Broke my South African Grille
mojav
mojav is offline
PostPosted: Mon May 26, 2025 6:24 pm    Post subject: Broke my South African Grille Reply with quote
Well I wrecked my thermostat housing turning around on a bumpy road.
Was able to find a replacement at O'Reileys and performed a coolant flush..
But I broke my flimsy plastic South African grille pulling it off to get to the radiator.
Any recommendations on a replacement grille that fits the 4 headlight setup on a 89 Vanagon? I don't really want to go with the SA grille again because it's so flimsy. Anyone have any custom grille setups?
Thanks[/img]
mojavmusic.com
View user's profile Send private message Twitter Instagram YouTube Gallery Classifieds Feedback
pbrown
pbrown is offline
PostPosted: Mon May 26, 2025 7:33 pm    Post subject: Re: Broke my South African Grille Reply with quote
Look at the Small Car grill. The inner lights are different size.
https://smallcar.com/south-tacoma-grille/
Patrick Brown
1986 Westy Syncro EJ25
Flickr --> https://flic.kr/s/aHsmQNUXEF
markswagen
markswagen is offline
PostPosted: Mon May 26, 2025 7:56 pm    Post subject: Re: Broke my South African Grille Reply with quote
l'd go back to stock, either stock early or late.
the tacoma grill, there's a decent camping trip in that cost.
l hate those south african things, if l have a customer who has one on his van, and for some reason it needs to come off, l tell him it's up to him to remove and refit the grill.
l have zero wish to be on the hook for any damage caused to them.
619 201 0310
dhaavers
dhaavers is offline
PostPosted: Tue May 27, 2025 6:22 am    Post subject: Re: Broke my South African Grille Reply with quote
Unless you’re completely sold on the SA look, for about half the price you can get a set of H4 E-code headlamps for the stock grille…and they’re glass.
…and you’ll be able to see REALLY WELL. Cool
- Dave
"The WonderVan"
zerotofifty
zerotofifty is offline
PostPosted: Tue May 27, 2025 7:58 am    Post subject: Re: Broke my South African Grille Reply with quote
Stock square light grills are great with the stock headlights if you install an aftermarket LED bulb. Nice bright light, plus the current draw goes easy on the fuse panel
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
mojav
mojav is offline
PostPosted: Tue May 27, 2025 8:05 am    Post subject: Re: Broke my South African Grille Reply with quote
- Dave
The stock grille on mine has the square lights which, I don't like. Will the 80-85 stock grille (with round lights) fit on an 89 Vanagon?
mojavmusic.com
4Gears4Tires
4Gears4Tires is offline
PostPosted: Tue May 27, 2025 8:29 am    Post subject: Re: Broke my South African Grille Reply with quote
Yes, you need the headlight buckets as well.
Red Ryder
Red Ryder is offline
PostPosted: Tue May 27, 2025 9:19 am    Post subject: Re: Broke my South African Grille Reply with quote
Later square headlights with updated e-code lenses for the win!
“Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition (Tornado Red)
“Nigel” — 1999 Jaguar XK8 convertible (Alpine Green Metallic)
1988M5
1988M5 is offline
PostPosted: Tue May 27, 2025 9:48 am    Post subject: Re: Broke my South African Grille Reply with quote
Ok deal on NOS round H4 with buckets.
https://www.thesamba.com/vw/classifieds/detail.php?id=2686585
BK
1991 tin top GL
Some BMWs.
4Gears4Tires
PostPosted: Tue May 27, 2025 10:08 am    Post subject: Re: Broke my South African Grille Reply with quote
Seeing my Vanagons side by side, square headlights make the van look like this =_= and round headlights make the van look like this (:
Very different vibes of the two vans. Round headlights are so much happier / friendlier.
Red Ryder
PostPosted: Tue May 27, 2025 11:46 am    Post subject: Re: Broke my South African Grille Reply with quote
Perhaps, but square headlights more closely match the boxy aesthetic of the Vanagon’s body shape!
