Bilstein jack
phil60
phil60 is offline
PostPosted: Sun Jun 01, 2025 10:55 am    Post subject: Bilstein jack Reply with quote
Hi - can anyone throw any light on how this type of jack works - namely the base that you would expect to go flat on the floor has a metal rod protruding from it.
my3bugs
my3bugs is offline
PostPosted: Sun Jun 01, 2025 11:14 am    Post subject: Re: Bilstein jack Reply with quote
thats the jack handle sticking out , pull it out and it should become clear to you how to use i
some years bugs hold the jack upside down and you just store the handle in the hole like that . keeps em together . just wiggle n pull it out .
not the best pic as he is lowering it here , but youl get the idea .
phil60
phil60 is offline
PostPosted: Sun Jun 01, 2025 1:12 pm    Post subject: Re: Bilstein jack Reply with quote
Brilliant - many thanks. I did try to get the rod out but it wouldn't budge. I'll give it another go.
my3bugs
my3bugs is offline
PostPosted: Sun Jun 01, 2025 2:01 pm    Post subject: Re: Bilstein jack Reply with quote
pull harder !!! Smile
most everything you need to know about VW jacks is here
Dan Holstein
Dan Holstein is offline
PostPosted: Fri Jun 06, 2025 10:32 am    Post subject: Re: Bilstein jack Reply with quote
Hi, is there an available spray can blue for the jack bottom?
Thanks
Dan
panicman
panicman is offline
PostPosted: Fri Jun 06, 2025 9:22 pm    Post subject: Re: Bilstein jack Reply with quote
Krylon Sky Blue. That's the best match I saw in the threads.
