Door opens by it self on bumpy roads ?
mark d
mark d is offline
PostPosted: Sun May 18, 2025 4:15 pm    Post subject: Door opens by it self on bumpy roads ? Reply with quote
Yes i used search. There were 39 hits. If the answer is there I missed it.
1972 Westfalia (the one in the photo) she opens the drivers door on her own on bumpy gravel roads...maybe she is trying to tell me something ?
also occasionally when i try to close the drivers door it acts like it is hitting something solid. the piece that goes in the striker is in the correct position when this happens
as always any help would be appreciated thanks,
Mark
1972ish westfalia
"what good are tractors without violins ?" jose figueres
busdaddy
busdaddy is offline
PostPosted: Sun May 18, 2025 4:48 pm    Post subject: Re: Door opens by it self on bumpy roads ? Reply with quote
There really isn't a better way to describe door latch and striker check and adjustment than what is in the Bentley manual, it describes not only the latch's interaction with the striker but the part that pull rod and inner handle position plays, it even has pictures.
If you get all those properly dealt with and it still does it then latch wear is the next suspect.
Слава Україні!
mark d
mark d is offline
PostPosted: Sun May 18, 2025 4:53 pm    Post subject: Re: Door opens by it self on bumpy roads ? Reply with quote
thanks busdaddy. i will check my bentley when i get home. on my ship for another week
1972ish westfalia
mikedjames
mikedjames is offline
PostPosted: Mon May 19, 2025 11:14 am    Post subject: Re: Door opens by it self on bumpy roads ? Reply with quote
Lubrication might have something to do with it, I have had a sliding door that bounced and failed to lock until I lubricated the whole lock.
Alternatively the whole lock and striker are somehow adjusted so far out of alignment that it is only catching on the first detent..
All the locks on a VW originally have two detents for safety, quite often a front door can fail to go to the second detent if the rubber seal is stiff and it is closed too gently.
I have also had the striker on my sliding door worn half through causing the lock to bounce or fail to shut..I built it up with weld metal and filed it down.
Ancient vehicles and vessels
KTPhil Premium Member
KTPhil is offline
PostPosted: Mon May 19, 2025 11:39 am    Post subject: Re: Door opens by it self on bumpy roads ? Reply with quote
Order seat belts ASAP.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
Bnanwel
Bnanwel is offline
PostPosted: Mon May 19, 2025 11:44 am    Post subject: Re: Door opens by it self on bumpy roads ? Reply with quote
x2 on above. This is especially true with a lot of the replacement rubber. Sometimes you get rebound before the second detent catches. Close the door from outside lightly so only the first catches and then again harder so that you can “see” the difference. I would bet that is your problem.
‘72 Karmann Ghia Conv.
‘73 Karmann Ghia Coupe
‘74 Karmann Ghia Coupe
‘70 Deluxe
‘72 Deluxe
mark d
mark d is offline
PostPosted: Mon May 19, 2025 2:37 pm    Post subject: Re: Door opens by it self on bumpy roads ? Reply with quote
Thanks guys, will try all when I get home next week
1972ish westfalia
Abscate Premium Member
Abscate is offline
PostPosted: Mon May 19, 2025 3:04 pm    Post subject: Re: Door opens by it self on bumpy roads ? Reply with quote
Check the M plate to see if the Bus was made with the MIL code' for the military market,
Bnanwel
Bnanwel is offline
PostPosted: Mon May 19, 2025 8:09 pm    Post subject: Re: Door opens by it self on bumpy roads ? Reply with quote
Out of curiosity, do mil spec doors open by themselves to allow faster deployment?
‘70 Deluxe
‘72 Deluxe
Abscate is offline
PostPosted: Tue May 20, 2025 5:18 pm    Post subject: Re: Door opens by it self on bumpy roads ? Reply with quote
No, but they operate to command “ fall out”
Thanks for playing!
