Type 4 thermostat and flaps
RZAR
RZAR is offline
PostPosted: Sun Feb 24, 2008 7:26 am    Post subject: Type 4 thermostat and flaps Reply with quote
Im putting together and rebuilt longblock for my 77 bus. I installed the themostat and cable, hooked it up to the flaps and tested it buy slowing heating it up. When the flaps open and close its real jerky. Is this normal? I lubed all the hinge and pivot points on the flaps and wheel.
2VWs1BMW
2VWs1BMW is offline
PostPosted: Sun Feb 24, 2008 8:39 am    Post subject: Reply with quote
You probably have some binding internal to the cooling tins. Disconnect the cable and move the flaps by hand.
- Brian -
'17 Alltrack
'99 ///M Coupe w/48k mi - Bimmerforums
'77 Westy w/156k mi
NUKETROOP
NUKETROOP is offline
PostPosted: Sun Feb 24, 2008 8:56 am    Post subject: Reply with quote
He's right,
they should move smoothly. I used some Rem-Oil to lube the points you stated. Do you have the plastic bushings that sit in the fan shroud and hold the rod? Thats the first thing I'd look for. The picture only shows one but I have 2.
Then check to see if you wound the spring enough? I'm not sure how much you need to do it, someone help out.
You may need to take the fan shroud off and lube the linkages that connect the rod to the flap on the left side if you still can't get it smooth.
If that doesn't work, The linkage inside on the left is held together by spring clips. Those could be too tight, slightly open them with a flathead screwdriver..
Los Alamos Nat'l Labs weapons rock. Lawrence Livermore weapons SUCK!
IYA-ATOMIC-YAS
1977 Campmobile w/78 Engine(H-Lifters)
RZAR
RZAR is offline
PostPosted: Sun Feb 24, 2008 12:01 pm    Post subject: Reply with quote
I do have everything that needs to be there. i lubed all the pivit points and the flaps move freely when the cable disconected. its just when the the themostat is expanding and contracting the flaps move the stop then move and stop. it does this opening and closeing. the flaps do close and open completely.
Smurf
Smurf is offline
PostPosted: Sun Feb 24, 2008 6:51 pm    Post subject: Reply with quote
what would happen if you just leave the cable off? Won't the flaps just stay open the whole time? just curious
1962 Beetle
1977 Westfalia (Subaru Conversion)
"Traveling in a fried-out Kombi
On a hippie trail head full of zombie"
-Men at Work
IFBwax
IFBwax is offline
PostPosted: Sun Feb 24, 2008 6:57 pm    Post subject: Reply with quote
If the spring is attached, yes. It should. However, the thermostat is important to prevent engine wear. It gets your engine to heat up faster rather than having the flaps perpetually open which will cause your engine to run colder longer which is bad.
Owner of: "The Party Pickle" (a 1979 2 Liter FI "Raby Camper Special" Sage Green Westy Campmobile) & "Charlie Brown" (a 1979 2 Liter FI "Rob Grant Rebuild" Agate Brown/Dakota Beige Station Wagon)
www.partypickle.blogspot.com
Tcash
Tcash is offline
PostPosted: Sat May 12, 2018 10:31 am    Post subject: Re: Type 4 thermostat and flaps Reply with quote
To link to this thread copy and paste
Code:
[url=https://www.thesamba.com/vw/forum/viewtopic.php?p=8769526#8769526]Type 4 thermostat and flaps[/url]
Note: The spring in the following pictures is a Failsafe. If the Thermostat cable should break, the spring will Open the cooling flaps.
Code:
[url=https://www.thesamba.com/vw/forum/viewtopic.php?p=7765988#7765988]Type IV (4) Cooling Flaps Closed n Open[/url]
Warning, crappy pics ahead....
This is correct, yes?
Tab pushed forward towards front of vehicle = flaps closed?
Tab is up, pulled all the way back towards the rear of the vehicle = flaps open?
added tcash
SGKent Premium Member
SGKent is offline
PostPosted: Sat May 12, 2018 11:24 am    Post subject: Re: Type 4 thermostat and flaps Reply with quote
the question might be how you heated it. Although it is fairly smooth in operation, that does not mean your heat source created linear expansion inside the bellows.
