DesertSasquatchXploration Samba Member
Posted: Fri May 23, 2025 10:33 pm Post subject: Eliminating Cylinder Head Valve Shrouding for Performance |
Any gains with stock DP heads? I have my topend apart going back together as a 69 crank, 90.5, .040 deck height 49CC heads 9CR.
But why don't I bring the Chambers out to the bore size around the valves and have them cut back to 49CC I have a small step still so heads have some meat on them Is it worth it on a 5K rpm engine 100 cam 1.1 rockers.
Or will i end up with 75CC heads once i remove that material  _________________ Key is to have downward travel Preload keep both wheels on the ground at all times once you lift a tire your DONE. Guys worry about clearance instead think of the opposite you want the suspension to drop that tire in the hole and keep you going. A spider for example they keep their body low but their legs can reach pretty far so they don't (bottom out) |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42958 Location: at the beach in Northern Wokistan
Posted: Fri May 23, 2025 11:12 pm Post subject: Re: Eliminating Cylinder Head Valve Shrouding for Performance |
back cut at least the intake valves and that will help even with stock DP heads. Get rid of any excess flashing in the ports but do not make them shiny smooth. They need roughness to prevent laminar flow. _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7966 Location: Videbaek Denmark
Posted: Sat May 24, 2025 6:31 am Post subject: Re: Eliminating Cylinder Head Valve Shrouding for Performance |
| DesertSasquatchXploration wrote: |
Or will i end up with 75CC heads once i remove that material  |
Initially you are 100% right. BUT, the unshrouding of the valves will only work well if your valve seat cuts are good. If you have a std "out of the box" type of seat cut the positive impact will be minor. That said, if you watch f.i. Brian-E´s tutorial on the subject you will notice that the valve and seat area is VERY sensetive to the right shapes and angles. Even on a 1776 displacement with a medium range cam etc. you can easily loose or gain 10 hp by not getting that area right. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Brian_e  Samba Member
Joined: July 28, 2009 Posts: 4276 Location: Rapid City, South Dakota
Posted: Sat May 24, 2025 4:32 pm Post subject: Re: Eliminating Cylinder Head Valve Shrouding for Performance |
I just finished up a pair of stock valve 040 stock valve heads for a local racer. Stock bore, and they are right at 125cfm at .500". They are my standard, quickie mild port job, with a minimal amount of material removed from the flange shape. 85.5mm bore. Mostly just bowl and seat work.
The same heads, near identical port with a 90.5 bore will flow about 134cfm at .500". That is with my 4 angle valve job, and a back cut valve on both. Only real difference is the larger bore diameter, and the slight bit more un-shrouding on the 90.5.
The un-shrouding is needed, but don't get carried away. Stick to the side walls, and the plug side of the chamber. I don't even touch the non-plug side. There is almost NO air moving there. Un-shrouding out to a 90.5 bore will gain you about 1-2cc is all.
So there are gains to be made there if you spend the time. Without a doubt, the biggest and best gains are made blending the bowls, and getting the seats narrowed and placed well on the valve face. Easy 15-18cfm gain just doing that.
Spending time trying to remove the casting lines in the port will do nothing for flow, and only add port volume in the wrong spots. Don't even worry about the casting lines. Also, you never back cut an exhaust. Only the intakes. Usually about a 3-4cfm gain just doing that.
The most important part of the whole intake port is the 1" before, and the 1" after the valve seat. Spend your time detailing that area, and you will see the most gains.
Brian _________________ So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts |
BFB Samba Member
Posted: Sat May 24, 2025 4:56 pm Post subject: Re: Eliminating Cylinder Head Valve Shrouding for Performance |
Why do you say to never back cut exhaust valve ? _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
modok Samba Member
Joined: October 30, 2009 Posts: 27754 Location: Colorado Springs
Posted: Sat May 24, 2025 5:13 pm Post subject: Re: Eliminating Cylinder Head Valve Shrouding for Performance |
One mistake I made in the past, reading early David Vizard stuff with the idea that all flow is good, low lift and high, and thought it was a good idea to unshroud the valves all the way down by the seat get more low lift flow, to have a good path around the valve at even low lifts, like .200 lift, and....well..... that wasn't the right thing to do for every case.
Not a big deal to worry about, but turns out of you increase low lift flow, but hurt high lift flow, you end up making it run like it has a bigger cam, but in all the bad ways and none of the good ways. DOH
Increasing the gap around the valve at, say, .350 lift and up is a good idea, but I'd leave it alone below that, a lot of the time the stock heads is actually too far blown out down there already. The stock heads were cast a little big so a bit of core shift didn't matter. Check the gap around the valve you'll see it varies a lot one chamber to another, and making them all match the largest one isn't best, more like they had it right on average.
If you use a slightly larger valve and sink it down a bit, that helps improve the situation, as you can make each one match.
And the exhaust side is different but similar. Flow going around the valve on the cylinder-wall side is actually aiming the wrong way to go down the port, so you don't really want to increase that overkill, and maybe it flows more or maybe it doesn't, but flow likes to take the straighter path, so, focus on that the most.
So lay back to the bore size some, yeah, but don't go too far with it and hog out a big swimming pool around each valve. It DOES give more low lift flow, but not the way you want.
