willyok Samba Member
Joined: May 07, 2014 Posts: 66 Location: Vallejo/San Diego
Posted: Tue May 27, 2025 12:38 pm Post subject: Re: TDI DMF issues |
Ok so I spoke to LUK/Schaeffler. They are confident both DMF kits I have are Authentic regardless of the lack of QR codes.
I removed the non operational DMF and found that all the bolts attaching the pressure plate to the DMF were not “tight” and required very little fort to remove. I also found 2 of the three alignment dowels broken in the DMF. I marked the non functioning DMF click and measured the free play at 39mm. The new one has 5mm play
Im going to move forward with installing the replacement DMF and see what happens.
I’ll keep you posted.
Will |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5888 Location: Bemidji, MN
Posted: Tue May 27, 2025 3:10 pm Post subject: Re: TDI DMF issues |
| willyok wrote: |
Will |
excellent! i'm glad you called them. so many counterfeit auto parts now and the good companies are adding authentication apps and staffing phones. was it hard to get to a real person? what questions did they ask to verify? _________________ -dan
www.thefixitworkshop.com |
Posted: Tue May 27, 2025 7:12 pm Post subject: Re: TDI DMF issues |
I downloaded the REPXPERT AP, and called them from the number on that. Provided them sole serial numbers rom the pressure plates and clutch discs and confirmed a couple stamps in specific locations.
Took about 5 minutes. The representative didn’t have a clear reason what caused my issues unfortunately but did say that based on freepoay and broken pins it is bad. |
tjet Samba Member
Posted: Wed May 28, 2025 7:53 am Post subject: Re: TDI DMF issues |
| I've always used Sachs clutches and flywheels in my Jetta TDI. No Luk experience. |
Posted: Wed May 28, 2025 3:31 pm Post subject: Re: TDI DMF issues |
UPDATE
Ok, so I installed the replacement LUK DMF from Amazon and it works perfectly immediately.
I don’t know what happened to the first one but this one feels great.
Thanks for all the contributions. I’ll update once ID parts gets back to me regarding the warranty. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 10776 Location: Western WA
Posted: Thu May 29, 2025 8:03 am Post subject: Re: TDI DMF issues |
Did it have any back-and forth slop?
If yes, how many mm at the ring gear?
In my simple mind, a DMF can't have any slop.
But i don't actually know anything. _________________
....KTMs, GasGas, SPOT mtb |
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10120 Location: Where?
Posted: Thu May 29, 2025 8:59 am Post subject: Re: TDI DMF issues |
The ring gear is mounted to the part of the dual-mass flywheel that is solidly bolted to the crankshaft. There is no slop between the ring gear and crankshaft. The added motion between the two masses occurs between the mass bolted to the crank and the mass on the side of the pressure plate/disc/transmission.
https://www.youtube.com/watch?v=ckf5fWGi5TU |
Sodo Samba Member
Posted: Thu May 29, 2025 9:45 am Post subject: Re: TDI DMF issues |
OK thanks for that link.
So the gearbox side has "the slop" or free-rotation. OK I see how it puts the gearbox on a cushion. Does have it as much free rotation as the diagram depicts?
Having broken the springs on a 'normal' clutch disc I wonder if a DMF would help the gearbox to last longer with a big 4-cyl gas motor.
The massive low-end torque of those 2.7 GoWestys must beat real hard on a gearbox. _________________
Posted: Thu May 29, 2025 11:06 am Post subject: Re: TDI DMF issues |
| Sodo wrote: |
The massive low-end torque of those 2.7 GoWestys must beat real hard on a gearbox. |
I believe it allows 'cushion' up to the point that the springs are coil bound but I haven't destroyed one to find out if there is any additional limit to the rotation.
The downside to the DMF is the added complexity and increased potential for issues as a result. IMO, the whole assembly should also be replaced with each disc. The cost of the DMFs used to be much higher and transaxles used to be cheap. With that reversal their use has become much more sensible IMO.
I believe the DMF would assist transaxle longevity for any engine, but obviously it makes a bigger difference for engines with greater low-end torque, fewer cylinders, and more abrupt power pulses. |
Posted: Thu May 29, 2025 12:18 pm Post subject: Re: TDI DMF issues |
a question to the DMF users... is chatter any more significant on a DMF? soft motor mounts, worn clutch shaft bushings, and driveline slop can lead to clutch chatter on engagement. i would imagine the engineers would have figured that out and not tolerated it in a production environment but it seems like it could lead to some funk on engagement. _________________ -dan
dieseltdi Samba Member
Joined: September 07, 2006 Posts: 796 Location: Grapevine, Texas
Posted: Thu May 29, 2025 12:30 pm Post subject: Re: TDI DMF issues |
I can speak from my experience not only driving TDI cars before and after DMF and my TDI conversion with and with out DMF. In the cars, it really smooths out the vibration of the TDI. Makes for a more pleasurable driving experience, not as much “shock” when you go through the gears and accelerate hard. In my TDI van, it was like night and day. I used to feel all the vibration through the shifter and through the sound of the engine. With the DMF, it is definitely smoother and a bit less loud. _________________ When a clown moves into a palace he doesn’t become a king, the palace instead becomes a circus. — Turkish proverb
Those who will willingly sacrifice freedom for security, deserve neither.
Currently:
1982 Vanagon Westy TDI conversion with Coast Mt. Hightop - SKYE
2025 Hyundai Ioniq 6 EV
2015 Golf Sportwagen S TDI
Way too many previously owned to list! |
Posted: Thu May 29, 2025 12:32 pm Post subject: Re: TDI DMF issues |
| In my experience DMF clutch engagement is noticeably smoother than single-mass clutch engagement. |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2682 Location: Southeast Kentucky
Posted: Thu May 29, 2025 5:21 pm Post subject: Re: TDI DMF issues |
In my opinion, a DMF rules in a Vanagon with a TDI engine....... no question.
I started with the OE Diesel set-up. My engine, without a Tune, would slip the clutch easily.
Then, I installed a Single Mass Flywheel using a Vanagon Pilot Shaft and Clutch Disc. The Clutch Disc cracked somewhere before 20k miles.
Then, I installed a DMF .............. never looking back! Quiet, no slipping, no chatter, and smooth shifting.
For those reading this Thread, as may have already been stated, a DMF will only work with a "diesel" bell housing, OE or aftermarket available at Weddle.
Also, the Clutch Disc that comes with the DMF package doesn't have Springs. And, the clutch disc with springs from a SMF will not work in the DMF package (seems I may have already said this). _________________ '84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful. |
Posted: Thu May 29, 2025 6:05 pm Post subject: Re: TDI DMF issues |
| Sodo wrote: |
But i don't actually know anything. |
Yes the faulty DMF had 38mm of measurable slop. The new one had around 5mm if I pushed really hard. |
Posted: Thu May 29, 2025 6:16 pm Post subject: Re: TDI DMF issues |
I put about 50 miles on it today mixed city driving and 8 miles of stop and go traffic. Clutch feels really nice zero chatter and pretty light pedal feel.
As of right now I’m very pleased. I’ll update in regards to my warranty reimbursement |
syncroserge Samba Member
Joined: November 26, 2005 Posts: 571 Location: Okotos, Alberta, Canada
