texastomeh Samba Member
Joined: November 20, 2018 Posts: 301 Location: Dallas, TX
Posted: Wed May 21, 2025 8:10 am Post subject: Too Much Oil In Valve Cover after HOOVER MOD???? |
Guys,
I seem to be having a problem with the 1&2 sparkplugs fouling and causing misfires on only the right side of my 1776.
After thoroughly checking out other possibilities, I believe the issue is caused by excessive oil in the valve cover as a result of potential "over zealousness" on my part while incorporating the HOOVER MOD . The oil seems to be getting sucked through the valve guides, even though they have guide seals on them.
Does anyone have any "easy(?)" recommendations as to how to reduce the "effectiveness' (i.e. oil flow to the head) of the HOOVER MOD as something to try?
Thanx in advance for your advice and comments!!
Tom _________________ A new engine build won't solve ALL of life's problems - only those THAT REALLY MATTER!!!
GETTING old was GREAT - BEING old SUCKS!!
Too bad that the guys that know how to solve all of the WORLD's problems are too busy working on old Volkswagens!! |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7791 Location: Videbaek Denmark
Posted: Wed May 21, 2025 8:19 am Post subject: Re: Too Much Oil In Valve Cover after HOOVER MOD???? |
IF! that is where the oil comes in, you most likely have too little crank case breathing capacity, i.e too much blow by _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
oprn Samba Member
Joined: November 13, 2016 Posts: 14584 Location: Western Canada
Posted: Wed May 21, 2025 9:38 am Post subject: Re: Too Much Oil In Valve Cover after HOOVER MOD???? |
Where did you find valve stem seals and how did you install them?
Interesting that you think it is the Hoover mods. Do you have a 30mm oil pump? Are you running heavy cold oil that is having a hard time getting back down to the crankcase?
Just some thoughts... _________________ Our cars get old, we get old but driving an old VW never gets old! |
rayjay Samba Member
Joined: March 26, 2008 Posts: 1576 Location: Buford GA
Posted: Wed May 21, 2025 9:53 am Post subject: Re: Too Much Oil In Valve Cover after HOOVER MOD???? |
Pull the intake manifold and see if oil is puddling in the intake port. |
BFB Samba Member
Posted: Thu May 22, 2025 6:41 am Post subject: Re: Too Much Oil In Valve Cover after HOOVER MOD???? |
I had similar oil issues after hoover modding an engine although I wasn't fouling plugs. most people didnt believe it and wanted to blame oil in the intake ports on something else but there wasn't anything else to get it there and after my fix the oil wasn't in the ports anymore either.
what I did was drill & tap the heads for 1/2" npt just below the valves , then run a drain line from there to the block, which has to be above the oil line otherwise your drain line will have oil in it as high as the oil level in the case. I drilled & tapped the case while it was together , just used copious amount of bearing grease and went really slow and cleaned & regreased as went.
more than likely its coming from over grooving the lifters so replacing them is an alternative too.
after that, I dont do all the hoover mods anymore especially not the lifter mod, dont need more oil going into the heads than what can drain back out and even unmodded vw heads fill quite a bit so what's the point. _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
Posted: Thu May 22, 2025 7:55 am Post subject: Re: Too Much Oil In Valve Cover after HOOVER MOD???? |
I do the Hoover mods quite extensively on alm ost anything except dragrace (which I normally dont build anymore) I have NEVER had this issue, not even on sustained 5000 rpm Autobahn cruises.
But, as I wrote above, you need sufficient crank case ventilation, or maybe even a PCV system. (I never had the need for that, but its an option
PS. Do you happen to have vented valve covers? If yes, block them and let the slight overpressure help push the oil back in the case again. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13430 Location: West Coast, USA
Posted: Thu May 22, 2025 8:46 am Post subject: Re: Too Much Oil In Valve Cover after HOOVER MOD???? |
If the Hoover mods caused too much oil on the 1/2 side, then wouldn’t every engine VW ever have too much oil on the 3/4 side?
Robbie _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
Posted: Thu May 22, 2025 10:08 am Post subject: Re: Too Much Oil In Valve Cover after HOOVER MOD???? |
airschooled wrote: |
If the Hoover mods caused too much oil on the 1/2 side, then wouldn’t every engine VW ever made would have too much oil on the 3/4 side?
