Schnitzelfuss Samba Member
Joined: September 18, 2024 Posts: 102 Location: North Alabama
Posted: Sat May 17, 2025 2:24 pm Post subject: Do popouts have a hinge pin at the B Pillar mount? |
I just bought a pair of nice OG popouts locally for my ‘66 and expected to see a piano-type hinge at the front where they screw into the B Pillar. There were none, just the S shaped vertical bracket attached to the trim with screws. When one opens the rear latch and pushes outboard how does the window pivot up front at the B Pillar without a pin? I didn’t see a piano hinge type pin depicted in the parts manual. |
my3bugs Samba Member
Joined: June 18, 2003 Posts: 727 Location: Moreno Valley
Posted: Sat May 17, 2025 7:17 pm Post subject: Re: Do popouts have a hinge pin at the B Pillar mount? |
Can’t say I’ve ever seen a hinge that has no moving parts. I’m trying to figure out how that solid piece of metal VW calls a hinge- secured to another solid piece of metal- the B Pillar, with screws- can allow the window to swing in and out when unlatched at the rear, or if I’m missing a part. |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6038 Location: 37.5N 77.1W
Posted: Sat May 17, 2025 8:03 pm Post subject: Re: Do popouts have a hinge pin at the B Pillar mount? |
the metal just flexes. Spring steel in a S shape. Doesn't move that much. _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
Posted: Sun May 18, 2025 4:08 am Post subject: Re: Do popouts have a hinge pin at the B Pillar mount? |
Thank you!
So they are flex hinges. Very old metal. Are they prone to cracking or failing? Or is that rare? Wondering if I should replace the originals before installing. |
Posted: Sun May 18, 2025 5:19 am Post subject: Re: Do popouts have a hinge pin at the B Pillar mount? |
Quote: |
should replace the originals |
I don't think it would be easy to remove or replace. I have never seen a replacement for that part. I've never seen a broken one either. The amount of movement they can take is quite a lot. I've seen the pop-outs extended twice the normal distance without breaking. _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
branston Samba Member
Posted: Sun May 18, 2025 7:02 am Post subject: Re: Do popouts have a hinge pin at the B Pillar mount? |
Schnitzelfuss wrote: |
Thank you!
I rebuilt dozens of popouts and have never seen a broken flex hinge, a few rusty and ugly ones, inspect them and refit them, if you need one, they are here on Samba or Wolfsburgwests reproduction is very nice too. |
Dusty1 Samba Member
Posted: Sun May 18, 2025 7:15 am Post subject: Re: Do popouts have a hinge pin at the B Pillar mount? |
Out of the hundreds of popouts I've bought and sold at swap meets I've seen maybe one window with a damaged hinge. It was on a "parts" Bug in the weeds before it landed in my swap meet stash.
Broken latches are way more common than broken hinges.
Posted: Sun May 18, 2025 2:18 pm Post subject: Re: Do popouts have a hinge pin at the B Pillar mount? |
Thanks all for the feedback, much appreciated! |
