Vanagon instrument cluster question
jeff.appel
jeff.appel is offline
PostPosted: Thu May 22, 2025 2:06 pm    Post subject: Vanagon instrument cluster question Reply with quote
Hey all, my speedometer finally ground to a halt after 318,000 miles. I’m replacing it with the GoWesty electric speedometer and the GPS VSS.
I am trying to remove the old mechanical speedometer from the instrument cluster, but it’s connected to a flexible, blue, plastic thingy with circuits. Sorry, I don’t know the name of this thing, it’s like a circuit board but plastic.Anyway, it runs through the back of the instrument cluster and connects to various inputs on the speedometer, for lights, and the tachometer.
The GoWesty instructions offer no guidance on what to do with this thing. Should I simply cut it from the old mechanical speedometer since the new one will have a separate power source?
Thanks
hdenter
hdenter is offline
PostPosted: Thu May 22, 2025 2:23 pm    Post subject: Re: Vanagon instrument cluster question Reply with quote
Don't cut anything! Call go westy and ask for clarification or better instructions. It doesn't sound like you have the necessary skills/experience to be poking around in your instrument cluster... Is there a samba member near you that can help. Many of us have been known to work/help/observe for beer....
Hans
'79 triple white convertible bug
'84 sunroof vanagon
'85 weekender
MarkWard
MarkWard is offline
PostPosted: Thu May 22, 2025 2:30 pm    Post subject: Re: Vanagon instrument cluster question Reply with quote
It should unplug from the speedo head. Small screwdriver for prying. You can tape it safely aside. Problem is your oil warning system may not function correctly. Also, it looks like your old Speedo has a cruise control speed sensor attached. If your van has working cruise, it may not with the new Speedo. But yes contact GW to be sure.
jeff.appel
PostPosted: Thu May 22, 2025 3:08 pm    Post subject: Re: Vanagon instrument cluster question Reply with quote
Thanks all. I emailed GW to get clarification.
@Hans I just replaced the entire front end suspension and the radiator by myself so I feel qualified to dig around in the instrument cluster Smile I was being hyperbolic when asking if I should cut the circuitry connection, I should have said "disconnect" instead.
@Mark the van does have factory cruise control but it hasn't worked since I've had the van. Up until now i've had a Fast Forward SpeedPuls VSS plugged into that port in the back of the speedo. I am bummed to hear that the oil warning system may not work properly with the new GW speedo. Hopefully they have some workaround for this?
crazyvwvanman
crazyvwvanman is offline
PostPosted: Thu May 22, 2025 3:32 pm    Post subject: Re: Vanagon instrument cluster question Reply with quote
That branch of the blue foil unplugs from the back of the speedo.
It has a black connector that you need to work free from the speedo.
There is a small circuit board hiding inside the old speedo and that is the oil pressure warning circuit board.
It isn't actually part of the speedo, it just hides inside the speedo.
That blue foil branch is the only thing hooked to the oil circuit board.
Mark
Altoona
Altoona is offline
PostPosted: Thu May 22, 2025 4:10 pm    Post subject: Re: Vanagon instrument cluster question Reply with quote
From the GW website:
Important model application notes:
• Direct replacement for all 1980-85 speedometer types with the original blue printed circuit foil, or fitted with our Replacement Kit for Printed Circuit Foil.
• Direct replacement for all 1986-91 speedometer types ONLY when fitted with our Replacement Kit for Printed Circuit Foil.*
jeff.appel
PostPosted: Thu May 22, 2025 4:14 pm    Post subject: Re: Vanagon instrument cluster question Reply with quote
Well frig, Altoona's right. GW just wrote me back:
"It looks like you have a late model Vanagon. You will need to replace that blue foil with this kit.
https://gowesty.com/products/instrument-cluster-ci...8064337061
There are little plastic tabs that the foil is attached with. You simply pop it off of those. There's a few sections on the back of the tach that require the removal of nuts and bolts.