Robbie |
Exactly! _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Chip  Samba Member
Posted: Thu May 22, 2025 3:48 pm Post subject: Re: Too Much Oil In Valve Cover after HOOVER MOD???? |
texastomeh wrote: |
Guys,
Tom |
Are these 9mm stem Mexican 043 heads?
I'd guess the problem is with this strange detail more than anything else. |
BFB Samba Member
Posted: Thu May 22, 2025 4:29 pm Post subject: Re: Too Much Oil In Valve Cover after HOOVER MOD???? |
Alstrup wrote: |
Robbie |
Exactly! |
Well… they kinda do which is the point of the Hoover mods.
Far as my deal went, i had the issue on both sides not just one. And to be honest id say i probably notched the lifters too much. really, just wanted to try the mods just because. I’ll mod the cases to get more oil to the 1-2 side but i think the lifter mod is unnecessary. _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
modok Samba Member
Joined: October 30, 2009 Posts: 27588 Location: Colorado Springs
Posted: Thu May 22, 2025 5:35 pm Post subject: Re: Too Much Oil In Valve Cover after HOOVER MOD???? |
When people say Hoover mods I don't know what they did, I doubt they used exactly the same parts and procedures he did. Just tell us what you did , with what parts.
And it's probably unrelated anyway.
Possibly a groove in valve guide bore, guide loose in head, guide worn. Ect |
BFB Samba Member
Posted: Thu May 22, 2025 6:28 pm Post subject: Re: Too Much Oil In Valve Cover after HOOVER MOD???? |
Maybe you should do some research on hoover mods then youd know what it is and what they did and that there are no parts to buy & use _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
modok Samba Member
Posted: Fri May 23, 2025 12:01 am Post subject: Re: Too Much Oil In Valve Cover after HOOVER MOD???? |
no, no, I'm just being nice.
You and everybody else is just too retarded to ever figure out that the amount of FLOW that flows through a thing has to do with the size of the passages and the pressure.
This is true of carburetors and oil systems and valve guides and leaks and breathers and intake systems and exhaust systems and how engines work entirely.
But the sooner you start working on the problem then the sooner it might be solved.
The number of grooves in a lifter may or may not matter, it would depend on the size of the grooves if that was a restriction or not. Was the restriction in the pushrod? was it in the valve adjuster? was it the rocker? Where was the restriction?
The whole point of Mr. Hoovers most famous blog post of many, was him teaching you how to think for yourself, and FIND the restriction, not cut grooves in things with no understanding of why.
I know that ALL engines have some type of metering scheme to adjust the amount of oil to the heads, and it may be done many different ways, but some people don't know that.
And for a long time I didn't understand that people were taking his one blog post as actual universal instructions.
So now I assume nothing.
And I wasn't talking to you BFB, but now I am. |
oprn Samba Member
Posted: Fri May 23, 2025 4:29 am Post subject: Re: Too Much Oil In Valve Cover after HOOVER MOD???? |
I am one of those individuals that blindly followed Mr. Hoover's "universal" instructions to the letter on my last engine build. I have not seen any excessive oil consumption, flooding of the valve covers, blackened spark plugs or lowered oil pressure. That is the first engine I have done it on and there has been no downside.
Unless the OP did something drastically different than Mr. Hoover outlined then his black oily plugs are from something else. _________________ Our cars get old, we get old but driving an old VW never gets old! |
BFB Samba Member
Posted: Fri May 23, 2025 6:05 am Post subject: Re: Too Much Oil In Valve Cover after HOOVER MOD???? |
modok wrote: |
you always say the most ignorant shit like you think your somebody and some great theologian ... " maybe its the.., maybe its not.
was it because its blue, was it because its not red? how could this possibly be, could the cosmos be aware its existence??
where for art thou oh oil leak? IF the oil were but sentient it could tell me but wait, it moves and flows, and has form, you can read signs it shows therefore it has language. ALAS it must be sentient or maybe it's not .
