Engine Valve Adjustment
74 Ghia
74 Ghia is offline
PostPosted: Wed Jun 04, 2025 11:49 am    Post subject: Engine Valve Adjustment Reply with quote
Hi,
74 Ghia, stock 1600. My regular mechanic just retired, had been going to him for over 30 years. Just went to a new guy for an oil change and a valve adjustment. Quoted me $534 for a valve adjustment. As I was paying $50-$75, I declined. Any idea of the $ range I should expect?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Jun 04, 2025 12:18 pm    Post subject: Re: Engine Valve Adjustment Reply with quote
No more than an hour, assuming they're really slow.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
rg65
rg65 is offline
PostPosted: Wed Jun 04, 2025 12:22 pm    Post subject: Re: Engine Valve Adjustment Reply with quote
Don't know what the book rate is to set valves but would think 1 to 1.5 hours times the labor rate and parts (gasket set) would be a close estimate. $500.00 seems high.
Era Vulgaris
Era Vulgaris is offline
PostPosted: Wed Jun 04, 2025 2:50 pm    Post subject: Re: Engine Valve Adjustment Reply with quote
rg65 wrote:
1 to 1.5 hours
I could do it in 90 minutes if I drink a beer between each cylinder. Seriously though, it's not a difficult job and shouldn't take more then 20-30 minutes once you've done it a couple times and have the hang of it. $500+ is highway robbery.
Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue
runamoc Premium Member
runamoc is offline
PostPosted: Wed Jun 04, 2025 6:28 pm    Post subject: Re: Engine Valve Adjustment Reply with quote
He did that to scare you away...it worked Shocked
Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
Mr. 010
Glenn is offline
PostPosted: Wed Jun 04, 2025 6:57 pm    Post subject: Re: Engine Valve Adjustment Reply with quote
I like this.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Rome
Rome is offline
PostPosted: Mon Jun 09, 2025 3:47 pm    Post subject: Re: Engine Valve Adjustment Reply with quote
Valve lash needs to be done with the engine "stone cold", meaning probably leaving it overnight if you drive it to the shop so that the work is done in the morning with the car pushed into the shop. There should not be any cost involved to leave the car, since the mechanic is not actually working on it/spending time on it while its parked.
I agree that a practiced aircooled VW mechanic should EASILY do the actual adjustment work in 1/2 hr. Add 15 minutes to lift up and lower the car,, clean off spilled oil from the valve covers off the heater boxes, remove the prior gaskets from the valve covers and install new ones...
Did the new mechanic imply but not specifically mention doing some related work at same time while the car is in the air, such as replace the trans fluid, lube the front beam, check the rear brakes' adjustment and handbrake adjustment, check functionality of the heater cables, maybe even bleed the brakes? That $500+ is exceptionally high.
rcooled
rcooled is offline
PostPosted: Tue Jun 10, 2025 11:46 am    Post subject: Re: Engine Valve Adjustment Reply with quote
Find a new mechanic...
'63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
heimlich Premium Member
VWNOS.com
heimlich is offline
PostPosted: Tue Jun 10, 2025 4:11 pm    Post subject: Re: Engine Valve Adjustment Reply with quote
Where are you located?
74 Ghia
74 Ghia is offline
PostPosted: Wed Jun 11, 2025 6:50 am    Post subject: Re: Engine Valve Adjustment Reply with quote
I am located in Southeastern Wisconsin.
VWNOS.com
heimlich is offline
PostPosted: Wed Jun 11, 2025 7:22 am    Post subject: Re: Engine Valve Adjustment Reply with quote
There's lots of people there with VWs. Maybe you could post a thread asking for recommendations for a new mechanic.
I have customers there. If you send me an email I can ask them as well.
paul_round
paul_round is offline
PostPosted: Wed Jun 11, 2025 9:09 am    Post subject: Re: Engine Valve Adjustment Reply with quote
Why not do it yourself, It's super easy.
Mr. 010
Glenn is offline
PostPosted: Wed Jun 11, 2025 9:23 am    Post subject: Re: Engine Valve Adjustment Reply with quote
This
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
wagen19
wagen19 is offline
PostPosted: Wed Jun 11, 2025 11:32 pm    Post subject: Re: Engine Valve Adjustment Reply with quote
Glenn wrote:
This
It seems, he has not done a valve adjustment since owning the car.
It sounds like he could benefit from a Mentor.
Found the following text here on Samba:
If you do not already have a copy, Buy an Idiot's Guide. It will put you in the right mindset to be one with your car.
eg:
https://www.amazon.ca/Keep-Volkswagen-Alive-Step-S...d_source=1
runamoc is offline
PostPosted: Thu Jun 12, 2025 6:23 am    Post subject: Re: Engine Valve Adjustment Reply with quote
'Garage' of YouTube has 2 'How to' videos...
https://www.youtube.com/results?search_query=adjusting+volkswagen+valves
wagen19
wagen19 is offline
PostPosted: Thu Jun 12, 2025 2:50 pm    Post subject: Re: Engine Valve Adjustment Reply with quote
Imo it seems, the car possibly rather needs not only a valve adjustment, but rather more a "full service" tune up according to original VW maintenance scedule.
For that kind of service, more time as only one hour is needed and also some material.
Is there a book of documented services for that car?
(it seems, the owner never has really worked on his car, but I can be wrong)
When, how many miles or years ago was the last prophylaxis "full inspection" and how old are all the fluids, tires, spark plugs, brake linings etc. now?
I can´t believe, a really complete "full service", properly done, incl. all material could be done for only around 75 $ nowadays in "Good Old USA".
It´s not about cleaning and looking only.
Suggest to have a look on original VW service plans and ask at official VW dealer and any other mechanic, what a service only (without any repairs) would cost and compare.