The reason you need our cluster foil replacement kit is because the dynamic oil pressure electronics are located on the back of your OEM speedo. The GPS speedo doesn't have provisions to mount this board. The cluster foil replacement kit moves that circuitry to the center of the cluster."
Time to drop some more cash Sad
MarkWard
MarkWard is offline
PostPosted: Thu May 22, 2025 5:59 pm    Post subject: Re: Vanagon instrument cluster question Reply with quote
Curious what engine using Fastforward VSS.
crazyvwvanman
PostPosted: Thu May 22, 2025 6:03 pm    Post subject: Re: Vanagon instrument cluster question Reply with quote
You can remove the small oil warning circuit board from your old speedo and then plug it back into the stock blue foil just like it was, without hiding the circuit board inside the speedo.
The circuit board has no electrical connection to the old speedo, only to the blue foil.
VW simply hid it inside the speedo.
You can still use it when it is external to the speedo.
Mark
16CVs Premium Member
16CVs is offline
PostPosted: Fri May 23, 2025 12:32 am    Post subject: Re: Vanagon instrument cluster question Reply with quote
Why not just send your factory Speedo out for a rebuild? It served you over 300K, it deserves to be put back and serve the rest of its life.
My .02
Stacy
Samba member # 14980
Crooked Designer
Crooked Designer is offline
PostPosted: Fri May 23, 2025 10:46 am    Post subject: Re: Vanagon instrument cluster question Reply with quote
my 2¢ is upgrade the cluster wiring. My blue foil created tons of electrical gremlins in my dash. Replaced it with the one from vanagon.org (but the GW one is probably what you'll want if it is built to hookup to your new speedometer) but all of those issues went away after replacing the blue foil. Was very satisfying and hasn't had a problem in 7 years.
'85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit
SoquelDude
SoquelDude is offline
PostPosted: Fri May 23, 2025 5:36 pm    Post subject: Re: Vanagon instrument cluster question Reply with quote
I replaced the blue foil with the one from Vanagon.org and replaced the speedo with the GW one. They all play well together.
'90 Vanagon Westy GL, AT, EJ22E conversion (1993 2.2L Legacy Engine)
willyok
willyok is offline
PostPosted: Fri May 23, 2025 6:53 pm    Post subject: Re: Vanagon instrument cluster question Reply with quote
My .02
Stacy
Not to hijack but who are you using for this service? I’m in the same position as OP.
kevinm
kevinm is offline
PostPosted: Fri May 23, 2025 9:37 pm    Post subject: Re: Vanagon instrument cluster question Reply with quote
If you decide to repair and keep the speedo, here's a foil replacement option for late models that's been discussed on other threads before. Looks like a direct fit:
https://smallcar.com/vanagon-instrument-foil-repla...jja-8dZfZr[/url]
90 Syncro Westy, "Ludwig"
MarkWard
MarkWard is offline
PostPosted: Sat May 24, 2025 7:49 am    Post subject: Re: Vanagon instrument cluster question Reply with quote
willyok wrote:
My .02
Stacy
There are companies that can rebuild. In Florida DNA speedometer is on the West coast of florida. https://www.dnaspeedometers.com/ and Lauderdale Speedometer https://www.lspeedo.com/
I have used both companies. I ship to them directly. DNA is a smaller company and their pricing is more in my range. I'm sure there are lots of places.
Ahwahnee
Ahwahnee is offline
PostPosted: Sat May 24, 2025 8:21 am    Post subject: Re: Vanagon instrument cluster question Reply with quote
I haven't used them for VW but they do show VDO among the list of what they service.
Maybe not the cheapest but the ones I think are best:
https://www.westvalleyinstruments.com/
PS - they're up in Reseda.
do.dah
do.dah is offline
PostPosted: Sat May 24, 2025 8:32 am    Post subject: Re: Vanagon instrument cluster question Reply with quote
I used https://www.nhspeedometer.com/
I himmed and hawed of who to send it to, and choose North holleywood speedometer.
Not the cheapest, but they didn't have my speedo 24hrs, and the time from shipping to, and receiving from, was only a few days.
I'm happy with my choice.
