 12, 2000 Posts: 6340 Location: Sacramento
Posted: Sat May 17, 2025 4:01 pm Post subject: Re: What did you do for your Bus today? |
I had the dash ashtray re-chromed, and it looked awesome, but all of the tabs broke off when I tried to re-attach it (probably hydrogen embrittlement), so I glued it with Marine PC-11 epoxy
_________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15520 Location: Casa de Oro, California
Posted: Sat May 17, 2025 6:40 pm Post subject: Re: What did you do for your Bus today? |
| You glued the chrome lid to the ash holder? Or you glued the assembled ashtray to the painted dash? |
thom Samba Member
Posted: Sat May 17, 2025 6:49 pm Post subject: Re: What did you do for your Bus today? |
| BarryL wrote: |
I glued the lid to the ashtray _________________ -Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type |
thom Samba Member
Posted: Sun May 18, 2025 10:28 am Post subject: Re: What did you do for your Bus today? |
I polished and installed the rocker trims, and the WCM trim insert matches my paint perfectly
1956 Single Cab
1963 Unimog 404
1965 E-Type |
Buskraut  Samba Member
Joined: March 22, 2011 Posts: 92 Location: San Jose, CA 95125
Posted: Sun May 18, 2025 5:26 pm Post subject: Re: What did you do for your Bus today? |
Thom,
Your trim came out awesome... I'm just getting ready to do mine. Can you share your technique?
Also, sources for chroming are becoming far and few between... who did you use?
Thanks! _________________ Erik S
'65 Type 251 / Deluxe
'03 Eurovan MVWK |
thom Samba Member
Posted: Sun May 18, 2025 7:37 pm Post subject: Re: What did you do for your Bus today? |
| Buskraut wrote: |
| Your trim came out awesome... I'm just getting ready to do mine. Can you share your technique? |
I bought a bench polisher on amazon, a couple of wheels, and went to town. There's lots of online resources for this. I bought a two-speed unit, which was a good idea in hindsight, as it's easier to handle the smaller pieces at the lower speed.
| Quote: |
| Also, sources for chroming are becoming far and few between... who did you use? |
I used Sherm's plating here in Sacramento. I've also used Ogden chrome in Utah, which specializes in 'mail order' chrome plating, but you really have to be on them about the quality. They destroyed a set of Type 34 door handles; luckily I had a spare set and they re-chromed those for free. _________________ -Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type |
Posted: Sun May 18, 2025 8:02 pm Post subject: Re: What did you do for your Bus today? |
Thanks. I've got a variable speed HF grinder/buffer and various buffing wheels and compounds I've been experimenting with, but I'm not super happy with the results yet. I need a process aggressive enough to remove some light pitting, and then work my way up to the beautiful shine you have. _________________ Erik S
'03 Eurovan MVWK |
perello Samba Member
Joined: April 15, 2005 Posts: 906 Location: where social security comes for free
Posted: Mon May 19, 2025 1:34 am Post subject: Re: What did you do for your Bus today? |
blinded the heat riser holes
_________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
thom Samba Member
Posted: Tue May 20, 2025 9:29 am Post subject: Re: What did you do for your Bus today? |
| Buskraut wrote: |
| I need a process aggressive enough to remove some light pitting, and then work my way up to the beautiful shine you have. |
You're probably better off wet-sanding with a progression of 400/600/800/1000/1500 to handle the pitting. Start with the higher grit, if it's not working, then move down a grit until you start seeing results, then work back up. Rotary buffing is not going to remove pits unless you use a very aggressive compound. Remember, you're ultimately removing material to smooth out the pits. _________________ -Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type |
ComfortablyNumb Samba Member
Joined: February 19, 2025 Posts: 37 Location: Washington State
Posted: Tue May 20, 2025 9:35 pm Post subject: Re: What did you do for your Bus today? |
Today I ordered a Vintage Speed exhaust, a hitch from Jeremy Hoggard, and a new fuel tank and wiring harness from Wolfburg West. Good thing my bus is a camper because when the Visa bill comes in my wife will make me go live in it!
