Radial play in axles
Alexander_Monday
Alexander_Monday is offline
PostPosted: Sun May 18, 2025 12:43 pm    Post subject: Radial play in axles Reply with quote
Is this normal radial play for brand new parts?
It is total play for both sides.
Lobro T-2 CV's, no play in them.
The slop appears to be in the EMPI axle splines.
Danth’s or Parker’s Law:
“If you have to insist that you've won an internet argument, you've probably lost badly.”
Alexander_Monday->What were the rings gapped at?
bedlamite->Almost enough.
andk5591 wrote:
The original german engineers have attained sainthood and it is impossible to improve perfection.
Anything that anyone does to deviate from the original designs will be made to wrench on 20 year old Yugos with Harbor Freight tools in hell.
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Sun May 18, 2025 7:04 pm    Post subject: Re: Radial play in axles Reply with quote
Remove CV bolts, slide boot/flange on axle towards center. Reinstall CV bolts and look where play is while rotating back and forth.
Tell us what you find.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
Alexander_Monday
PostPosted: Sun May 18, 2025 7:30 pm    Post subject: Re: Radial play in axles Reply with quote
Play is in the splines on the side I didn't install.
No play in the who knows how many miles original 71 T1 assemblies.
I forsee bad things happening with 300+ HP.
Just ordered some early 944 OEM axles.
(Car had steel control arms and my understanding is they should fit)
Will see how the play is with them.
jsturtlebuggy
PostPosted: Sun May 18, 2025 8:44 pm    Post subject: Re: Radial play in axles Reply with quote
I have installed many EMPI axles with both stock Lobro and EMPI CVs and never seen or had any excess play in spline area of axle or CV.
Joseph
Elrod Motorsports
SGKent Premium Member
SGKent is offline
PostPosted: Mon May 19, 2025 10:45 am    Post subject: Re: Radial play in axles Reply with quote
check the torque on the axle nut. It may have been loose and worn both the flange/drum and axle.
George Carlin:
Skills@EuroCarsPlus:
1971 deluxe (sold)
1977 deluxe
Alexander_Monday
PostPosted: Mon May 19, 2025 12:02 pm    Post subject: Re: Radial play in axles Reply with quote
Torque on axle stubs is good.
I can see it is the splines in the other assembled cv's / axle that I didn't install.
