lboos Samba Member
Joined: November 20, 2015 Posts: 443 Location: Marietta GA.
Posted: Fri May 23, 2025 8:40 am Post subject: valve clearance |
Between valve adjustments, does the valve clearance increase or decrease do to normal wear ? Thanks
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4384 Location: viroqua wi.
Posted: Fri May 23, 2025 8:46 am Post subject: Re: valve clearance |
lboos wrote: |
Between valve adjustments, does the valve clearance increase or decrease. Thanks |
If parts wear evenly, neither. |
BMFBMF Samba Member
Joined: November 13, 2020 Posts: 448 Location: Swtzerland
Posted: Fri May 23, 2025 1:36 pm Post subject: Re: valve clearance |
Generally valve seats wear and the gap closes up. _________________ -----Slava Ukraini-----
1971 Stock South African Beetle 1300 : My mom's european "Thin Chick" spec. Completely stock with torsion bar front, swingaxle rear, smooth hubs, single MC, 40 mm shoes, 31PICT3 carb and 5 bolt drums all round, currently Running a 1976 SF:AS engine with the original SF:AD engine overhauled in a box, waiting to go back in one day. |
Posted: Fri May 23, 2025 1:49 pm Post subject: Re: valve clearance |
BMFBMF wrote: |
Generally valve seats wear and the gap closes up. |
Or the adjusters wear more and it opens. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79217 Location: Sneaking up behind you
Posted: Fri May 23, 2025 1:56 pm Post subject: Re: valve clearance |
bsairhead wrote: |
BMFBMF wrote: |
Or the valve stem stretches and the gap closes up. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Fri May 23, 2025 2:35 pm Post subject: Re: valve clearance |
Glenn wrote: |
bsairhead wrote: |
BMFBMF wrote: |
Or the valve stem stretches and the gap closes up. |
I would find it hard to believe that the stem would stretch more than the adjuster would wear. |
lboos Samba Member
Posted: Fri May 23, 2025 4:41 pm Post subject: Re: valve clearance |
I was just thinking, today I adjusted the valves on my 1972, I never noticed it before but on two of the cly's two of the valves were so tight I could not get .006 blade in, so I guess that means the valve clearance decrease's with normal wear. Thanks anyway .
Posted: Fri May 23, 2025 5:50 pm Post subject: Re: valve clearance |
lboos wrote: |
I was just thinking, today I adjusted the valves on my 1972, I never noticed it be for but on two of the cly's two of the valves were so tight I could not get .006 blade in, so I guess that means the valve clearance decrease's with normal wear. Thanks anyway . |
That would only be logical if they all did. So the other 2 cylinders all was normal? And was it just exhaust or intake or one of each? And were the 2 cylinders on the same bank? |
lboos Samba Member
Posted: Sat May 24, 2025 5:31 am Post subject: Re: valve clearance |
bsairhead wrote: |
[quote="That would only be logical if they all did. So the other 2 cylinders all was normal? And was it just exhaust or intake or one of each? And were the 2 cylinders on the same bank? |
Your prob. right, The tight valves were on #2 and #4 cly don't remember which valve, the other valves were slightly loose.
The reason I adjusted the valves was when I was going up a hill I noticed a valve rattle when under a load, after the valve adjustment no more valve rattle.
Thanks for all the advice, I've been around VW bugs since the 60's, love to drive them, but still don't know a whole lot about them mech . |
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 1958 Location: Wichita, KS
Posted: Sat May 24, 2025 6:11 am Post subject: Re: valve clearance |
Yeah, you want to keep an eye on any valves that require significant readjustment over short intervals, especially exhaust valves. If one or more of them is consistently tight every time you check & readjust, can sometimes be a sign that the stem is stretching, and may be getting ready to break - !! _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
