volkaholic1 Samba Member
Posted: Tue May 20, 2025 3:05 pm Post subject: type iii engine tin drawings complete |
i know this must exist, but i cant find it, i need a complete type iii engine tin drawing, with all the parts, i have found drawings, but they all seem to leave stuff off, like the fan, like the thermostat flaps system, even the rear fan shroud, things like that
it must exist, please point me to it, thanks! _________________ Volkaholic |
GearheadJim Samba Member
Joined: April 10, 2003 Posts: 217 Location: Columbus Ohio
Posted: Tue May 20, 2025 5:47 pm Post subject: Re: type iii engine tin drawings complete |
hey that is great
still does not show the thermostat or the funky linkage
and how does the air get from the fan shroud to the cylinder tins? there must be ductwork? _________________ Volkaholic |
gtixpress Samba Member
Joined: June 22, 2006 Posts: 322 Location: Mahomet, IL
Posted: Wed May 21, 2025 6:34 am Post subject: Re: type iii engine tin drawings complete |
There is an upper set of tins and a lower set. They direct air from the fan across the top of the cylinders, then it loops down and around across the bottom of the cylinders and out the back of the car. Some air travels through the openings in the cylinder fins between the cylinders as well. It's a lot less complicated than a Bugs. _________________ Joe P.
1969 VW Type 3 Squareback
2018 VW Atlas SE VR6 4Motion
2019 VW Beetle S Final Edition Convertible |
jaransonT3  Samba Member
Joined: January 01, 2005 Posts: 1343 Location: Dearborn, MI
Posted: Wed May 21, 2025 8:31 am Post subject: Re: type iii engine tin drawings complete |
| volkaholic1 wrote: |
hey that is great
and how does the air get from the fan shroud to the cylinder tins? there must be ductwork? |
Yes, it is missing the thermostat and linkage and the flaps are not shown in the fan shroud, but all of the cooling tin is there. That is the beauty of the Type 3 pancake motor...much simpler than the upright cooling on the Type 1.
The air from the shroud goes through the rectangular openings directly into the upper cylinder shrouds. No additional ducting is required. _________________ Later,
John Jaranson
'66 Square (Sophy)
'67 Type 34 Karmann Ghia
'70-1 Fasty (Jane - the Lead Sled project)
'71 Westy (Sialia)
https://www.carartbyjohn.com
https://www.carartbyjohn.com/2026Invasion/ |
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 4081 Location: San Jose, CA
Posted: Wed May 21, 2025 10:27 am Post subject: Re: type iii engine tin drawings complete |
| jaransonT3 wrote: |
hey that is great
The air from the shroud goes through the rectangular openings directly into the upper cylinder shrouds. No additional ducting is required. |
Yeah, the thermostat / flaps are not something we really get asked for so I didn't add them to the diagram. Usually we just sell shrouds complete with the flaps, etc. The parts book here on the site has the flaps and linkage in it if it helps:
https://www.thesamba.com/vw/archives/manuals/type3_parts_book/ _________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
Posted: Thu May 22, 2025 10:10 am Post subject: Re: type iii engine tin drawings complete |
hey that is what i was looking for, thanks! _________________ Volkaholic |
