Flywheel shim question
Page: Previous  1, 2
vamram Premium Member
vamram is offline
PostPosted: Sun May 18, 2025 8:50 am    Post subject: Re: Flywheel shim question Reply with quote
Not to hijack, but is it ok to run w/2 shims instead of 3 if the endplay measurement is w/in the .003-5 range w/just 2 shims?
'75 Super Le Grande...we hardly knew ye. Sold 2025 for peanuts.
Click to view image
Save the Supers!!
esde
esde is offline
PostPosted: Sun May 18, 2025 9:44 am    Post subject: Re: Flywheel shim question Reply with quote
yes, but
I always use more thin shims if I can.
It leaves more space for oil film, and more shims lessens the difference in speed between each shim surface.
When re-shimming an engine, I set them a little loose, in case there is some bearing movement that was not detected.
modok wrote:
panicman
panicman is offline
PostPosted: Sun May 18, 2025 10:20 am    Post subject: Re: Flywheel shim question Reply with quote
I don't think I wrote my posts very clearly, my apologies.
The videos were taken prior to torquing the flywheel gland nut. After really torquing it, that movement went away.
Also, the flywheel was installed with NO shims. Not metal, and not paper.
Given the measurements I provided, it sounds like I should order either a single shim, or a set of shims.
But I am totally new to this. How thick should my shim or shims be to provide the correct endplay?
chrisflstf
chrisflstf is offline
PostPosted: Sun May 18, 2025 10:43 am    Post subject: Re: Flywheel shim question Reply with quote
Put 2 shims in, then measure. Calculate for 3rd shim
txoval
txoval is offline
PostPosted: Sun May 18, 2025 11:34 am    Post subject: Re: Flywheel shim question Reply with quote
Your final endplay should be .003-.005”
Install that metal gasket, torque to 250 ft/lbs, and measure. Subtract .003” from that measurement to determine shim thickness
If you want to go with a single Porsche shim here is the link:
https://www.stoddard.com/porsche-356/porsche-356-engine/crankshaft-parts.html
panicman
panicman is offline
PostPosted: Sun May 18, 2025 12:11 pm    Post subject: Re: Flywheel shim question Reply with quote
Thanks!! Last question, my torque wrench tops out at 150#.
I measure 16" from the socket to the end of the handle, and I weigh 230.
If I apply all my weight to that wrench (feet off the ground) can I assume I got it to at least 250 ft pounds?
RickS
RickS is offline
PostPosted: Sun May 18, 2025 12:16 pm    Post subject: Re: Flywheel shim question Reply with quote
A torque wrench is not a breaker bar. It is a calibrated instrument. Treat it as such.
panicman
panicman is offline
PostPosted: Sun May 18, 2025 12:24 pm    Post subject: Re: Flywheel shim question Reply with quote
Fair enough.
If I use my half inch socket wrench and a cheater at 16" with my weight on it, will that achieve the 250 ft pounds needed?
Dale M.
Dale M. is offline
PostPosted: Sun May 18, 2025 3:05 pm    Post subject: Re: Flywheel shim question Reply with quote
panicman wrote:
Fair enough.
You will break your 1/2 drive socket and breaker bar, you need 3/4 inch sockets and breaker bar.....
Or a Torque multiplier...
OR....
Easiest way to increase torque wrench range with extension would be to make extension "A" same length as dimension "L"... To get torque value you double value as to what torque wrench is set at IE:132.5 X 2 = 265...
Personally I have one of these, it can apply 4 times the torque at output as what is applied at input....IE:66.25 X 4 =265
panicman
panicman is offline
PostPosted: Mon May 19, 2025 8:08 am    Post subject: Re: Flywheel shim question Reply with quote
Thanks Dale!
panicman
panicman is offline
PostPosted: Wed Jun 18, 2025 10:20 pm    Post subject: Re: Flywheel shim question Reply with quote
I got busy.
I did go ahead and order a new torque wrench. I also sourced one of the damn paper gaskets for the flywheel.
Tonight it got late, but I did get the flywheel on, and torqued it to 250#.
Tomorrow, I should be able to measure end play.
Page: Previous  1, 2
Page 2 of 2
