Syncro Schwenk springs and Fox shocks
pbrown
pbrown is offline
PostPosted: Sun May 04, 2025 6:24 pm    Post subject: Syncro Schwenk springs and Fox shocks Reply with quote
Hey All,
I need a favor. For those of you running Schwenk standard height springs and Fox shocks on your Syncro -- I would like to know your ride height. Measure from the fender lip to the wheel center.
I'm having an issue with the Fox shock rubbing on the axle. I like my ride height where it is. I will either have to adjust the shock higher to clear the axle or change to a stock Syncro spring. Stock springs are a little shorter.
Thanks in advance.
--Patrick
Patrick Brown
1986 Westy Syncro EJ25
Flickr --> https://flic.kr/s/aHsmQNUXEF
Sodo
Sodo is online now
PostPosted: Mon May 05, 2025 7:41 am    Post subject: Re: Syncro Schwenk springs and Fox shocks Reply with quote
Two possibilities:
Pray that its the UCAs upside down.
Other Twisted Evil is even less fun.
You may have the left-side Foxshock on the right side.
'90 Westy EJ25, NEW oil rings (!) 2Peloquins, 3knobs, pressure-oiled GT mainshaft, filtered, cooled gearbox
....KTMs, GasGas, SPOT mtb
pbrown
pbrown is offline
PostPosted: Mon May 05, 2025 8:00 am    Post subject: Re: Syncro Schwenk springs and Fox shocks Reply with quote
That's not is. At least I don't think so. I'll take a look. I have a ride height issue. The axle to shock body is okay. It's the adjustable spring cup. They need to be adjusted away from the axle a bit. I thought I had enough clearance but there are noticeable rub marks on the axle. It must be when turning or in compression.
I'm planning to pull out the spring compressor and adjust them up a couple of turns.
To make things worse, I had a local shop replace an axle and they put one on with a fatter hollow body axle. I need to get that out of there before there is additional damage.
Patrick Brown
pbrown
pbrown is offline
PostPosted: Mon May 05, 2025 8:10 am    Post subject: Re: Syncro Schwenk springs and Fox shocks Reply with quote
I just checked the UCA. They are mounted correctly. They are Burley control arms but that shouldn't matter.
Patrick Brown
pbrown
pbrown is offline
PostPosted: Sun May 11, 2025 6:06 pm    Post subject: Re: Syncro Schwenk springs and Fox shocks Reply with quote
I adjusted the front shocks up about 1/8" to hopefully eliminate the axle rubbing.
I have a non-standard axle on the passenger side. It has a thicker axle than OEM and was rubbing. It was installed new by Peace Vans in Seattle. They should have known better. Lesson learned - do your own work.
I have a replacement axle coming from Van Cafe tomorrow. It has the NLA Lobro outer CV. I'm worried that it will have the same thicker axle issue as what I removed. I also have some new CVs coming from T3 that I can use to rebuild my old axle. There will be options.
I have a trip planned and need this done by the 22nd.
Patrick Brown
pbrown
pbrown is offline
PostPosted: Sat May 24, 2025 8:18 pm    Post subject: Re: Syncro Schwenk springs and Fox shocks Reply with quote
I missed my deadline and cancelled the trip.
I started installing the stock springs from Christopher @ T3. It turns out that they have an inside diameter that is to small to fit the lower spring perch on the Fox shock.
IMG_3204 by Patrick Brown, on Flickr
The upper spring is the Schwenk and the lower is the replacement stock Syncro spring.
IMG_3205 by Patrick Brown, on Flickr
Schwenk spring
IMG_3206 by Patrick Brown, on Flickr
replacement sprint that is too small
I'm going to reinstall the Schwenk springs and change the ride height to clear the Fox shock's adjustment nuts.
Patrick Brown
pbrown
pbrown is offline
PostPosted: Sat May 24, 2025 8:24 pm    Post subject: Re: Syncro Schwenk springs and Fox shocks Reply with quote
Here is the problem. The axle has been rubbing.
IMG_3202 by Patrick Brown, on Flickr
And I had an axle fail. It's unclear if it was from the rubbing or other. I think it was self inflicted. I have a sport VC and think I broke the axle when turning too tight and too high speed.
IMG_3201 by Patrick Brown, on Flickr
I have some original rebuildable axles. I'm working on rebuilding now. Those outer CV joints are a PITA to remove.