I think overall it just runs better being more like a funnel around the intake valve and less like a bowl. There is no one right way, but all the right ways have that aspect in common. |
Posted: Sat May 24, 2025 7:05 pm Post subject: Re: Eliminating Cylinder Head Valve Shrouding for Performance |
Great insight Thanks Guys! I'm going to have at it in the morning ill post a pic tomorrow. _________________ Key is to have downward travel Preload keep both wheels on the ground at all times once you lift a tire your DONE. Guys worry about clearance instead think of the opposite you want the suspension to drop that tire in the hole and keep you going. A spider for example they keep their body low but their legs can reach pretty far so they don't (bottom out) |
Posted: Sat May 24, 2025 9:03 pm Post subject: Re: Eliminating Cylinder Head Valve Shrouding for Performance |
I agree with Modok. Don’t dig a ditch around the valve. Ideally, the chamber walls should start at the 30deg top angle and extend out from there in somewhat of a straight line. More unshrouding as the lift gets higher.
Pictures are always hard to see it all, but this is one I just did. The plug side has a little too much bowl to it, but the material was already removed from there, and that is where 85% of the flow is happening.
Bigger valves blend better into the chamber walls than stock valves.
Focus on the valve bowls, and the valve job, then do the unshrouding.
-Modok
Posted: Sat May 24, 2025 9:04 pm Post subject: Re: Eliminating Cylinder Head Valve Shrouding for Performance |
| BFB wrote: |
| Why do you say to never back cut exhaust valve ? |
The sharp ridge helps fight reversion back into the chamber, and the exhaust rarely needs more flow added.
-Modok
modok Samba Member
Posted: Sat May 24, 2025 9:33 pm Post subject: Re: Eliminating Cylinder Head Valve Shrouding for Performance |
LOOKS GOOD, and well said.
the stock heads have too much ditch aroud the seat, and that worked ok becase in stock form the valve only lifted .300 high.
If the heads were designed for .400+ lift they would have been designed different. You can only half correct it on old stock heads, but a lot of the NEW heads are getting better, clearly!
tho that one spot you didn't touch on the plug side.... and i agree with it  |
Wreck Samba Member
Posted: Sat May 24, 2025 11:06 pm Post subject: Re: Eliminating Cylinder Head Valve Shrouding for Performance |
| Hopefully get a set of Doug's heads heading my way in a few weeks time. |
SGKent  Samba Member
Posted: Sun May 25, 2025 12:21 am Post subject: Re: Eliminating Cylinder Head Valve Shrouding for Performance |
| Brian_e wrote: |
| BFB wrote: |
Brian |
if you plan the right length headers there won't be reversion into the cylinder because the exhaust valve will be closed just before the pressure wave gets there. The pressure will build up against the closed valve, the flow will reverse and when the valve opens suck the exhaust gasses out. It is true that back cutting the exhaust will not give you as much benefit as doing the intakes but there is some decrease in drag and increase in available surface area. _________________
George Carlin:
modok Samba Member
Posted: Sun May 25, 2025 12:41 am Post subject: Re: Eliminating Cylinder Head Valve Shrouding for Performance |
| SGKent wrote: |
| if you plan the right length headers there won't be reversion into the cylinder because the exhaust valve will be closed just before the pressure wave gets there. |
True, but, it's kinda impossible to make a header that works ideally at all engine speeds. Or, lets say impractical. |
Posted: Sun May 25, 2025 6:15 am Post subject: Re: Eliminating Cylinder Head Valve Shrouding for Performance |
| SGKent wrote: |
| if you plan the right length headers there won't be reversion into the cylinder because…. |
And 96.2% of the people on here wouldn’t/couldn’t build a custom header for their application even if they could figure out the math, and then correctly apply it for their perfectly tuned, reversion free 800rpm range.
-Modok
Posted: Thu May 29, 2025 2:37 pm Post subject: Re: Eliminating Cylinder Head Valve Shrouding for Performance |
Well you were right after I did a basic unshrouding they are at 51.5cc give or take. I'm going to drop them off at brothers in the morning. With the deck height @.040 and no rings when i rock the piston its .034. I had the jugs honed they are .0038 over the piston Dim. I think that looks ok.
Since im reusing the pistons and jugs im kinda tempted to do a .50 deck. What do you guys think should I do a .040 deck with used stuff?
I'm super happy i did a top end I had one exhaust valve with a sloppy valve keeper and it was pulling out was going to drop a valve at some point. _________________ Key is to have downward travel Preload keep both wheels on the ground at all times once you lift a tire your DONE. Guys worry about clearance instead think of the opposite you want the suspension to drop that tire in the hole and keep you going. A spider for example they keep their body low but their legs can reach pretty far so they don't (bottom out) |
Posted: Thu May 29, 2025 2:45 pm Post subject: Re: Eliminating Cylinder Head Valve Shrouding for Performance |
Not sure you are able to specify what kind of valve job you want at Brothers, but I would recommend against their standard valve job. You might have better luck with a performance V8 machine shop instead. The last few jobs I have seen from them were very wide seats placed very low on the valve face. Exactly opposite of what you want for good flow. If you can specify, I would ask for a .040” wide seat positioned about .015-.020” away from the margin of the valve. That is for intake only. Exhaust can be about .060 wide placed in the center of the valve face for better cooling.
It seems like a minor detail, but I have seen 8 to 10 CFM gain on a stock valve head just by moving the seat placement on the valve face.
-Modok
