Split Bus 14" tires - modern equivalent to 7.00x14
Page: Previous  1, 2, 3, 4, 5, 6, 7, 8
BarryL Premium Member
BarryL is offline
PostPosted: Sat May 17, 2025 6:14 pm    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
Yes. When I first got my Standard it had 7 X 14s. It was squirrelier and they wore out super fast. But the spare tire well hits the holding lug hole for both sizes in the same place.
DanM
DanM is offline
PostPosted: Sun May 18, 2025 9:38 am    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
I haven't seen anyone mention these in this thread, but I like the Maxxis UE-168 Bravo. They're radial with the right weight / ply rating and the 205/0R14 gets you the 27" diameter of a bias ply 700-14 with a little more meat, but nothing crazy.
https://www.maxxis.com/us/tire/bravo-series-ue-168/
cdennisg
cdennisg is offline
PostPosted: Sun May 18, 2025 4:37 pm    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
That 205R14 C is an interesting size. I bet it would fit well on a bus meant for on road use. Or use as a steer tire combined with something a bit more rugged out back.
nothing
ted698
ted698 is offline
PostPosted: Mon May 19, 2025 8:03 am    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
I run 205R14C's on my UK bus, to max out the gearing with tyre size, although these only really bring it back up to the 27" diameter that the OG crossplies were... some of the modern radials are comically small, so the final gearing is all over the place.
I use Mazzini EffiVan - as they are a 'van' tyre they seem OK, and they're pretty cheap!
https://www.camskill.co.uk/m90b0s1673p181391/Mazzi...se%3A_72dB
Not sure if these are available in the States?
BarryL is offline
PostPosted: Tue May 20, 2025 6:44 pm    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
mandraks wrote:
BarryL wrote:
Here's a couple from farther away showing stance and size as you requested.
Basically stock.
Barry 185/14 may be stock replacement, but they are definitely much smaller in diameter compared to a 7.00/14. I remember back when i worked for a tire manufacturer just how much smaller they are compared to 7.00/14s. same thing with the 6.40/15 or 5.60/15 on the beetles. huge difference in diameter.
people did like the radials, of course, because they last longer, and they make you think your bus is faster and uses less gas per mile indicated. it just takes longer to get places and distances are suddenly longer....
I did the math:
184/ 14" go around one rotation 790 times in a mile.
7.00X14" go around one rotation 747 times in a mile.
cdennisg
cdennisg is offline
PostPosted: Tue May 20, 2025 7:48 pm    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
BarryL wrote:
mandraks wrote:
Basically stock.
I did the math:
And that math is variable. Different manufacturers build tires differently, and actual size/width/diameter will vary.
nothing
crofty
Judas of the North
crofty is offline
PostPosted: Wed May 21, 2025 6:46 am    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
I run these on all of my buses.
https://www.ebay.com/itm/382651774165
BarryL is offline
PostPosted: Wed May 21, 2025 12:02 pm    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
cdennisg wrote:
I was going by the 185/R/14 s in this chart vs the 27" ones commented on.
Now that you guys pointed out the size when I look at my bus I feel the 25.5" diameter tires have diameter envy.
Page 8 of 8