Patrick Brown
ALIKA T3
ALIKA T3 is offline
PostPosted: Sat May 24, 2025 11:49 pm    Post subject: Re: Syncro Schwenk springs and Fox shocks Reply with quote
I don't understand how the splines can only be damaged at the tip... Confused
pbrown
pbrown is offline
PostPosted: Sun May 25, 2025 12:03 am    Post subject: Re: Syncro Schwenk springs and Fox shocks Reply with quote
The axle came out of the cv joint while still on the van. Possibly the clip was not completely engaged when last rebuilt.
Patrick Brown
pbrown
pbrown is offline
PostPosted: Sat May 31, 2025 1:32 pm    Post subject: Re: Syncro Schwenk springs and Fox shocks Reply with quote
I have a couple of core axle assemblies. I was able to get one stripped down. That outer CV is a PITA. An angle grinder was involved.
This photo shows the old and the replacement. The red one is the old. It doesn't seem so bad after seeing them side by side.
Syncro Front Axles by Patrick Brown
Patrick Brown
pbrown
pbrown is offline
PostPosted: Sat May 31, 2025 3:20 pm    Post subject: Re: Syncro Schwenk springs and Fox shocks Reply with quote
I spent some time with a small file cleaning up the replacement axle.
Syncro axle cleaned up by Patrick Brown, on Flickr
I'll take it to the powder coating shop on Monday.
Patrick Brown
4Gears4Tires
4Gears4Tires is offline
PostPosted: Sun Jun 01, 2025 4:47 pm    Post subject: Re: Syncro Schwenk springs and Fox shocks Reply with quote
I'd throw chinese ebay axles in there before I ran that.
pbrown
pbrown is offline
PostPosted: Tue Jun 03, 2025 7:19 pm    Post subject: Re: Syncro Schwenk springs and Fox shocks Reply with quote
I finally found a good axle.
Good Used Axle - Syncro Front
I'll repaint tonight and assemble tomorrow.
I perfected my process for removing the outer CV. I no longer fear this task. Here's the secret.
Build a small slide hammer from a 1 1/4" x 10" steel pipe. Use an angle grinder to cut a notch as seen in the photo below. The notch provides a place for the snap ring tool.
CV Removal Tool
This is the snap ring tool I used.
Snap Ring Tool 1
https://www.amazon.com/dp/B00209ETSS?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Pull the inner CV first. Slide the tool over the axle with the notch facing the outer CV. Clamp axle in vise close to the inner end but not on the splines. Hold the snap ring open while slamming the pipe against the CV joint. The first hit should get past the groove so that the snap ring tool can be set aside. A few more wacks and the joint pops off.
Patrick Brown
pjn_wyo
pjn_wyo is offline
PostPosted: Thu Jun 05, 2025 4:22 pm    Post subject: Re: Syncro Schwenk springs and Fox shocks Reply with quote
I still think sodo is right
pbrown
pbrown is offline
PostPosted: Thu Jun 05, 2025 5:39 pm    Post subject: Re: Syncro Schwenk springs and Fox shocks Reply with quote
About what?
Patrick Brown
pbrown
pbrown is offline
PostPosted: Thu Jun 05, 2025 6:44 pm    Post subject: Re: Syncro Schwenk springs and Fox shocks Reply with quote
Upper Control Arm. I'm pretty sure it's mounted correctly. Please advise if I'm mistaken.
Upper Control Arm Mounted Correctly
Freshly rebuilt axle. New CVs from T3. Replacement axle shaft from Burley.
Freshly Rebuilt Syncro Axle
Now it's time to get this axle in the van and get my ride height set.
Patrick Brown
pbrown
pbrown is offline
PostPosted: Thu Jun 05, 2025 8:16 pm    Post subject: Re: Syncro Schwenk springs and Fox shocks Reply with quote
And the axle is back in the van. I haven't torqued anything yet. You can see the tight clearance to the Fox shock. One should stick with OEM size axle shafts if running these.
Axle installed again
The new 12pt 8mm head CV bolts from T3 have two piece Nordloc washers. I've not seen these before.
Two layer washer for CV
Patrick Brown
pbrown
pbrown is offline
PostPosted: Yesterday 12:13 pm    Post subject: Re: Syncro Schwenk springs and Fox shocks Reply with quote
It's back together and the axle nut is torqued to 258 ft-lbs.
Big torque wrench
I took it for a drive and found a flat place to spot and measure ride height.
Front Right - 19 1/2"
Front Left - 19"
Rear Right - 19 1/4"
Rear Left - 18 1/2"
I bought some rear spacers from T3. I'll start at the Rear left and add a 1/2" spacer to start and remeasure. My target will be 19 1/2" at all wheels.
Patrick Brown