I still need to order a fuel pump, fuel line, and a German shroud and tin so I can get it back together and running. Also need to either get the carbs rebuilt or replaced as I suspect they, or at least one of them, was the cause of my troubles. |
Posted: Tue May 20, 2025 9:53 pm Post subject: Re: What did you do for your Bus today? |
Glued some vinyl on the rear quarter panel. Yeah, yeah, I know stock was painted, but IMHO the vinyl looks good and should wear well. Went overboard on the clamps because I hate puffy edges. Next is to add some piping.
'03 Eurovan MVWK |
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5660 Location: 1st Coast
Posted: Wed May 21, 2025 3:33 am Post subject: Re: What did you do for your Bus today? |
For me it's more like "What did your bus do for you today?". I used my repro ladder on my bus to help me store my 16' DN iceboat mast and the plank to the rafters in my garage. Little did I know I overworked my crappy knee and needed lots of fluid drained yesterday.
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
| Lind wrote: |
| Have you considered simply starting with a nicer bus? I don't know what your skills are, but the race is easier if you can see the finish line. If you are not a runner, don't start off doing a marathon. |
melville Samba Member
Joined: August 09, 2006 Posts: 1297 Location: Just Outside the Redwood Curtain
Posted: Wed May 21, 2025 8:23 am Post subject: Re: What did you do for your Bus today? |
Tell me about your Airhead! Is that an R100R? _________________ 2000 M Roadster
79 R100RS
78 R100/7
75 R75/6
65 Standard Micro
57 Sedan |
Pau Samba Member
Joined: April 09, 2002 Posts: 386 Location: Euskal Herria
Posted: Wed May 21, 2025 10:10 pm Post subject: Re: What did you do for your Bus today? |
| Pau wrote: |
Good morning.
I attacked the front nose again. Last time:
| Pau wrote: |
in one hour I did only the right corner of the nose.
I keep on going.
Cheers. |
Yesterday I spent three hours and I was quite satisfied with the result. The day before I spent almost the same time for passenger's door (only the white paint!!).
Gowing forward.
Have a nice day. |
_________________ Freedom for the Catalan Countries
Si ens destrossen les contrades alçarem les barricades !!*!! |
thom Samba Member
Posted: Tue Jun 03, 2025 9:18 am Post subject: Re: What did you do for your Bus today? |
My 1957 deluxe's original rebuilt and first run-in. It's a little noisy, so I'm going to re-adjust the valves this afternoon. I still need to build a new carb; I put a bug air cleaner on it because that's what I had at-hand - need to clean up and re-paint a bus air cleaner.
AA 80mm pistons and cylinders
AA H-beam rods
Wolfsburg West high-performance cam
019 distributor with Pertronix ignition
Vintage Speed muffler
1956 Single Cab
1963 Unimog 404
1965 E-Type |
Posted: Thu Jun 05, 2025 3:09 am Post subject: Re: What did you do for your Bus today? |
Sweet, I like your starting switch too.
| thom wrote: |
AA H-beam rods
Maui Roadsters
| Lind wrote: |
thom Samba Member
Posted: Mon Jun 09, 2025 7:14 am Post subject: Re: What did you do for your Bus today? |
More random assembly
1956 Single Cab
1963 Unimog 404
1965 E-Type |
thom Samba Member
Posted: Mon Jun 09, 2025 7:15 am Post subject: Re: What did you do for your Bus today? |
I should stick to commercial models: all of these deluxe bits are a PITA. I spent 4 hours yesterday getting the rear bumper to this point, and I probably have a couple more hours to go.
1956 Single Cab
1963 Unimog 404
1965 E-Type |
BarryL  Samba Member
Posted: Thu Jun 12, 2025 6:06 pm Post subject: Re: What did you do for your Bus today? |
Inventory some guts.
thom Samba Member
Posted: Sat Jun 14, 2025 8:40 am Post subject: Re: What did you do for your Bus today? |
Drove it for the first time today
1956 Single Cab
1963 Unimog 404
1965 E-Type |
