Does 043 905 205 distributor have retarded #3?
talljordan
talljordan is offline
PostPosted: Wed May 21, 2025 2:31 pm    Post subject: Does 043 905 205 distributor have retarded #3? Reply with quote
Title says it all. Some years of distributors had a retarded #3, I timed my bug with the #3 wire, does this distributor have a retarded #3 lobe?
Bosch part number is 0 231 170 034
1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end
bsairhead
bsairhead is offline
PostPosted: Wed May 21, 2025 3:12 pm    Post subject: Re: Does 043 905 205 distributor have retarded #3? Reply with quote
Move it to the one and find out.
talljordan
PostPosted: Wed May 21, 2025 3:21 pm    Post subject: Re: Does 043 905 205 distributor have retarded #3? Reply with quote
Its 2 degrees of retard, which is within the margin that I dont trust my dwell meter to pick it up reliably. Id prefer to know for sure.
bsairhead
PostPosted: Wed May 21, 2025 4:20 pm    Post subject: Re: Does 043 905 205 distributor have retarded #3? Reply with quote
Got a good machinist square? Actually a regular small square will tell.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed May 21, 2025 4:39 pm    Post subject: Re: Does 043 905 205 distributor have retarded #3? Reply with quote
The cam is curved.
Pretty sure only the DVDA distributors had the 3* retard.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
talljordan
PostPosted: Wed May 21, 2025 4:44 pm    Post subject: Re: Does 043 905 205 distributor have retarded #3? Reply with quote
Appreciate it Glenn, I figured you would have the answer.
Do all the DVDAs have this? or was it only until doghouse shrouds were introduced. Im slightly considering going DVDA on my 1972 super, as that is what is period correct. Though Im not sure it would have any advantage besides emissions.
Mben
Mben is offline
PostPosted: Wed May 21, 2025 5:27 pm    Post subject: Re: Does 043 905 205 distributor have retarded #3? Reply with quote
I have a vacuum only advance distributor 113905205T on my 1970 single port. When I checked the timing at idle this Spring I compared cylinder 1 to number 3. The timing of 3 was retarded when compared to 1.
heimlich Premium Member
VWNOS.com
heimlich is online now
PostPosted: Wed May 21, 2025 5:55 pm    Post subject: Re: Does 043 905 205 distributor have retarded #3? Reply with quote
The short aluminum bodied distributors such as 113 905 205 K and 113 905 205 T had the #3 cylinder retarded. This was on the non-doghouse fan shroud that ran hot on #3 cylinder. I've not seen it consistently on the distributors made after that. Sometimes you will find a distributor that has some offsets but nothing that is consistent that would tell you it is on all the distributors from the factory like that. Those early short aluminum ones mentioned have it on every single one.
What you can do to check your distributor is move the wire on your timing light. Take a note where it is on #1 with the base timing that you set. When you move it to the other cylinders you will see how far off they are. Sometimes it is important to use a specific cylinder for timing.
