Fit a -67 load bed to a -73 single cab
halmis
halmis is offline
PostPosted: Thu May 22, 2025 3:10 am    Post subject: Fit a -67 load bed to a -73 single cab Reply with quote
Hi everyone! Is it possible to fit the split load bed sheet metal on a bay if you make it a little longer? Is it the same width? I’ve found a place that only have the older one, but i could easily lenghten it if it’s the same otherwise
jtauxe Premium Member
jtauxe is offline
PostPosted: Thu May 22, 2025 6:31 am    Post subject: Re: Fit a -67 load bed to a -73 single cab Reply with quote
They are the same width, but the T2b bed is a bit longer, as you noticed. I suppose you could add a section (I would suggest one between the plates) to lengthen it.
Photos?
Where are you located?
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
halmis
halmis is offline
PostPosted: Thu May 22, 2025 11:39 am    Post subject: Re: Fit a -67 load bed to a -73 single cab Reply with quote
Ok, thanks. There was nothing left of the old bed so it would be great if i could fit the -67 bed. I live in Sweden
babysnakes
babysnakes is offline
PostPosted: Fri May 23, 2025 4:41 pm    Post subject: Re: Fit a -67 load bed to a -73 single cab Reply with quote
Klassik Fab has the load bed on their site.
halmis
halmis is offline
PostPosted: Sat May 24, 2025 1:35 pm    Post subject: Re: Fit a -67 load bed to a -73 single cab Reply with quote
Yes, but it would cost me 600$ just to get it here
SGKent Premium Member
SGKent is offline
PostPosted: Sat May 24, 2025 1:37 pm    Post subject: Re: Fit a -67 load bed to a -73 single cab Reply with quote
old cars take money to repair properly. Get used to it.
George Carlin:
Skills@EuroCarsPlus:
halmis
halmis is offline
PostPosted: Sun May 25, 2025 6:23 am    Post subject: Re: Fit a -67 load bed to a -73 single cab Reply with quote
sure, but i'm not an idiot