George Carlin:
Skills@EuroCarsPlus:
1971 deluxe (sold)
1977 deluxe
hazetguy
hazetguy is offline
PostPosted: Sun May 13, 2018 9:55 am    Post subject: Re: Type 4 thermostat and flaps Reply with quote
you did see that this thread is a decade old, the original poster and one other haven't logged in in about a year, one poster in about 9 years. i know you weren't the one who dredged this up for no reason, just sayin.
Wasted youth
Wasted youth is offline
PostPosted: Sun May 13, 2018 4:02 pm    Post subject: Re: Type 4 thermostat and flaps Reply with quote
Old thread, yes. But relevant.
My question: What will happen when the lube dries up? Probably better to apply fine craftsmanship so the moving parts move freely on their own accord without lubrication.
SGKent is offline
PostPosted: Sun May 13, 2018 6:23 pm    Post subject: Re: Type 4 thermostat and flaps Reply with quote
Missed that - thanks Hazetguy
George Carlin:
1971 deluxe (sold)
1977 deluxe
Hoody
Hoody is offline
PostPosted: Sun May 13, 2018 7:10 pm    Post subject: Re: Type 4 thermostat and flaps Reply with quote
It’s really nice that Tcash takes the time to post all of these past threads, stickys, and trouble shooting diagrams. I can’t be bothered to post pics of my extremely unobtanium parts when I decide to let them go. Thank GOD he hasn’t poached any of my pics of them.’Oh wait....I don’t have any. Sorry Jon....I had to bust your balls. And BTW the spare tire cover you sold me 5 years ago just got unwrapped. With some love it is dead tits perfect! Thanks Jon!
poundman
poundman is offline
PostPosted: Tue May 27, 2025 12:22 pm    Post subject: Re: Type 4 thermostat and flaps Reply with quote
Where can I purchase all these components. Mine are gone.
Restoring a 1972 Bay Window Bus that has not be registered for the road since 1981.
Sugar Land, Texas
Wildthings
Wildthings is offline
PostPosted: Tue May 27, 2025 1:49 pm    Post subject: Re: Type 4 thermostat and flaps Reply with quote
You must have part #31 and something needs to seal the hole where bolt #44 used to go. The rest are not particularly necessary in Texas if you aren't driving it during the winter months.
poundman
poundman is offline
PostPosted: Tue May 27, 2025 3:27 pm    Post subject: Re: Type 4 thermostat and flaps Reply with quote
Is #31 just an engine tin? Or is it a flap ?
Sugar Land, Texas
aeromech
aeromech is offline
PostPosted: Tue May 27, 2025 3:35 pm    Post subject: Re: Type 4 thermostat and flaps Reply with quote
Available through
Awesome Powdercoat
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Jcolton
Jcolton is offline
PostPosted: Tue May 27, 2025 9:17 pm    Post subject: Re: Type 4 thermostat and flaps Reply with quote
Busted Bus did me up right
I was missing everything as well and Joe sent me the whole set up looking like new
1979 Westy
Wildthings
PostPosted: Tue May 27, 2025 10:48 pm    Post subject: Re: Type 4 thermostat and flaps Reply with quote
It's the flap that directs air into the top of the oil cooler, it is 100% necessary, a lot of people just screw it to the tin it mates against when they remove the remainder of the flap setup.
I am a big fan of having a working thermostat system, but it's hardly necessary if you seldom drive below 70°F.
SGKent is offline
PostPosted: Tue May 27, 2025 11:07 pm    Post subject: Re: Type 4 thermostat and flaps Reply with quote
Here is a drawing Colin (amskeptic) did. He was kind enough to share it with others to answer questions on how the flaps work because there is a lot of confusion about them. It is also why 3 is the hottest cylinder.
the cooling flap on the left side where the oil cooler is acts both as a flap and as a vane. It splits the air so part of it goes thru the oil cooler and part thru the cylinders. It is a must whether open or closed.
[/quote]
George Carlin:
1971 deluxe (sold)
1977 deluxe