maybe I MAKE sense and MAYBE I just talk in circles about random shit... "
"And I wasn't talking to you BFB, but now I am". that's frightening, I think I'll have a hard time sleeping now. I might even second guess what I post, in fear that you'll reply directly to me. _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15598 Location: Deep in the 405
Posted: Fri May 23, 2025 7:34 am Post subject: Re: Too Much Oil In Valve Cover after HOOVER MOD???? |
This is the reason I haven't been around the last few months. Too many Karens. I took a good long look in the mirror and saw a Karen. There are a few more other folks around here that need to look into the mirror and see if Karen is there. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Fri May 23, 2025 7:44 am Post subject: Re: Too Much Oil In Valve Cover after HOOVER MOD???? |
Here is my guess on the fouled plug problem. If you have read several of the OP's posts he always overthinks and overbuilds everything. My guess is he built his 1776 for his kit car and he simply doesn't have enough hard miles on it to properly break-in the rings and has blow-by. My guess is he needs to run his motor hard and fast and get the rings seated in. Maybe he runs the wrong heat range plug causing them to foul out. Maybe his carbs are not jetted correctly causing the plugs to foul out. My smell test says it's not anything to do with the Hoover mods. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23027 Location: Oklahoma City
Posted: Fri May 23, 2025 8:16 am Post subject: Re: Too Much Oil In Valve Cover after HOOVER MOD???? |
vwracerdave wrote: |
Here is my guess on the fouled plug problem. If you have read several of the OP's posts he always overthinks and overbuilds everything. My guess is he built his 1776 for his kit car and he simply doesn't have enough hard miles on it to properly break-in the rings and has blow-by. My guess is he needs to run his motor hard and fast and get the rings seated in. Maybe he runs the wrong heat range plug causing them to foul out. Maybe his carbs are not jetted correctly causing the plugs to foul out. My smell test says it's not anything to do with the Hoover mods. |
I think that is a fair observation. This is one of these threads I was just watching with only half interest.....because there is no data visually presented. It's all just a blind guess for anyone answering.
The man says both #1 and #2 spark plugs are fouling. But....no picture.
Is it actually oil fouling or is it fuel fouling? Or is it virtually no spark on 1 and 2? Or hideously low compression on 1 and 2?
Just not enough info yet to say/guess anything.
Ray |
58 Plastic Tub Samba Member
Joined: September 03, 2007 Posts: 472 Location: Nowhere, USA
Posted: Fri May 23, 2025 9:25 am Post subject: Re: Too Much Oil In Valve Cover after HOOVER MOD???? |
This is the reason I haven't been around the last few months. Too many Karens. I took a good long look in the mirror and saw a Karen. There are a few more other folks around here that need to look into the mirror and see if Karen is there. |
That is unusually self-aware and honest for an on-line forum post. Well done. FWIW, any constructive post with an honest perspective, based in both theory and practice is appreciated by the rest of us who read a lot and post a little.
You definitely have your own perspective based on your experience, and as long as you present that perspective as an observation (as a point along a continuum of observations) your input is a valuable reference point.
It's easy to get stuck in a rut or to discount the perspectives of other people, to read too much (or too little) into questions other people are asking. But even then, a strongly held opinion is still WORLDS better than constantly engaging in personal attacks and accusations.
Yeah, this forum has a lot of Karens, but it's got even more parrots just repeating the "folklore and common knowledge" we all read again and again.
Like almost any online forum, there is no shortage of keyboard warriors who bring almost nothing to the discussion. Opinions are great -- online pissing matches are ridiculous. _________________ Stan Galat
"A single point in isolation is a reference point. Two points is a line. Three points is a trend. Trends don't lie." |
Posted: Fri May 23, 2025 9:30 am Post subject: Re: Too Much Oil In Valve Cover after HOOVER MOD???? |
58 Plastic Tub wrote: |
It's easy to get stuck in a rut or to discount the perspectives of other people, to read too much (or too little) into questions other people are asking. But even then, a strongly held, and well funded opinion is still WORLDS better than constantly engaging in personal attacks and accusations.
Like almost any online forum, there is no shortage of keyboard warriors who bring almost nothing to the discussion. Opinions are great -- online pissing matches are ridiculous. |
Fixed your statement and agree.  _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