Icebox500
Icebox500 is offline
PostPosted: Tue May 27, 2025 1:04 pm    Post subject: Re: Broke my South African Grille Reply with quote
Likely more than you want to spend but I'm essentially happy with my South Tacoma Grille from Small Car. Nice to have bright LED lights.
87 Westy 2WD “Van Geaux”
FAS 2.0 Gas GENV (10/2025)
AZ Transaxle + Peloquin Manual Transmission
GW lift springs, solar, Burley front & rear disc, etc...
New Orleans, LA (previously CO, WA, and CA)
Past
87, 90 Westys
64, 65 splittys + various air cooled
syncrodoka
syncrodoka is offline
PostPosted: Tue May 27, 2025 2:55 pm    Post subject: Re: Broke my South African Grille Reply with quote
I stick a radiator pick in the top corner and pry the grill away from the body, haven't broken or damaged the 3 that I have in almost 20 years.
The south tacoma grill was supposed to be designed to be more solid than the SA version.
Your only other options are stock single round or a square light grill.
Franklinstower
Franklinstower is offline
PostPosted: Wed May 28, 2025 7:28 am    Post subject: Re: Broke my South African Grille Reply with quote
I use plastic bike tire tools on my grill, pops it off easily. I agree the SA grill is flimsy.
I was actually about using some fiberglass resin to strengthen it up.
'89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
YITB
mojav
mojav is offline
PostPosted: Wed May 28, 2025 9:26 am    Post subject: Re: Broke my South African Grille Reply with quote
So here is what I'm working with
Does the S Tacoma grille fasten the same way as all the other grills? Through the clips?
It looks like for the S Tacoma setup I will need to replace my bright lights with 5.5" lights instead of my 5.75" ones.
For the 80-85 stock grille setup I would ditch the hella highbeams and replace my outer hellas with some H4 E-code lamps and different wiring?
My current brackets would work with either setup right? Just need some clips and radiator clip? (that broke too)
Looking like 4-500 vs 7-800 with tax and shipping potentially?
Thanks for the help guys
mojavmusic.com
ALIKA T3
ALIKA T3 is offline
PostPosted: Wed May 28, 2025 11:00 am    Post subject: Re: Broke my South African Grille Reply with quote
No wiring change, you just keep your outer lights, they're common to both set up, replace the clips if needed for the grille. Done.
These inner lights, even made in Germany were so bad, it's unreal.
I adapted some cheap inner lights I found to get rid of them.
I grease the pins on the grille to avoid ripping it out.
The Tacoma grille has stainless pins and is much beefier in itself.
mojav
mojav is offline
PostPosted: Wed May 28, 2025 12:20 pm    Post subject: Re: Broke my South African Grille Reply with quote
so according to this bit I'm fine with my current lights, just get some clips? This seems the most straightforward as far as the durability I was looking for
mojavmusic.com
Hammy1
Hammy1 is offline
PostPosted: Wed May 28, 2025 1:37 pm    Post subject: Re: Broke my South African Grille Reply with quote
Here’s my 85’ to which I added 1980’s Jaguar headlights and buckets that I got from the local U-pull. I am impartial to the four headlights myself….
dougnlina Premium Member
dougnlina is offline
PostPosted: Wed May 28, 2025 2:08 pm    Post subject: Re: Broke my South African Grille Reply with quote
Heres my cheap SA inner light solution, scary bright and still going strong
https://www.thesamba.com/vw/forum/viewtopic.php?t=797617&highlight=
"Grover" a '87 Syncro Poptop 1.8T
"Olive" a '60 Ragtop Beetle (retired)
"Kermit" '79 Westfalia (retired)
"Patches" '72 Beetle (retired)
"Wilbur" '69 Camper (retired)
"Bernice" 67 Beetle, My first love, (Also Retired)
mojav
mojav is offline
PostPosted: Wed May 28, 2025 6:11 pm    Post subject: Re: Broke my South African Grille Reply with quote
This is really badass but I'm on the road and don't have an angle grinder, sand blaster or 3D printer.
If you didn't smash the lights would they still fit or is this a necessary adjustment to meet the needs of the South Tacoma?
mojavmusic.com
