Where to plug in portable fridge?
Muskrat
Muskrat is offline
PostPosted: Mon May 19, 2025 5:58 pm    Post subject: Where to plug in portable fridge? Reply with quote
Just picked up a a new to me Adventurewagen, that had the original galley removed, and a westy galley, sans fridge, installed.
Looking to get a chest fridge/freezer and wondering how people are powering it?
Not the battery setup, but where are you actually plugging in?
Was thinking of wiring a 12v outlet to the passenger pedestal, but would love to see what others have come up with
Cheers!
Manx clone 62 pan 1500 single port
83.5 westy w/2.1 wbx...RIP
Red Ryder
Red Ryder is offline
PostPosted: Mon May 19, 2025 6:35 pm    Post subject: Re: Where to plug in portable fridge Reply with quote
Several options to consider:
1. If you have an aux/house battery, you can simply add a fused 12v receptacle to connect the fridge power cord.
2. You can add a fused 12v receptacle to the primary battery — similar to what you suggest. Recommended while traveling only to avoid draining battery.
3. Purchase a rechargeable power station with adequate amp/hr rating to power the fridge directly. We use a 100w folding solar panel to recharge our power station.
“Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition (Tornado Red)
“Nigel” — 1999 Jaguar XK8 convertible (Alpine Green Metallic)
Muskrat
Muskrat is offline
PostPosted: Mon May 19, 2025 7:15 pm    Post subject: Re: Where to plug in portable fridge Reply with quote
Thanks, I have an aux bat setup, I'm more interested in where people are plugging in...surface mounted cigarette lighter outlet? Quick disconect plug, flush mounted outlet in the pedastal, cord run across the floor to the dash?
Wanna see what people have come up with.
MsTaboo Premium Member
MsTaboo is offline
PostPosted: Mon May 19, 2025 7:17 pm    Post subject: Re: Where to plug in portable fridge Reply with quote
Very common to install a receptacle on the B pillar near the sliding door.
When camped with power available we use the 120v receptacle on the Westy kitchen and place a small rug over the cord to keep from tripping.
Currently:
All that's needed for evil to prevail is for good people to do nothing.
Red Ryder
PostPosted: Mon May 19, 2025 7:36 pm    Post subject: Re: Where to plug in portable fridge Reply with quote
A portable fridge should come with two power cords. One will have a male plug for a cigarette lighter-type receptacle, and the other will have a standard 120v plug (with transformer). Locate and wire a single or dual socket 12v receptacle (shown in MsTaboo’s post) where it works best for you. Your Adventurewagen likely already has a 120v interior receptacle if equipped with an external shoreline plug.
tdivan82 Premium Member
tdivan82 is online now
PostPosted: Tue May 20, 2025 4:54 am    Post subject: Re: Where to plug in portable fridge Reply with quote
Consider using an Anderson Powerpole or other similar connector that does not wiggle loose with the bumps and vibration. I've found cigarette lighter plugs to not engage very well and often bump loose while driving.
- George
'82 Westy TDI (ahu)
'96 Passat TDI
snuf
snuf is offline
PostPosted: Tue May 20, 2025 5:42 am    Post subject: Re: Where to plug in portable fridge Reply with quote
I have been using an ARB Twist lock system-that plugs and locks securely into socket.
https://americanadventurelab.com/wp-content/uploads/2020/11/ARB-Threaded-Socket-5-247x296.jpg
https://www.amazon.com/gp/customer-reviews/R1OTDGWEVBT1YF?ref=dp_vse_ibvc_sml
Blue seas, https://www.bluesea.com/products/1010/12_Volt_Plug , Dometic https://www.dometic.com/en-us/outdoor/coolers/accessories/hwk-dc-223505?v=9600024894 and others have Twist lock system to choose from.
Can be mounted wherever you choose and keeps the connector secure.
1986 Wolfsberg Limited Edition Vanagon.
AKA: Poptop with rear corner cabinet, fold down side table, rear-facing jump seat and a 12v fridge/cooler.
Muskrat
Muskrat is offline
PostPosted: Tue May 20, 2025 7:51 am    Post subject: Re: Where to plug in portable fridge Reply with quote
I hadn't heard of this, connector, but never liked the ciggy lighter plugs. Was thinkin bout the plugs the solar panels use. Not sure what those are called. I'll look up the Anderson.
Cheers!
Muskrat
Muskrat is offline
PostPosted: Tue May 20, 2025 7:55 am    Post subject: Re: Where to plug in portable fridge Reply with quote
Another good option!
Cheers!
Muskrat
Muskrat is offline
PostPosted: Tue May 20, 2025 7:56 am    Post subject: Re: Where to plug in portable fridge Reply with quote
Cheers!
Timwhy
Timwhy is offline
PostPosted: Tue May 20, 2025 8:04 am    Post subject: Re: Where to plug in portable fridge Reply with quote
Cheers!
Here is mine, it had been the plan to plug in the fridge to it. The length of the fridge cable and that of the cig socket saw some voltage drop from my Aux fuse box to the fridge. I then hardwired (fused) the fridge to the battery and use my socket for the XM Boombox.
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
Andymon
Andymon is offline
PostPosted: Tue May 20, 2025 9:22 am    Post subject: Re: Where to plug in portable fridge Reply with quote
I installed the cigarette lighter type plug on kick panel of the bench seat. The cord from the fridge goes under the carpet and then up to the plug.
"Blanch" '85 Westy
"Too many freaks and not enough circuses".
snuf
snuf is offline
PostPosted: Tue May 20, 2025 10:52 am    Post subject: Re: Where to plug in portable fridge Reply with quote
Cheers!
MC4 solar panel connectors are the most commonly used for solar panels. Get a crimper and make your own cables if that is better suited for you.
MsTaboo is offline
PostPosted: Tue May 20, 2025 11:15 am    Post subject: Re: Where to plug in portable fridge Reply with quote
Cheers!
Been using the cig lighter plug since 2011, seems to work fine. Buy a good one and it lasts. The other plugs are good also, just that the cig type are cheap and universal for other items.
Whichever way you go be sure and figure a way to secure the fridge in case of crash. Since you've already been on one rollover you can probably relate! Shocked
Currently:
shagginwagon83
shagginwagon83 is offline
PostPosted: Tue May 20, 2025 11:40 am    Post subject: Re: Where to plug in portable fridge Reply with quote
I hardwired my fridge to my fuse panel. Wire is coming out from under the OG fridge location (Westy interior), under the rug, to the fridge. I plan to add an outlet one day.
I will probably add an SAE port when I do so - https://www.amazon.com/dp/B07GNMPZZG
Instagram: @joannthevan
Red Ryder
PostPosted: Tue May 20, 2025 11:57 am    Post subject: Re: Where to plug in portable fridge Reply with quote
This location for a receptacle also allows the fridge to be placed just outside the vehicle while plugged in when camping, creating more interior space…
fxr
fxr is offline
PostPosted: Tue May 20, 2025 1:12 pm    Post subject: Re: Where to plug in portable fridge Reply with quote
Cheers!
I use Anderson Pole connectors all over the place. Not exactly cheap, but they make a good solid connection. Waterproof versions are now available as well.
Jim Crowther
Vespa GTS 300
